Question about HP LaserJet 4250n Printer
4250 grinds On every print job the printer grinds and clunks while printing.
    Habit-Forming:
  • 44 Answers
The proper thing to do here is replace the swing plate assembly rm1-0043 with the OEM part. Otherwise, you'll end up in the same situation in half the time. Only a seasoned technician can perform this task as the printer needs to be completely dismantled. 30 minute job if you've done this 20 times before. 2 hour job if you've never done it before.
Posted on Aug 07, 2012
This is a very common problem for this model ... the swing plate assembly has a black gear which in particular is prone to wearing out ... originally the design was a plastic gear, PrinterTechs has a metal gear replacement which is sturdier ...
instructions: http://www.printertechs.com/tech/assemblies/swingplate/swingplate1.php
Posted on Mar 31, 2009
Actually, TSAworld offers a simple solution to this very common problem with HP LaserJet 4200, 4250, 4345 and 4350 models; "gear chatter" or grinding noises. The problem is caused by the fuser drive gear mechanism, commonly called the "swing plate assembly". We sell a kit which contains aftermarket components to rebuild the existing swing plate assembly and the fuser gear. As long as the actual swing plate assembly is not bent or the spring is not missing for damaged, then fixing this problem literally takes about 15-20 minutes by following our detailed instructions included with each kit. Arm yourself with a simple, quick, and cost-effective solution. Plus we sell lots of other kits for taking care of many other common issues with printers and copiers. You can reach us at 1-800-633-6626
Posted on Sep 03, 2008
Test
  • 4 Answers
Remove the fuser from the rear of the printer and look on the left side from the rear. Most comon problem is that the swingplate gear wears down so much that the gears slip and grind. If you see a pile of black powder under this gear plate this is for sure the problem. Complex repair job. Lots of dis-assembly is required.
Posted on Jun 15, 2008
  • HP Master
  • 2,794 Answers
It needs to be looked at by a technician to see it there are any broken gears in it.
Posted on Jun 13, 2008
Hp 4250(on a network) is hung up on processing job. I restarted the print spool and physically restarted the printer put the problem still exists.what should i do
you may need to turn off your print services on your pc. pull up the printer que on the pc. delete the jobs in the que. right click my computer. go to mange. go to services and applications .go 2 services. double left click. look for print spooler. right click. choose stop. then go to printer and reset job. turn off printer. turn on printer. restart your print spooler. close all windows and try to print
Jan 07, 2011 | HP LaserJet 4250n Printer
When i print, the printer makes a grinding noise the paper gets jamed also.
Remove the fuser unit and check if there is a residue on the side of the gears. If so, you 'll have to replace the swing gear assy. Partnumber 5851-2766. It is not an easy job!!!
Gerrit Jan
Oct 28, 2009 | HP 4250 Monochrome LaserJet Printer
Lexmark C510 is making grinding noises while printing large jobs
I found another posting stating that the culprit was the black toner cartridge. Sure enough I changed our black cartridge and the grinding noise has stopped. No wonder the grinding noise was not happening all the time only when the black cartridge got low. Thanks for the help!
Oct 15, 2009 | Lexmark C510 Laser Printer
Error during print 'Remove all paper from bin'
HP Laserjet 4250 Network connected laserjet printer.
Steps to be follwed to set right :
01. Please check in number of desktops or laptops it connected.
02. Give proper IP Address in the Desktop or Laptop where it has to be orignally installed.
03. Being a network printer, lot of desktop or laptop users might have printing job iniated.
04. Right click the printer properties which is available bottom right hand corner ikon and delete or cacel all printing jobs.
05. The original desktop or laptop where the IP Address created will be rebooted. System should be restarted.
06. Try to print now to close this solution.
07. Still the problem persits, kindy contact local HP Authorised printer service engineer to set right this issue.
Have a nice working day.
Jul 17, 2009 | HP 4250 Monochrome LaserJet Printer
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Need to clear all printing jobs from the printer 4250 HP
It's probably queued up on the computer you're using. If this is Windows or Mac, look for a printer icon toward the bottom-right corner of your screen.
If you don't have it and you're on Windows, click Start: Control Panels: Printers. Find your printer.
Inside the new screen, you should be able to first pause the printer, then cancel all the jobs. You may have to highlight all of them, then right-click to get cancel.
When they're all cleared out, go back to where you paused the printer, then hit Resume printing.
Jan 19, 2009 | HP LaserJet 4250n Printer
HP LaserJet 4240/4250/4350 PCL 6
I think its a virus infected....... run scanning software.. to detect virus... second you need to do is log in as a administrator then go to the printer property and delete pending print jobs...then restart your unit..
gudluck
Mar 25, 2008 | HP LaserJet 4250n Printer
HP LaserJet 4250n Printer Logo
332 people viewed this question
Ben Johnson
