My television is a 15inch bush lcd tv and the screen has just gone dark its working but you cant see anything it is very dark what can i do to get it rectified
    Problem Solver:
  • 11 Answers
L.C.D ASSY PART DEF
Posted on Jun 13, 2008
Bush tv no colour, red has gone
T"Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2014 | Bush Industries IDLCD26TV16HD LCD TV
Bush IDLCD26TV16HD blue flashing light?
It is on protection mode due to some defects on the board. Switch off the TV manually, remove the plug and cool it off for 48 hours and retry. If nothing works, better refer it to a qualified service technician.
Jul 18, 2012 | Bush Industries IDLCD26TV16HD LCD TV
Polaroid TDX 01530B 15inch Black screen, no picture except POLAROID is visible briefly as TV fires up. Sound works.
The tv have a long board that call the LCD inverter board it is dead.This long LCD inverter board only job are to provided a backlight for the tv LCD screen panel to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish long LCD inverter board for the replacement.
May 13, 2011 | Polaroid TDX-01530B 15.4 in. LCD HDTV
Hi the tv started to go dark then it would be ok then dark and the same when dvds played do get sound now black screen nothing at all
Hmm
Looks like the back light or the driver circuit has failed.
If you shine a bright torch at the screen can you see a very faint image ?
If so then its the back light has gone.
If you cant see anything its the screen driver.
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Grundig GU19WDT 19 in. LCD TV
I have a LG 42LB5D 42" 1080 LCD television that
hi, usually you can correct this issue with only a few system checks, dark streaks can be caused by damaged pixels on the screen, in which case you need to replace the TV.
  • Inspect where the dark streaks are on the television. If the streaks occur at the same place on the top and bottom of the screen, they are due to the formatting of a movie or television show you are watching. This is normal. Also, if the streaks appear on the left and right of the screen, they are due to the show being filmed in full-screen instead of wide-screen. This also is normal.
  • Change the input setting so you are viewing the contents of a different device. If the dark streaks are gone, you know they are due to the device connected to it. However, if the dark streaks remains no matter what input the TV is connected to, the problem lies with the television.
  • Inspect the cable connection. Oftentimes when connecting a computer to an LCD TV, you can have strange dark streaks across the screen. Use a DVI-to-HDMI cable connection when plugging in your computer, then press the "Menu" button on your TV remote, select "Picture" and chose "Square Pixel." See whether the image adjusts and the dark streak goes away.
  • Contact the manufacturer of your LCD television if the dark streak remains. This streak can be caused by a defect in the television; if the TV is still under warranty, you can have it replaced.
  • Feb 02, 2011 | LG 42LB5D 42 in. LCD Television
    Samsung LCD TV Screen is very dark but still shows picture
    You either have a bad Power Supply or a bad Main bd. Worst case can be the inverters on the Panel have gone bad in which case the Panel needs to be replaced.
    Jul 06, 2009 | Televison & Video
    Bush 42" rear projection rp40tv sound but no pic
    any help please thanks tv turns on no problem but can not see any thing on screen. code comes up cant use menu do you no the code
    Dec 16, 2008 | Bush 5693D 24" TV
    Dark screen on bush lcd
    If this set is a LCD I would have the backlight circuit checked out by a tech. No user serviceable parts inside this set.
    Sep 02, 2006 | Bush DVD142RC 14 in. TV/DVD Combo
    Televison & Video Logo
    Top Televison & Video Experts
    Electro Med Services...
