Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I have a 250 gb simpletech external hard drive. no. 96200-41001-077. I have used it as the time machine backup on my MacBook. It stopped backing up time machine recently. I got the message. Backup failed when I looked at the application. Then I would get the message that my simpletech needed to be reformatted. Now its icon does not even show up on the desktop or finder when I plug it in to the USB port. Did it die? Can it be saved? (Other things work on that USB port so it is not the port.)
    Brigadier General:
  • 10,406 Answers
> icon does not show up on the desktop or finder
A major "clue" that one component of the external storage device has failed, namely:
* USB cable (try a different one)
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure
* optionally, the external power-supply that connects to the enclosure
Use a multi-meter to verify the voltage/amperage output of that power-supply.
(Not all external storage devices need such a power-supply.)
> can it be saved?
Partially. Disassemble the enclosure, and remove the disk-drive.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage-device. (Compare it to a heart-transplant -- same body, new heart.)
Posted on Nov 04, 2010
SimpleTech 250 gig external drive not recognized on MacBook
It could be formatted in a different manner. See if it is detected by your mac. Go to Applications/Utilities/Disk Utility and see if your hard drive is shown there. If it is, then the formatting of your hard drive is not compatible and you will need to reformat to be able to use it on a mac.
Nov 02, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 250 GB External Harddrive won't backup 180GB . Says it is full.
click start control panel administrative tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start
you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
I found that you get best results by ticking one box then returning after it has finished then tick the other box
then you restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
hope this helps
Jul 08, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
Not enough memory to run time machine
If you do not have enough hard drive space to perform a time machine backup then you will need to either get a bigger external hard drive or delete files that you do not need.
Feb 29, 2012 | SimpleTech 250GB USB2.0 7200 RPM External...
How do you use the simpletech 160 gb ext drive with a macbook pro or a macbook
Your external HDD must be MAC OS compatible.
I've it is compatible, just plug it in and it should pop-up
Jun 08, 2011 | SimpleTech SimpleDrive 160 GB External USB...
I backed up my entire computer on my SimpleTech Pinin Farina external hard drive and now I can't figure out how to find a file on it that I need. I see all the backup files, but I can't figure out how to...
Backup software compresses the files and encodes them to an image file made up of a series of sequenced files. The same software you used to do the backup should have the restore options needed to locate desired files. SimpleTech website shows Fabrik to be the name of the backup software.
If you utilized, there's also an online backup site used to store files. Following link is the users guide:
http://www.simpletech.com/support/guides/user-guides/60000-00168-001.pdf
Oct 22, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
No software or instructions
simpletech is a plug and play device compatible with vista and xp. you dont need a software to use it unless you wanted to access the quick backup button function when you press the simpletech logo. software is available at their support website: www.simpletech.com/support/
Jul 16, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Reformatted without downloading software to my desktop
robilynn -
Here is the driver page, you'll have to get the model number off of the drive to download the proper one:
http://www.simpletech.com/support/support_downloads.php
Here is the page for the manuals (top of the page), just choose Pro or Duo pro for whichever is the drive you have:
http://www.simpletech.com/support/guides.php
That should give you everything you need to get it back up and running.
Michael
Jul 04, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
I accidently delete my backup software
I have been using Easy Recovery Professional for a while now and I have no complaints as to what it is capable of doing, you can download it at http://download.cnet.com/EasyRecovery-Professional/3000-2242_4-37386.html?tag=mncol OR you could simply download the Backup software at http://www.simpletech.com/support/support_downloads_storagesync1.42.php
Jun 18, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Simpletech 320 GB
my advice to you is open it and unplug the one touch button.
Jan 11, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Restoring backup files
well first off you should not use teh same external hard drive for both dell and mac! and for it to work on a dell you need to go to disc utility in the applications folder and click on you external hard drive and go to the last pannel which is called restore and put in the given info and it shall work!
Jan 04, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
403 people viewed this question
Top SimpleTech Computers & Internet Experts
Marvin
Marvin
Phil Whisenant
Phil Whisenant
Steve Allison
Steve Allison
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
