Question about Bush DVD142RC 14 in. TV/DVD Combo
How do i store channels on Bush TV/DVD
Cant see how to store channels on remote control.
have no manual. nothing on remote to identify how.
can anyone help ?
Barry.
  • mags1943 Aug 06, 2008
    have tried everything to store if a picture comes up its perfect but wont lock in very frustrating
Like yourselfs could not tune in t v chanels very frustrating only solution i bought a digi box pluged it all in fantastic picture well worth the £17 pound that it cost maggie
Posted on Aug 11, 2008
Where can i get a remote for bush dvd player 3081buk cant find one ?????
You should visit some stores which carry a remote and check the manual if your DVD appeares listed. If you can't have a look at the manual - frequently these remotes come in a sealed blister - take note of make and model and then do a google search for the maunal
Some examples of manuals on line are
http://www.nwtel.ca/sites/default/files/media/documents/tv/DRC800-User-Guide-US-EN.pdf
http://www.urcsupport.com/images/uploaded_images/Atlas_OCAP_M1056.pdf
https://customer.xfinity.com/~/media/support_comcast_com/residential/remotes/manuals/silver_with_gray_ok_button.pdf
https://www.foxtel.com.au/content/dam/foxtel/support/pdf/remote-guide-iqhd-TDC850NF.pdf
I looked up this last one and it has all these codes for Bush,
0741 0723 1723 0758 0859 0727 0718 0745 0806 0544 0802 0846 0907 0912 0751 0546 1193 1464 1447 1511 1168 1860 1395
If you are interested in a Foxtel Remote, look for it on google. A site selling it is
http://www.dicksmith.com.au/tv-video/replacement-remote-foxtel-iq-2-dsau-gh3047
Sep 22, 2015 | Bush Televison & Video
Volume up and channel up buttons do not work for 19 Bush tv/DVD combo. How do I reset the remote control
Hi, If you have a computer. look up (google search) Bush tv/dvd combo. There maybe some things you can do yourself. The # 1 thing you can check is the batteries. replace with new and make sure they are in correctly. + to + - to - Do not mix batteries (new with old). Good luck.
Jun 01, 2015 | Televison & Video
Remote control for bush tv not working
REMOVE THE BATTERIES FROM YOUR REMOTE AND TRY USING THE CONTROLS ON THE TV
Jun 21, 2013 | Televison & Video
I can find no replacement remote
The remote you have now has no setup codes for Bush TV. RXA RCR 311W-Model remote have setup code for Bush TV. the code is [1056]
With your present remote control, do a code search method, If there is a code pre-setted for Bush, you will get it.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out
If code search method do not help you, please understand that, the remote control you have now can't be setup with your TV.
Jul 03, 2012 | RCA Universal Remote Control
Remote control manual for bush internet tv
To reset your bush internet t.v. remote after replacing the batteries you must press left down right and number 1 at the same time. You must do this whilst pointing the remote at the t.v. set.
Apr 09, 2009 | Bush 1433GRN2 14" TV
How can I get Freeview Channels?
I have a Bush 6690D and I can confirm that it does have a built-in digital decoder for terrestrial signals (Freeview).
Have you checked whether ***********'s TV is set to digital mode ? The "Mode" button on the remote cycles between analog, digital and AV inputs.
Oct 23, 2008 | Bush DVD2038 DVD Player
Bush 15" conmbo DVD TV
1) change the batteries
2) make sure nothing is between remote and TV
or
3) you may need to buy a replacement all for one type remote because this one is broken.
Jul 27, 2008 | Bush DVD142RC 14 in. TV/DVD Combo
Codes list required for Gemini G610S multi remote
Try 230, 231. 232, 233, 248 for the VCR.
Try 009, 011, 019, 024, 025, 027, 028, 051, 062, 068, 107, 115, 120, 131, 132, 139, 167, 169, 171 for TV.
Sorry - cannot help with DVD.
Len
Jun 06, 2008 | Gemini 1 Device Universal Television...
Connecting a dvd player to a BUSH Bush BTV180T 14in TV/VCR Combi
if there is a scart connection on your bush tv then
you can use your panasonic dvd player on it, trust me
just look all over the remote carefully for an AV button, or failing that press channel up or down whilst the DVD is powered up and playing a disc and you will have solved it
hope this helps mate
Nov 05, 2007 | Bush DVD142RC 14 in. TV/DVD Combo
Bush TV 2137TSIL
go to & ask for manul http://www.television-remotecontrols.co.uk/tv%20remote%20control%20model/bush.htm you will have to give model no.
Oct 04, 2007 | Televison & Video
Bush DVD142RC 14 in. TV/DVD Combo Logo
251 people viewed this question
Top Bush Televison & Video Experts
Joseph Hoffmann
Are you a Bush Televison and Video Expert? Answer questions, earn points and help others
