Question about Fisher and Paykel Dishwashers
DW60CSX1 Dishwasher will not power on? Have checked all connection including socket with no luck!
Dishwasher stops after filling with water
there is a problem with the drain. It is not draining all the water.
1. The drain hose could be too high.
2. There is a plugged pipe
3. There is debris in the drain hose or the pump
May 31, 2013 | Fisher and Paykel Dishwashers
How to reset error code on DW60csx1
It is likely the flood switch itself is faulty and may need to be replaced.
Apr 01, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
My diplomat dishwasher will not turn on. I changed the fuse in the plug and it still wont turn on. Theres no lights or anything, it has completely died
Try checking the power supply. It is possible that there is a fault in the socket. 1) Try plugging something else into the socket to check that it is working. or 2) plug your machine into a wander lead that it connected to another socket.
If still no joy, call in a repair man- good luck!
Jun 04, 2012 | Dishwashers
My dishwasher DW60CSX1 is approx 3-4 years old and is now not cleaning dishes. The tablet is often still in the bottom half dissolved and the dishes are dirty & wet. I've checked the filter, the arm...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 06, 2011 | Fisher and Paykel DD24DCFX6 Dishwasher
Old dishwasher had power, I connected a new dishwasher and it doesn't work. I double checked and made sure I turned the power back on at the breaker box.
Hello, have you tried plugging something into the socket the dishwasher is plugged into.
Hope this helps.
May 17, 2010 | Dishwashers
Fisher & Paykel Dishwasher DW60CSX1
I have a dishwasher - "Soft Touch" which seems to be stuck on F1. This occured in the middle of the night and although turning off at wall cannot get it off this setting
Jul 11, 2009 | Fisher Dishwashers
I have no power on my dishwasher. I ran an extension cord to another outlet that I know has power and still nothing. I don have any led lights or anything. Can you help. GE model # GHDA960K03BB. Thank...
Few components may cause power failure to your Dishwasher.
1. Disconnect your power plug from the socket outlet.
2. Trace the cord to where it connected to your dishwasher.
3. Tight those connectors firmly .
4. Plug back your dishwasher power cord .Start your dishwasher.
If nothing happen, check if control board came with fuse or bimetal. check the continuity of the fuse., You may also check your latch assembly.If no power still change the console or the control board.
Jul 26, 2008 | GE Dishwashers
No power
Check the wiring connection. The merrets can come loose and you then loose power. Turn off power first, if this is the case, make sure you tape them up.
Sgt 48
May 17, 2008 | Bosch 24 in. SHU53 Built-in Dishwasher
Dishwasher won't turn on
check socket in wall with another appliance.it could be the wall socket.also try a fuse that you know is working like one from your kettle.
Mar 01, 2008 | Maytag 24 in. MDB6600A Jetclean II...
Dishwashers Logo
115 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
