Question about Salton Ice Cream Makers
I have a Salton Ice Cream Machine - Model IC4. I used it hard enough to wear the metal coating from the metal container. I quit using it and packed it away. Do they make container replacements or is it too old.
SOURCE: Salton ice cream maker manual
This website has dozens of manual for free download, including one for Saltons: http://www.pickyourown.org/icecreammakermanuals.htm
Posted on Mar 02, 2008
SOURCE: salton hand crank big chill ice cream maker
Put metal bucket in freezer day before.no plastic parts in freezer. Put back in place.Fill with mix 2/3 full. Let sit 10 min and then crank away till firm and hard to crank. Yum
Posted on Aug 03, 2008
cardmechanic
  • 9 Answers
SOURCE: denu ice cream maker manual
The manual can be found here:
http://deni.com/files/5201-5202-5203-5205-5210.pdf
Posted on Jan 15, 2009
ButtFuzz
  • 463 Answers
SOURCE: Salton Big Chill manual
http://www.pickyourown.org/icecream/Salton_Big_Chill_ice_cream_maker_ICM15_IB.pdf
Posted on Mar 08, 2009
ThaMp3Doctor
  • 8596 Answers
SOURCE: salton model GL14 Ice Cream machine
For all of the above, you will need to contact Salton directly, as they no logner post the info on their website:
3633 Flamingo Road
Miramar, Florida 33027
Phone 954.883.1000
Posted on Mar 20, 2009
My ice cream maker spins but not making icecream
* Ice cream makers are small tub partial filled with cream, sugar, and flavor.
* This cream tub is placed inside a larger bucket containing ice and salt (usually rock salt). The salt makes the melted water almost as cold as the ice. (colder than regular unsalted water)
* Creme in contact with the metal tub gets frozen and creates a layer of frozen creme around the tub.
* The frozen creme is soft due to the fat in the creme preventing the liquid from freezing hard.
* Scraping away the semi frozen cream allows more liquid cream to freeze on the cleaned sides of the inner tub.
* with continuous scraping the cream will form a semi frozen "Milkshake" like thick liquid. It will not harden as the large ice bucket would have melted all the ice by then.
* Remove the semi-frozen cream. Serve immediately or pack in container to continue freezing cream. It should harden when left over nite in freezer.
* Using bucket; https://www.youtube.com/watch?v=o_IFfVdOE2g
* Using bowl; https://www.youtube.com/watch?v=t7aUHywPnog
* Using Ziplock; https://www.youtube.com/watch?v=y-69y9GsS_4
* Enjoy!
Aloha, ukeboy57
Aug 28, 2018 | Ice Cream Makers
I need a manual for a Salton ice-cream maker model SIM 26
Are you sure of the model number? I just went to their website and did not find anything about ice-cream makers. Here is a list of all their model numbers. Nothing even close.
https://salton.com/instruction-books-manuals
Nov 16, 2017 | Salton Ice Cream Makers
Ice cream won't set up
The ice machine is a little more complicated then what it look like first you need to know if is any air filter. should be there, some where if no air filter do not try to fix the machine your self this type of equipment contains refrigerant and high voltage should be handle by an experienced certain devices hold electrical charges even unplug hope this is usefully.
qualified technician may little but could be dangerous
Aug 12, 2012 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Salton model GL14 Ice Cream machine
3633 Flamingo Road
Phone 954.883.1000
Jul 18, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Salton hand crank big chill ice cream maker
I bought one new, and it had a great recipe for Kiwi fruit ice cream, using kiwi fruit and oranges. I can't find the recipe book. You make just over 1 l of fluid ice cream mixture, the bowl must be pre=frozen for at least 15 hours, just put the liquid in the machine and crank the handle in quarter turns (the square outer box helps measure this!) every 5 min for the first 30 min, and then half turns every half hour or so.
Jul 06, 2008 | Salton ICM15 BIG CHILL 1.5 Quart Ice Cream...
I downloaded a manual for the ICM21, same picture as yours, today, August 2009, from kitchen.manualsonline.com
Click on frozen dessert maker under Member Contributed Manuals.
Click on Salton frozen dessert maker
Scroll down to Comments, get this manual
Click on instructions
Salton ice cream maker pdf
The one there is for the old ICM21 ice cream maker.
Jan 16, 2008 | Salton ICM-21 1.5 Quart Ice Cream Maker
Ice Cream Makers Logo
324 people viewed this question
Top Salton Ice Cream Makers Experts
Don Eagan
Tom Chichester
Terry
Terry
Are you a Salton Ice Cream Maker Expert? Answer questions, earn points and help others
