Looking for driver s3c6410 android adb - Computers & Internet
    New Friend:
The right place for you is: driverupdate us. Great database (including your driver), easy to navigate, fast reults. best of luck
Posted on Nov 02, 2014
Do not download any S3C6410 drivers
Windows detection for this is FALSE
It thinks the PanDigital is a Mobile phone and is
trying to download a Com port loader which is
unnecessary and wont work anyway
IGNORE or CANCEL
CONFIRMED with PanDigital
(The OS is ANDROID 2.x and thats why Windows? thinks its a phone when its not...
Posted on Nov 26, 2010
4 Suggested Answers
SOURCE: I need to download the
here is the link to a forum that can help you locate the drivers
http://openschemes.com/2011/04/29/pandigital-novel-adb-debugger-driver-mirror-s3c6410-android-adb-driver/
Posted on May 07, 2011
SOURCE: CAN'T FIND THE DRIVER S3C6410
DO NOT INSTALL ANYTHING FOR S3C6410;
WINDOWS DETECTION IS FALSE
IGNORE THIS/CANCEL
WINDOWS THINKS THE PANDIGITAL NOVEL PD07 IS A PHONE WHEN ITS NOT
  • 11 Answers
SOURCE: I cant find the driver
Here is what I have found. You cannot let windows automatically install. You must answer no to automatically install and do it manually. So try downloading this link and unzipping it where you can find it. And then point the install window to this .inf file.
a somewhat official answer is all your problem is lack of androidusb.sys, which located in windows\system32\drivers\, it was deleted or replaced by installing some other android related usb client drivers, however, when you install it manually by pointing it to the android_winusb.inf, it do copy the .sys file into system32\drivers\ again, so when come across with this problem, remove target client device keys (with the VID/PID) in registry in currencontrolset/usb/enum, then better restart windows , and run .exe file to install driver or install it manually, and if you can get the right androidusb.sys from your driver directry (for example c:\progrm files\htc...), you can just copy it into system32\drivers\ but complicated.
I cannot vouch for this file but it looks legit. CaptivateADBDriver xp.zip
Posted on Feb 02, 2011
My alcatel is asking for an adb sideload. How do I do this?
Probably every Android power-user at least once in his life used ADB - Android Debug Bridge. It is a versatile command line tool that lets you communicate with an emulator instance or connected Android-powered device. Using ADB shell commands gives you additional control over your device and sometimes it can save your device from being bricked (example: How to: copy ROM zip file to the freshly wiped device). You can find some more basic information about ADB here.
How to: copy ROM zip file to the freshly wiped device. The main difference is that ADB sideload works only with recoveries based on Jelly Bean source or newer. I believe that ADB sideload was created to simplify the process of flashing/restoring Android update.zip packages.
Keep in mind that while using ADB sideload, the regular ADB shell won't work. To be able to use SIDELOAD mode make sure you're running latest ADB drivers from the Android SDK (Platform-tools). Here are the simple steps you need to follow to flash update.zip package using adb sideload mode (based on stock Android recovery):
  1. Place the ZIP package you want to install in the same location where you keep ADB drivers - adb.exe, AdbWinApi.dll and AdbWinUsbApi.dll (usually it's SDK\platform-tools)
  2. Make sure you have USB debugging enabled in Settings > Development on your device
  3. Make sure your phone drivers are installed on the PC you're going to use
  4. Boot your device in recovery mode (Android logo with a exclamation mark) and connect your device to PC
  5. Hold down "power" button first, followed quickly by "volume up" button. You should now see the recovery menu
  6. Use the volume up/down keys to select "apply update from ADB," then press power to select it
  7. Open a command prompt on the PC (cmd.exe), type and confirm with ENTER:
  8. cd /d <adb.exe location> (for example: cd /d c:\SDK\platform-tools) or you can open your SDK/platform-tools folder, then press SHIFT button and the right-click mouse button and choose "Open command prompt here"
  9. adb sideload <filename>.zip (for example: adb sideload update.zip)
  10. The zip package will begin installing. When it's done, select "reboot system now."
How is that different from the alternative method? You don't have to manually create the proper folders structure, push the file and later install if from inside the recovery menu. The result is basically the same, because ADB sideload is also transferring the zip file into the device internal memory and later it automatically begins the installation procedure. However, it works only with recoveries based on Android Jelly Bean source.
May 16, 2015 | Alcatel Cell Phones
Restart a tablet when it is locked
  • Connect the tablet with USB cable to the PC
  • Open the command prompt
  • Change directory to the android SDK platform tools (Type in cmd--> cd C:\Program Files\Android\android-sdk\platform-tools)
Type following commands in cmd
  • adb devices (verify device is identified by pc. If not reconnect device and try again)
  • adb shell
  • adb reboot
It will restart.
Feb 12, 2014 | Android 4.0 Tablet PC
Where can I get the driver download for my Cruz reader S3C6410 Andorid ADB?
You can download the ADB driver for the Cruz Reader from Velocity Micro here.
Hope this helps
Ray
Mar 15, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I cant find the driver for my samsung intercept. I would like to connect to my computer but the S3C6410 ANDROID ADB doesn't work
Feb 02, 2011 | Computers & Internet
Need driver to sync s3c6410 android adb
If you were to log on to the manufacturer's web site, I think you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
The information is normally free of charge.
I hope this helps.
Jan 23, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
I have just purchased a pandigital novel ereader and my computer can not find a driver for a S3C6410 Android ADB. There was no disc with any drivers in the box. Where can I get this driver to make the...
Hi enpugh,
Here is an article titled:
How to install and set up the Android ADB drivers.http://www.softsailor.com/how-to/20430-how-to-install-and-set-up-the-android-adb-drivers.html
but I'm not sure if this is what your looking for.
Here is an Android Forum that might help you:
http://androidforums.com/captivate-support-troubleshooting/186357-cant-install-adb-drivers.htmlhttp://androidforums.com/captivate-support-troubleshooting/186357-cant-install-adb-drivers.html
and an article titled: How to Install Apps using ADB
http://androidcommunity.com/forums/f4/how-to-install-apps-using-adb-4482/
Hope this helps.
Dec 26, 2010 | Computers & Internet
CAN'T FIND THE DRIVER S3C6410 ANDROID ADB FOR MY PANDIGITAL NOVEL !!! PLEASE HELP ME !!!
According to online advice, this is not required for the pandigital novel. The Windows detection for this is false and is apparently prompted because windows believes the pandigital to be an android phone. The solution is apparently to leave it and assume no driver is required. The Windows 7 driver installation window should read, though, that a USB Composite, USB Mass storage, and two android UMS Composite USB devices are found and ready to use. Hope this helps .
Dec 25, 2010 | Computers & Internet
CAN'T FIND THE DRIVER S3C6410 ANDROID ADB FOR MY PANDIGITAL TABLET !!! PLEASE HELP ME !!! CHANTAL
IGNORE THIS/CANCEL
Nov 13, 2010 | Computers & Internet
Computers & Internet Logo
13,965 people viewed this question
David Payne
David Payne
