Question about Estate TAWS800JQ Top Load Washer
My washer water level is not working
Hi I'm having problems with my washer. If I put the water on low level or med. it just keeps going. It over flowed all on the floor . What can I do?
    Genius:
  • 1,073 Answers
Replace the water pressure switch
Posted on Jun 13, 2008
How to control water levels in Maytag TOP LOAD WASHER, model #MAV 6000 AWW
What is the problem?
Water level is automatically controlled based on what you set it to low, med, or high.
Jul 14, 2017 | Maytag Washing Machines
Hi, What controls the water level and turns off the cold water shut-off solenoid on an Admiral washer? It sometimes sticks and floods the floor. Thanks
the water level switch (the knob that say low med. extra lg. ect) controls the water level, it probably isnt the trouble, but i suspect that the water valve (where the hoses attach)is sticking open to determine this,when it does flood unplug the machine if it continues to fill while unplugged the valve indeed is sticking
Jul 20, 2011 | Admiral Washing Machines
Have just purchased a F&P Intuitive Fabric Sensitive washer and the water wont stop when filling the machine up ? This is a second hand machine so have no book.
Hi just read your posting.Now are you using the auto filling mode or the traditional water level mode eg-- low med or high?Has your machine got an led screen?If so go to the options section and you can select water level, traditional wash,and water temp.Please reply on how you got on or for further assistance. Looking forward to your reply.
May 21, 2011 | Fisher and Paykel Washing Machines
Leaking water while washing but not by every load,please help
Are you putting clothes in first or as you fill the machine??? This is a normal capacity washer, so you need to be sure to fill with clothes first, I believe this will cure it. If that isn't your trouble, you may have a level switch that isn't working correctly. That would be easy enough to fix. Check on High, Med and Low levels and see how much water goes in, if it looks high on any of them, you can use that leveling screw on the level switch itself to regulate how high or low it goes. UNPLUG the machine when inside, so you don't shock yourself, Make your adjustment, then replug and try before you reassemble the machine. Unplug for that too, just to be safe. :) let me know how it works out for you
Jun 04, 2010 | Maytag LSE7806A Top Load Stacked...
Washer spin but water do not stay in drum
Sounds like your drain is laying on the floor, or your stand pipe is too low, or the drain hose is too far down in the stand pipe. The drain must be at least as hi as your water level in the machine at it's fullest level, otherwise it will just siphons out almost as quickly as it fills.
Hope that helps,
Good Luck.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
Maytag FAV6800AWW - Major overflow right after starting machine
Hi, If you turn the water source valve on and water starts filling the machine even tho the machine is off, change the inlet valve.
If you have to start the machine so water will fill but, the water does not shut off at the desired level, there is a problem with the water level switch.
I hope this helps you. Please let me know if I can assist you further.
Vic.
Jun 13, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Ge washing machine
does the cold and hot shut off at med. and high?it sounds like your cold water valve solinard is sticking and needs to be changed,(very easy fix,let me know more-mike
Oct 28, 2008 | GE WVSR1060A Top Load Washer
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
My Maytag Performa PAV 22300AWW washer works eratically at best. The washer keeps filling completely on any water level selection (mini-med-large-oversize) and now the agitator won't work. I'm thinking it...
there is a tube that connects to the water level switch (small med large ) load level, it connects to the outside tub of the washer, inspect it to makes sure that it does not have a hole or crack in it
are you gettting water into the machine woth the power cord unplugged then you have a water valve that is bad , if no water comes into the machine with it unplugged the water valve is ok
if the above two tests are negative then the water pressure switch is bad.
Apr 16, 2008 | Washing Machines
Water keeps going and going and going!
the water is draining back to the ocean. The drain hose was not emptied properly from its last use. Put the machine in spin cycle (about 5 minutes) only to spin out the water from the outer tub completely and retry washer. If still problem, then visual check drain hose that it still has a "rising" section higher in altitude than the water level of inner tub (when working properly) before it makes a U-turn downward to send back to the ocean. You can also test the drain hose by putting machine in fill mode and crimping off the hose (fold hose over) to simulate a good drain hose. At this test, you should not "feel" water running through the hose if successfully crimped.
Jun 21, 2007 | Estate TAWS800JQ Top Load Washer
Estate TAWS800JQ Top Load Washer Logo
148 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
