Question about HP DeskJet 1220c InkJet Printer
Yellow light keeps blinking, nothing prints, reboot several times, turned off, still keeps blinking, no printing.
See Above
  • Scrapit Aug 30, 2008
    Yellow light keeps blinking, no print option. Book says that it is caused by the cover being open (it's not) or it is a cartridge error!
    Cartridges are new so what is my problem?
    Cheesed off
  • 417 Answers
Yellow light is normally user related to clear it is either that the ink cart is faulty or empty or that the paper isn't being picked up. If the latter remove all paper open the rear door and clean the black rubber rollers. You may even notice that there is a small piece of paper stuck there.
Thanks Jason
Posted on Aug 17, 2008
Buy a Canon. Inks won't expire.
Posted on Aug 14, 2008
Alarm/power light blinks five consecutive times
A repeating 5 orange flash is supposed to mean a foreign object inside the machine interfering with the print head. Check at both ends or the carriage track for a crumpled up wedge of paper. If nothing is there, check down the back paper feed path. If still nothing, it is possible the print head is overheating and is about to die.
Jan 03, 2018 | Canon PIXMA iP4200 InkJet Photo Printer
Hp lj 2500 flashing yellow light
The yellow-print-cartridge
light is blinking, and the
printer stops printing.
 The print cartridge is
empty or missing.
 The printer cannot
detect the print
cartridge correctly.
1. Reinsert or replace the print cartridge.
2. If the print-cartridge light is still blinking but the
Attention light is not on, turn the printer off and
then back on.
3. If the problem persists, repeat the above steps
with yellow print cartridges until the error is
resolved.
4. If the problem persists, replace the printcartridge
E-label reader, which is located on the
pressure assembly of the print-cartridge
carousel.
Jan 09, 2009 | HP LaserJet 2500L Printer
Won't print
have you tryed new cartridges on it or are you trying to use refilled cartridges?
Jun 22, 2008 | HP DeskJet 5150 InkJet Printer
The light blinks 12 times, and nothing will print
suggest you need a new set of printer drivers
remove old version first
go here for new ones
re install
Mar 20, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Our Canon Selphy DS810 is not printing any color on the photo paper. I cleaned it several weeks ago, we have a new ink cartridge in and nothing. It was printing a light yellow color several weeks ago...
There are all kinds of printers and printing problems. It’s important to note at the outset that for safety reasons you should unplug your printer if you plan on working inside the device for any reason. In addition to the electrical hazard, printers (especially laser printers) can also be very hot on the inside, so use caution.
There are a few general troubleshooting steps you should take first, regardless of your printing problem. These will help solve most everyday printing issues.
Reboot. You’ll be amazed at how many printing problems simply disappear after you restart your computer. Also, reboot your printer. Sometimes, for no good reason, a printer will become wedged (it just stops communicating with the computer). Turning your printer off for a few seconds, and then back on, will usually get you going again.
Read the printer’s lights. Doing this can provide you with very useful clues. Is the power light on? Is the paper feed light blinking? Don’t be afraid to press buttons on the printer: Turn it off and on, reset the paper feed, and take the printer offline and bring it online again.
Check your physical connections. Is the power cord loose? Does the cable from the printer to the PC have a secure connection at both ends? Look at the connector pins on your cable. Are they bent? Try another cable if you have one. Check the print cartridges and printing mechanism. Is anything blocking the printer? Are the cartridges firmly in place?
Print a Windows test page. Access your printer’s Properties dialog box (follow the directions given above). Select the General tab and click the Print Test Page button. If nothing else, you can find out a good deal about your printer’s problem. If the test page prints, you have a problem with your application, not with Windows. Answer the questions as prompted and work through Windows’ Print Troubleshooter as needed.
Drivers. Verify drivers on the Details tab in the Printer Properties dialog box. Make sure the installed driver corresponds with your actual printer. Check the manufacturer’s Web site for updated drivers and browse the support pages on the site while you’re there.
Mar 06, 2008 | Computers & Internet
Won't print
This relates to the problem with Driver. Uninstall all the printer driver for this Printer and then restart. After that reinstall all the drivers. your problem must be solved.
Feb 04, 2008 | HP DeskJet 610cl InkJet Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP DeskJet 1220c InkJet Printer Logo
300 people viewed this question
Ben Johnson
