Question about Panasonic PT-40LC12 40" Rear Projection HDTV
Replaced bulb, no picture, green light blinks
Can you please help? Should I try a repair shop?
  • apdxguy Jun 15, 2008
    Yes I am only a few months into a new bulb and the TV shut off mid movie tonight without warning. Unable to get the set to come back on. Push power button and the red light goes to blinking green but NO PICTURE! At this point, I don't think it is wise to invest much more into this TV but I wish someone had a relatively quick and not too costly fix.
  • 19 Answers
Usually indicates a bad or defective bulb. If new, it was manufactured defective. If used, it is usually due to excessive heat.
The ballast used to ignite the bulb could also be weak, but usually it turns out to be the bulb.
There is a method to increase the bulb's internal fan speed to aid in additional cooling and prevent overheating, but will also allow more dust to be drawn into the TV if the air filter is not sealed tight.
Posted on Jul 09, 2008
Green Blinking light on Mitsubishi Unisen lt 40164, tv wont turn on?
Blinking light means your bulb is blown and needs to be replaced. Very easy to do. Check owners Manuel . Shop the bulb on ebay
Dec 19, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
Power button blinks green about 1 minute then goes red
There is an additional problem,
if the bulb had been replaced by a technician, call them back and ask for additional support, since they did not fix the problem.
Oct 15, 2008 | Panasonic PT-50LC14 50" Rear Projection...
I have a Sony Wega LCD Projection 60wf655. When I turn it on, the red light turned green and blinks green 6 or 8 or 10 times or indefinitely. No picture but after a minute of being on the screen glows...
This could be the "thermal fuse" which usualy is next to the light bulb. Part cost around $5.00. Please check your manual for directions depending on light and times blinking.
Apr 11, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have one of thos green blinking light and NO
The lamp light would be solid red if the lamp were out. The steady blinking green led is usually caused by failed capacitors on the DM board. You can get the V26 dm repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the capacitors and the CD with detailed instructions.
Jan 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
I have a Mitsubishi Ws-65511 65" and the green light on front panel blinks continuesly and the tv will not turn on with the power button or the reset button on the front panel. If we unplug the power cord...
The Bulb in the unit needs to be replaced. To confirm, look in the manual for the set and it will explain the flashing lights by the numer and duration of flashes. Hope this helps.
Jun 07, 2009 | Mitsubishi WS-65511 65" Rear Projection...
Toshiba HMX94 DLP I replaced the bulb after it crashed and now red and green light flashes no picture. Please help. I tried two new bulbs. Mark T
The problem most likely is with either the lamp ballast or the light engine. The lamp ballast is the part that provides voltage to the lamp unit and is usually not all that expensive a part. The repair cost from a service shop can be about $300 or more. If you are handy, you can replace it yourself. Check out www.thepartstore.com for the ballast.
Apr 11, 2009 | Toshiba 42H81 42" Rear Projection...
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi HD TV 1080 blinking green light
sounds like it has a bad DM assy, or a bad 9v reg ic.
the dm can be repaired, there are 4 capacitors on it that need to be replaced.
Dec 13, 2007 | Televison & Video
Green flashing light - no picture
If the green power light is blinking and you have no picture, then your light bulb has burned out and needs to be replaced. It is not a cheap bulb to replace. If the TV is less than 1 year old it should be covered by the warranty
Nov 03, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Panasonic PT-40LC12 40" Rear Projection HDTV Logo
42 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
