Question about Sony Dvcam DSR-PD170 DV Digital Camcorder
PD 170 Recording problem
During recording the images look completely normal. On play back towards the left side and from top to bottom past recorded bits of information is being displayed along with the current images. They are present in irregular blocks. I don't know how to better describe this problem.
  • Bowguy Jun 13, 2008
    The first three quarters of the tape has this problem where the last quarter was normal.
    Master:
  • 497 Answers
Defective image sensor block shud be the problem
Posted on Jun 13, 2008
  • Broadcast Innovations Jun 17, 2011
    dear,
    this is just a tape path problem nothing else, go to a good service centre tell them to align your cameras tape path .
Need the manuel original lost or misplaced and can not find. want to record cassettes to cd's
Insert a blank CD-R or CD-RW into the unit. Press the Function button on the remote (key above Vol+ on the bottom right of the remote) or the turntable itself (top left of the control panel) until the unit is in Phono mode. Then insert the pre-recorded cassette and press Play to advance the tape to where you wish to start recording. With the cassette playing, press the CD Record button (recording will flash on the display). The CD Record button is to the left of the fast reverse button on the unit; it is labeled Record on the remote and is below the Stop button. When one side of the cassette finishes playing, press Stop. Wait for the display to return to Phono. Then eject and turn over the cassette to play side 2 (if you want to record both sides of the tape). Press Play again to advance the tape and then press Record. When this side finishes, press Stop and then Finalize. Finalize is at the bottom left of the remote buttons and to the left of the stand by indicator on the turntable.
The manual is available at Crosley: http://www.crosleyradio.com/Product.aspx?pid=1790 . The direct link to the manual is http://www.crosleyradio.com/Manuals/CR248_Manual.pdf . Recording a cassette to CD is on page 11 (page 12 of the pdf).
I hope this helps.
Jun 10, 2011 | Crosley CR248 Turntable
How do I view video
First set the camera to Playback mode. On the back of the camera there are two circular buttons. Looking at the top circular button, the bottom option is a right-pointing arrow. Press that arrow.
The last thing you photographed or recorded will display on the screen. If this is not what you are looking for, you will need to navigate to the correct item. To do this, use the bottom circular button that has both a left-pointing arrow and a right-pointing arrow. Use the left-pointing arrow to go back through your images/recordings.
The video recording should play automatically and repeat when completed.
May 04, 2011 | Fuji FinePix Z10fd Digital Camera
Which button is which
On the top of the device are the recording indicator and built-in microphone. On the front of the device to the right of the screen: (from top to bottom) ERASE, MENU, VOLUME UP, VOLUME DOWN
The MENU button cycles through these options in this order: Folder, record condition, record quality, AVR on/off, play condition, beep tone, set year/day/12 or time, key lock on/off
On the right side of the device: (from top to bottom) RECORD, STOP, PLAY, FORWARD*, REVERSE* *(FORWARD/REVERSE can be used in the MENU mode to select options)
On the left side of the device: (from top to bottom) External microphone jack Connects headphones
Here is an online (*.PDF format) manual for the recorder: MANUAL
I hope this information helps! :-)
Mar 06, 2011 | RCA RP5020 Digital Voice Recorder
I have problem with my pd 170 when i push recording switch it gos on paus mood
There are three buttons for recording. Please try the other two buttons ( one is on the top, other is under the handle) if the recording starts with any of the buttons, then your main button will be faulty. You have to get it replaced.
Hope it helps. Don't forget to rate me.
Thanks for using FixYa.
Jan 15, 2011 | Sony Dvcam DSR-PD170 DV Digital Camcorder
I have a PD 170. The LCD monitor turns completely blue
there is problem with on/off switch contact below to have that fixed.
Regards
Sep 18, 2009 | Sony Dvcam DSR-PD170 DV Digital Camcorder
My Sony DCR DVD 108 has no image at all with or with out disc says lens cap may be closed but it isnt flashing E:61:11 top right hand side of touch screen plays previously recorded dvd fine but thats it.
You may have lost your image sensor.
  1. Take lens cap off.
  2. Look in lens make sure there is nothing on or blocking lens.
  3. Find bright room & see if image comes up.
  4. Make sure your in video record mode.
  5. If you have eyepiece lens look to make sure it is off. {Most cams will not let you use both at same time.}
  6. Still no image try recording on blank disk then play back see if image is recording.
If that does not work MSG back.
Mar 07, 2009 | Sony Handycam DCR-DVD108 DVD Camcorder
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
No sound recording during video recording with olympus fe 170
To my knowledge, an Olympus FE-170 has no audio recording capability and records the video on 15FPS.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 30, 2008 | Olympus FE-170 Digital Camera
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
I used my pd-dvr100 to record a copy of a home made dvd. I do not know the format of the source disc. The process went well. The PD-DVD100 WILL PLAY THE DISC. However, the disc will not play on the player...
Have you tried to make sure the disc is finalized. Second check the manufacture website to make sure that the dvd player you are trying to play it in is compatible with the disc type that you recored on. Veryfy this by looking at the disc type on the dvd commonly refered to as +R or -R
Mar 08, 2008 | Protron PD-DVR100 DVD Recorder
Sony Dvcam DSR-PD170 DV Digital Camcorder Logo
128 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Sheryl Bahr
Sheryl Bahr
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
