Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Refregerator Hi, My kenmore ,side by side refregerator, Freezer is fine but refregerator is side is not cooling. Is it the fan fried , if so how do i change it. Thanks
  • jorge otero Jun 28, 2008
    kenmore elite side by side refrigerator on right is not cooling. freezer is fine. took off back cover in rear bottom behind the refrigerator(in the back near the floor where motor is). Motor is running and nothing seem to be frozen.
  • Anonymous Aug 04, 2008
    Freezer making ice- refrigerator set on 5 --seals on doors and divider between freezer and refrigerator gets hot, not warm. Refrigerator side not cooling enough. Any help?
  • 868 Answers
If your sure its not working ,you have to remove the cover in the freezer on the back wall and it requires a volt meter to make sure its not working.
Posted on Jun 13, 2008
Fridge warm, freezer cold. repair guy said its fine if milk is not spoiling. but set at 6 coldest temp is around 40
Can you feel air movement from the freezer to the refrigerator side through the cooling tubes when the evaporator fan is operating?
If not you might have some ice build up in the cooling tube that is not allowing the refregerator to get cold enough. Try a hair dryer to clean it.
Aug 19, 2011 | Frigidaire FRS26R4A Side by Side...
The frigerator & freezer are not cooling properly . i hear the compressor running . i have also diconnected cleanned inside and out but still the unit is not cooling properly . even on higest settings
If the compressor is running almost all the time (and the compressor sounds ok - no pinging/clunking),
then your side-by-side has developed a coolant leak.
When a system is low on coolant, the thermostat detects the warm condition of the refrigerator, and
runs the compresor motor in an attempt to cool off the refrigerator compartment, but if there's little
or no refrigerant in the system, the system's attempt to cool off the refregerator/freezer will fail,
with the symptom that the user wil hear the compressor motor running constantly.
May 13, 2011 | Kenmore Side by Side Refrigerator
Freezer works but not the refregerator
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 24, 2010 | Samsung RS2556 Side by Side Refrigerator
NO COLD IN THE REFREGERATOR SIDE
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Oct 19, 2010 | Whirlpool GD5SHAX Side by Side...
Top refregerator not working
look for ice in back wall of freezer . this is a no frost and that means no frost .. you may have a defrost system failure .. mm
Jul 04, 2010 | Amana 22.6 cu. ft. Side-By-Side...
GE Profile GSS25LGMB
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Sep 05, 2009 | GE GSS25LGM Side by Side Refrigerator
My refregerator is sid by sid, not making ice and is not cooling
if the fan motors and everything is else is running proprerly, i wouldnt be suprised if you needed to have some freon added to the system.
Apr 20, 2009 | Frigidaire FRS23KF7AB Side by Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
123 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
