USB Flash Drive
I turned my computer tower over this morning and in the process my usb flash drive was bent. The metal tip came out on one side and now the device is not working at all. My life is on this device and I desperately need the data from it. Does anyone know a way to at least retrieve the information from the device??? Any help is greatly appreciated.
    Problem Solver:
  • 9 Answers
I would advise you to send the drive to Drive Savers in the US, or Seagate Recovery Services in Canada. These two companies specialize in data recovery, however it will not be inexpensive.
DriveSavers - www.drivesavers.com
Seagate Recovery Services - http://services.seagate.com/ss/
Posted on Jun 20, 2008
How can i take the bitlocker off my PNY 4GB flash drive?
Windows version like XP.
There are 5 steps to remove BitLocker Drive Encryption from removable drive. Here are the steps.
  1. Open Control Panel then click on BitLocker drive encryption link.
  1. On the nest window, click Turn Off BitLocker link on your removable drive or USB flash drive.
  1. Next, the BitLocker Drive Encryption window will appear, click on Decrypt Drive button to start the decryption process.
  1. The decryption progress takes some minutes to finish, so wait until the process completed. Do not plug off your removable drive during the process.
  2. After the process completed, a message box appears, tell you the decryption process was completed. Click on Close button to close the window.
right click on your 4 gb usb drive select turn of bit locker in W7
hope it helps you
Mar 09, 2012 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Step by step how to use your usb flash drive?
Steps for connecting your USB Flash Drive
Step 1: Take off the cap and insert your flash key into the USB port. The USB port is usually located on your CPU tower (just below where you insert your floppy disk or CD. There will be a symbol that looks like a 'sideways cactus.' See picture.
brymz.jpegUSB symbol
Note : Some computers will have the USB port located on the back of the CPU Tower.
Step 2: Next, you can double-click on "My Computer" on your desktop or hold down the "Flag" key and the letter "E" at the same time (the "flag" key is located between the Ctrl and Alt keys on your keyboard, see picture). This will open up "My Computer".
Step 3: Once you open up "My Computer" to open your flash key, you will need to double-click on it, which at your home computer will either be the E:, F:, or G: drive.
Note:
The reason for why the drive letter might differ, is that your flash key is a "removable" storage so it assigns the next available drive letter. Also, once you insert your flash key in again, the F: drive will change its name to PKBACK, or Removable Disk, or even to the brand name of the flash key such as "Kingston".
Steps for disconnecting your USB Flash Key
Step 1: Make sure that you have saved the documents you have been working on and then close them by clicking on the big red X in the upper right-hand corner.
Step 2: Once everything is closed, click once on the little green arrow at the bottom right of the task bar (see picture).
A message in a box will appear saying "Safely Remove Hardware", or "Safely remove USB Mass Storage Device". Click once on that message.
Step 3: It should now be safe for you to take out your Flash key.
Note : If you want to be certain it is safe, go into "my computer" and check to make sure that the "removable disk" and drive letter your flash key was assigned have disappeared.
Note: If the green arrow still appears, click on it again and it should disappear. If a message appears saying "The device 'Generic Volume' cannot be stopped right now. Try stopping the device later", you will want to make sure that all of your programs or documents on your flash key are closed out.
If you re-try it and the message still appears, push Ctrl + Alt + Delete on your keyboard and then shutdown your computer. You can then take out your flash key or you can re-boot the computer and follow the same process above. You should then be able to remove it safely.
Flash drives are a very useful storage device because of their reliability and memory capacity. Learning how to use them may take a little experience, but once understood the flash drive can assist you in many ways with not only your data files, but using software that the host computer does not have. Also remember that a flash key is not indestructible, so you will want to use more than one physical location to store your data, such as your computer's hard drive, etc.
Sep 13, 2011 | Computers & Internet
My sony flash memory is showing in accessible pls help
There is a way to make it not inaccessible but that would require you to reformat it using the steps below:..
1. To verify that the USB flash drive is actually the cause of the problem by inserting the drive into a USB port on a different computer. Check to see if the drive remains inaccessible on the separate computer drive. Plug the USB flash drive back into the original USB port if it still shows up as inaccessible.
2. Please open the computer's Start menu and then click on the "My Computer" button to bring up a new window with a list of the drives connected to the PC. Find the "Map A Network Drive" button at the top of the new window. Click on the button and wait for another window to pop up on the screen.
3. Now click on the "Drive Letter" drop-down menu at the top left side of the window. Select a drive letter that you want to use for the USB flash drive. Click on the "Browse" button and then locate the USB flash drive. Click on the drive and then click on the "Open" button. Click on the "Finish" button and then restart the computer.
4. Please return to the Start menu and then open the Control Panel. Double-click the icon in the window labeled as "Administrative Tools." Scroll down through the new list of options that will populate the window and then double-click the "Computer Management" link. Click on "Allow" if your computer's operating system asks for your permission to open the Computer Management menu.
5. Find the "Storage" button at the left side of the window and click on it to bring up a new list of options. Click on the option labeled as "Disk Management" and wait for the list of attached disk drives to populate the panel at the middle of the window.
6. Right-click on the drive letter you selected earlier when you mapped the USB flash drive to the computer. Click on the menu option labeled "Format." Make sure that the "File System" heading is set to "NTFS" and then click on "Start" to reformat the drive. Volia.
7. Restart your computer once the reformatting process has completely finished. Attempt to use the USB flash drive again. If still no luck, try purchasing an entirely new flash drive if the computer still will not recognize the drive, as that will indicate it is defective or physically damaged somehow.
Mar 20, 2011 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I am a student in school, and I am not to computer savvy on Flash drive.. It did not come with any instructions on how to use it. It is a Cruzer USB 2.0 Flash Drive (4GB) Can you help me with step-by-step...
  • Boot up your computer and find an open USB port. These are small, rectangular ports typically on the sides or backs of laptop computers, or on the fronts or backs of desktop towers.
  • Plug your flash drive into the USB port. The drive will slide in only if it is turned in the right direction, so if you have trouble inserting it, turn it over.
  • Make sure your computer sees the flash drive. It should launch a menu, letting you know that it has found a new storage device. You can choose an option from the menu or close the menu if you don't need to immediately access the flash drive.
  • Install the flash drive's driver if your computer doesn't recognize the flash drive. The flash drive's packaging should include the manufacturer's website address. Open your Internet browser, go to that address, and download the flash drive's driver from the site. Install the driver on your computer. After that, your computer should be able to recognize your drive.
  • Jan 04, 2011 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
    I bent the metal usb connector on my 4gb cruzer and the light flashes one time and system wont recognize device.
    I had the same situation happen to me. My flash drive was in my computer on my coffee table and my dog tripped over the power wire for the laptop and it hit the floor bending the flash drive to about a 22 degree angle. I gently grasped the metal portion that inserts into the usb port and slowly bent it back to the original position and it worked fine. Two weeks later my dog ate the damn thing!! If you attempt to bend it back, make sure that you do not use pliers or any tool that may crush the metal portion or bend it out of shape. If you have an old computer or a usb port on a wire or hub, insert it, and bend it by hand. Good luck and I hope this helps.
    Oct 26, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Bent flash drive
    I am sorry. if the USB port is damaged or the PCB ( Circuit board) is damaged you are out of luck
    Jul 02, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
    Detection of pendrive is not possible
    Solution:
    i) Try to connect the pen drive on the back side of your computer tower, sometimes usb port present on    the front panel of your computer might not work.....
    Dec 27, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
    My computer wont detect my USB flash drive
    i) try to put the usb drive in some other ports(such as usb port present on the backside of yur computer tower) and check whether your computer is detecting the drive.....
    ii) if not there is sureluy some problem with ur usb drive, replace it  or repair it..., you can even try putting another usb drive(if you have an spare one...)
    Thanking you
    M. Sridhar
    Nov 24, 2008 | Memorex M-Flyer 1GB USB 2.0 TravelDrive
    PNY 4G USB 2.00 Flash Drive
    Solution:
    i) try connecting it on the USB port present at backside or back panel of your computer tower, sometimes USB port present on the frontel panel of your computer might malfunctione or not working properly........
    Nov 20, 2008 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
    Computers & Internet Logo
    70 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
