Question about Canon Cameras
I have a Canon Powershot G7 digital camera which is 18 months old. It was working fine until last week and now it won't start and i have no idea what it could be. Any advice?
  • 130 Answers
SOURCE: CF Card Error
Well there is a known problem witht eh CF memory design, i hope this is not your problem but it may be. Take your camera into a well lit area or get a small flash light. Open the memory door and peek down inside the camera and look at the pins inside the camera. Are they all uniform? does any look bent or out of place? there should be 2 uniform rows no pins should be missing or out of place. If they are you have a connection problem. This is one of the issues with this memory format and its why they have changed the design to SD. This is common with people who remove the cards alot and use a reader over time the card and the slot becomes warn and its very easy to bend pins because the card isnt sliding in smooth. If this is your problem (a few bent pins) you may have to take it in for service or try and fix it yourself. Ive read about people using a mechanical pencil. Remove the lead and the pin slips right into the top and you can carefuly move it back. Hope this helps!
Posted on Mar 30, 2006
SOURCE: Canon Powershot A75 problems
Having read on a few sites about loose ribbon wires causing problems and having this same problem. I decide to take the camera apart. Taking all the screws out and fidling with the "wires" connecting the zoom control and the photo type selector and the main circ board. I also cleaned the connector from the picture type selector. Then put it all back together the camera works fine again. NOTES... lots of small screws with varying lengths make sure you know where they come from. Took about 1 hour to do.Put back in the order you take apart or the back will not go back on.. Good luck have just saved myself a fortune
Posted on Feb 04, 2007
poolseman
  • 206 Answers
SOURCE: Blank black screen for my canon powershot S1 IS digital camera
This is a common problem with S1 IS and it is caused by faulty CCD sensor. Note that you can playback captured images without any problem but in capture mode all you get is blank screen. Will have to go to Canon but note that Canon repairs these models free of charge when it is the CCD sensor that stops working.
Posted on Sep 14, 2007
SOURCE: Canon Powershot G7 digital camera
A friend suggested I uninstall the digital camera solution disk and then reinstall it. I did so and although my computer seemed to crash once it was restarted after turning it off and back on and getting a blue screen from microsoft stating I had to start it manually everything worked out. I am so thankful. I got about 100 pictures downloaded and stored into the appropriate album. Thank you for your concern.
Posted on Jul 11, 2008
namzyanzy
  • 435 Answers
SOURCE: i need to find user manual for canon powershot A710 IS digital camera
Please click this link to visit the manual download page of your camera:
Canon PowerShot A710 IS Manuals
Thank you
Posted on Jan 07, 2009
How do i fix a canon powershot G7 camera
Check with the Connectors, and upgrade to the latest firmware by placing it to a working unit.
Feb 18, 2015 | Canon PowerShot G7 Digital Camera
Cannot turn on the camera even change a fully charged battery or through USB cable
Its not a problem with the battery, the G7 and the G9 have a problem where a loose screw inside the camera shorts it out and causes it to not power. The repair service is about $85 total for a new part, installation and return shipping of the camera!
Thomas Drayton
Owner www DarnToothySam com
Affordable Digital Camera Repair
Jul 26, 2011 | Canon PowerShot G7 Digital Camera
When I try to download photos from the Canon G7 to a Mac I get the "communications error" message.
Having gone two months without a response to my query, I assume my suggestion to use a card reader solved the problem.
Jun 09, 2011 | Canon PowerShot G7 Digital Camera
I took a picture with my Camera shut it off went to go use it again and it won't turn on. I've charged the battery and it still won't work. Any ideas what's going on. Thanks Jamie
Thomas Drayton
May 14, 2011 | Canon PowerShot G7 Digital Camera
Hi, could you tell me where the shutter timer is on the Canon Powershot G7? John
Press down-arrow on the cursor pad (marked with a one-handed clock). Use up/down to select the delay. Start the self-timer by pressing the shutter release button.
Jul 10, 2009 | Canon PowerShot G7 Digital Camera
There is a noise inside the camera. Kind of like the sound when you focus, but continuous whether or not you are focusing. Just started this morning. Camera has not been dropped or anywhere weird. It's...
G7 and G9 have a common problem: loose screws short the circuit boards. So if it’s possible, return it. But if you really like to keep it, open the camera and make sure the screws are secured. See here for more details:
Canon G7 won’t power on
Who killed my G9?
Jul 05, 2009 | Canon PowerShot G7 Digital Camera
Canon Powershot G7 just wont turn on... for no reason I can tell.
Usually you can't hear the loose screws in these when they fall out and short out the camera, although many people will say you can. When you have no power on a G7 or a G9, it is most always that loose screw problem. The screws inside should be corrected at the time of the repair so the problem doesn't happen again later. The site that is great for help with the Canon Powershot Camera problems is: www.camerasandparts.com They are great with these and that is all they specialize in. I would see if they can help, they're amazing if you need a hand with the Powershots, plus they do that no power correction on all G7 and G9's they service which I like. Good luck with it
May 17, 2009 | Canon PowerShot G7 Digital Camera
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Cameras Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
