Question about Microsoft Windows Server Standard 2003 for PC
Volume shadow copy backup error : 800423F1
I have been running a regular full b/u for my Windows Server 2003 with no problems until recently. Now, whenever I attempt to run a backup of the server (to a tape) I get the following error message:
Error returned while creating volume shadow copy: 800423f1
Operation aborted
Any help would be greatly appreciated
    Problem Solver:
  • 7 Answers
Http://support.microsoft.com/kb/833167
u may reffer this for sol.
Posted on Jun 17, 2008
Ved opstart af window defender
From your description, I understand the issue to be: you received VSS error 0x8007042d.
I. First please re-registry the following DLLs to see if it helps:
1. Stop the Volume Shadow Copy service: Open a command prompt and change
directories to \WINDOWS\system32 (this is important when you begin
registering the DLLs):
net stop vss
2. Then register the following DLLs and services (be sure you're still in
the WINDOWS\system32 directory at your command prompt):
regsvr32 ole32.dll
regsvr32 vss_ps.dll
Vssvc /Register
regsvr32 /i swprv.dll
regsvr32 /i eventcls.dll
regsvr32 es.dll
regsvr32 stdprov.dll
regsvr32 vssui.dll
regsvr32 msxml.dll
regsvr32 msxml3.dll
regsvr32 msxml4.dll
Start the Volume Shadow Copy service by running "net start vss", do a test
backup and see how it goes.
II. If the issue persists, Let's perform these troubleshooting steps:
1. Make sure you can use OSQL to connect to every running instance of
SQL/MSDE on the box, if you can not disable all of the instances.
You can find all of the instances installed on your server, by looking at
this registry value: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL
Server\InstalledInstances
The syntax would be "OSQL -E -S <servername>\<instancename>
For example OSQL -E -S server\SharePoint
If you can't connect to the database, then it will cause this type of
failure.
Also make sure that each of the SQL/MSDE instances is either running under
the Local System account or a Domain Admin account.
2. The issue may occur if there is corrupted data on the drive to be backed
up. Please run CHKDSK on each drive with the /f switch to fix the errors on
the disk (if there are any).
3. Per my experience, this issue can be due to VSS thinks the system is
still in setup process. Please perform the steps below to check the status.
WARNING: Using Registry Editor incorrectly can cause serious problems that
may require you to reinstall Windows. Microsoft cannot guarantee that
problems resulting from the incorrect use of Registry Editor can be solved.
Use Registry Editor at your own risk.
Open the registry and locate the registry key:
HKEY_LOCAL_MACHINE\SYSTEM\Setup
Ensure both registry values are set to 0:
- SystemSetupInProgress
- UpgradeInProgress
4. If the issue still happens, reinstall COM+ by following these steps:
A. Backup and then delete HKLM\Software\Microsoft\COM3
B. Boot to Recovery console and rename clbcatq.dll to ~clbcatq.dll. Be sure
to use the tilde.
C. Boot to normal mode and in Control Panel, open the Add or Remove
Programs tool, and then open the Add/Remove Windows Components tool. Do not
make any changes, just click "Next". This reinstalls COM+.
NOTE: You must have your Windows Server 2003 SP1 files available during
this step.
Hope above information helps! I am happy to be of assistance to you and
look forward to your reply!
May 31, 2010 | Microsoft Windows Vista Ultimate Edition
Windows 2003 Server Task Scheduler Exit Code (1)
Have you tried to use robocopy.exe instead of copy? Robocopy have a logging option and is a lot more powerful. It's available in Windows Server 2003 Resource Kit Tools.
May 26, 2009 | Microsoft Windows Server 2003 Enterprise...
the exit code of 1 or 0x1: Incorrect function called or unknown function called.
check your backupRBase.cmd file. one of the URL or function need to be modify.
Mar 04, 2009 | Microsoft Windows Server 2003 Enterprise...
I recently upgraded a server from server 2000 to server 2003.
I presume you did not do a full system backup of your Server 2000 system/boot drive before upgrading to Server 2003? If you did, just restore your Server 2000 backup. If not, then backup all your application data files and re-install Sever 2000 as if it was a new install. Then re-install your application and restore the data files.
Another possibility is to check with your application vendor and see if they have a version that works with Server 2003.
Feb 27, 2009 | Microsoft Computers & Internet
COULD NOT LOAD OS - TRIED 2000 & 2003 SERVER
Reinstall OS without repairing. Sometimes people make the mistake between a choosing repair and a full reinstall. Also backup any files before doing so.
Sep 20, 2008 | Acer Altos G530 Server
System State Backup problem
That specific error pertains to "validating" your copy of Windows. you might want to validate that copy, then re-try system state.
~~Jasta~~
Mar 24, 2008 | Microsoft Windows Server Standard 2003 for...
New to exchange server 2003
Hello there!
First things First!
1) you always going to have problems with exchange servers, or migrations. ** systems are not perfects**
2) You can migrate the emails to the new server, but, if only are in the correct version of Exchange 2003.
3) if backup is damage or fail, you lost everything.
4) try to reinstall the Server, and all utilites, is better, I know takes more time, but is better because you created yourself.
I suggest you to install from scratch!
Good luck
Feb 24, 2008 | Computers & Internet
New to Exchange Server 2003
U mail is noted friend.. U all files and foeld is xchange the new Windows Server 2003, than no problem..
Feb 24, 2008 | Microsoft Windows Server Standard 2003 for...
System State not successfully
This is common in the following OS.
• Microsoft Windows Server 2003, Web Edition • Microsoft Windows Server 2003, Standard Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise Edition (32-bit x86) • Microsoft Windows Server 2003, Enterprise x64 Edition • Microsoft Windows Small Business Server 2003 Premium Edition
This problem occurs when the following conditions are true: • You back up data from a volume that contains a Microsoft SQL Server database. • The recovery model of the SQL Server database is configured to use an option that is different from Simple.
Submit a request here to get a hotfix from Microsoft ( Its free and no product key will be asked )
http://go.microsoft.com/?linkid=6294451
Feb 18, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
620 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
