Question about SanDisk Computers & Internet
I broke the connector from my cruzer usb flash drive. The silver connector is lost and now 4 wires are sticking out. Help!.
    Guru:
  • 2,178 Answers
Try to backup the data you already have in it to a computer. Carefully insert the four wires and the remainder of what's left into a computer's USB port - be careful not to short any of the contacts together or to the chassis of the computer. Make sure the contacts are connected to their corresponding contacts in the USB jack of the input.
Posted on Nov 04, 2010
My sandisk cruzer 8gb was stepped on while in my xbox 360 and i wont light up nor come on when i hook it up to my computer how do i fix it
You could crack it open and resolder all the broken connections in it.. but.. your better off buying a new one. their a pita to repair.
Apr 11, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I forgot my password i cant lost the pic of my familly help
You can reset a lost or forgot Windows password with 4 methods below:
1. Another valid administrator account which can normally log on.
2. A password reset disk or a repair disc.
3. Third-party software to create a bootable password reset CD/DVD or USB, like Windows Password Breaker.
4. Re-install. Will lose data.
Jan 13, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The memory stick pcb has fractured into two pieces
The cruzer does not need the case to work, just be careful how u handle it connect to your computer and get your data. hope this helps
Jun 13, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Sandisk 2gb cruzer micro usb broke
if the usb connector broke off of the board inside the plastic casing, no, you wont be able to retrieve the data.
May 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
My usb not formated when i opend the drive and format windows make error that unable to format the drive
I had the same problem on my scandisk cruzer 4.0g usb flash drive. In the end I lost all data but I restored my flash drive back to normal. Program I used : Partition Magic. Hope this information will help you. God Bless.
May 14, 2010 | SanDisk 1GB Cruzer Titanium USB Flash...
Transfer pictures
1. Insert your sandisk drive intor the usb connector 2. browse the pictures you want to transfer 3. select the pictures (multiple select by holding Ctrl and clicking the picture or select pictures one-by one) 4. after selecting the pictures right click on them and select "Copy" (or your can just press Ctrl+C) 5. go to "My Computer" and browse your USB stick 6. right click and select "Paste" (or you can press Ctrl+V)
Apr 18, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
The USB connector broke!
I did the same to the cruzer as tedthehobit, and here's how I fixed it.
1) Split open enclosure with screwdriver alone edge. The small key-ring will come off when enclosure is separated. (Safety glasses, please). Circuit board is attached to plastic base--the piece for sliding the connector.
2) To see amount of damage and trace connection, remove the plastic as follows. Two notches are on each size at socket end. The other end has plastic bar across on-top. Use needle-nose piler to chew away top of notches, slowly and carefully to avoid stressing board and damaging surface. This makes it easier to move the notches to the side to lift the board up and out.
3) Look at pads where socket was attached. Fairly clean break, surrounding circuit trace and pads are intact. So, it is worth to continue.
4) The socket connection side has no large pads to solder wiring. The D+ and D- traces were lifted off slightly, but too thin to attach wire. Look at the other side.
5) Use flashlight as backlight, and follow traces from connector pads to ends of closest chips where it is big enough for soldering. [I have jpg of connection points--where to post it?]
6) Use wire-warp (hair-thin and pre-stripped) wire and small-tipped solder iron and work under bright light. Tin wire with traces of solder and remove excesses solder from iron tip. Connect wire to chip, melting and using the solder already there.
7) Solder other ends of wire to the correct tabs of the usb socket.
8) Plug usb socket into a socket extender to plug into PC. Extender is optional, but it will help to deteach from PC later.
9) Did not work the first time because 5V-line solder at circuit was not good (eventually came off). Re-solder. Plug back into PC, and cruze lit up and PC can access the file.
Jan 16, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Tip broke off
you will need to have someone resolder the 4 pin connector or submit it to a data recovery service......both of which I do.
Oct 19, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk Cruzer micro 2.0 GB problem
my sandisk cruzer micro 1Gb flash drive was not working for a month while i was copying 5o nos of photo on it.If i plugged in my device my pc getting hanged and the flash drive was not detected, please give me solution.....
Jun 05, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
50 people viewed this question
Top SanDisk Computers & Internet Experts
Alun Cox
k24674
Steve
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
