Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Hello My washer won't go into the rinse cycle, so all of my clothing is sitting in a "super plus" sized load of water. Any ideas as to what the problem is? I've tried going to each of the cycle settings and the rince does not work on any of them. I have also unplugged the aground from the outlet and then plugged it back in, still nothing.
  • Whirlpool Master
  • 2,699 Answers
Sounds like the lid switch is broken,open and close the lid a few times,if you don't hear a clicking sound when the lid closes then the lid switch is broke,you can try sticking a pen or a butter knife in the hole and see if you can get the water out,the part number is 8054980 and it's around 25 bucks,let me know if this is the problem and i'll tell you how to fix it
Posted on Nov 03, 2010
  • 4 more comments
  • nathaniel_fi Nov 03, 2010
    Sadly that doesnt seem to be the problem Salde. Everything else works exept for the spin cycle. I drained the water out manually only because it still won't automatically drain either. Any other suggestions Salde?
  • Sal De Nov 04, 2010
    ok if the lid switch is ok then most likely the motor coupling is broke,remove the two phillips screws that are on the end of the top console,they might be in the rear,i don't know why the life of me they put the screws in the rear of the console,then flip the console up,you'll see two metal clips and in the middle of them the lid switch harness,unplug the harness and with a screw driver pop the clips,just stick the screw driver in the hole and on the top of the clip and push back towards the wall and the clips will pop out,now open the lid,grab the frame and tilt it back to you and up and remove the frame of the washer,down at the bottom pop the water pump clips and slide the pump off,then remove the two screws,pop the clips and slide the motor out and you'll see the coupling on the back of the motor.this is a common problem,just remember how it comes undone because you have to put it back together the part number for the coupling is 285753A and it's around 20 bucks and should take you around 1 hour to repair it.let me know how you make out,one more thing,on the corners of the motor there are rubber spacers,if they are missing look for them on the frame and stick them back on the motor because you'll never get it back together if you don't,tap on the new coupling on the motor and the tranny shaft and slide the middle rubber piece onto the tranny,then slide the motor into the rubber piece
    one more thing,if you think it's the timer,there are points inside it that can get stuck,try tapping around the timer on the console and see if that will advance it,if it does start spinning then you have a bad timer ,also when in spin if it's the coupling the motor will run but no drain and spin,i don't want you to pull it apart and it's not the coupling
    nathaniel,one more thing,is there any sound at all?you could have something stuck in the pump,let me know,i'd hate for you to pull the motor out if it's not the coupling,like i said if the motor runs and nothing else is happening then it's the coupling
  • nathaniel_fi Nov 04, 2010
    thank you very much Salde. I am actually heading over to the laundrymat right now, but I will Definitly let you know how everything goes later on tonight.
  • Sal De Nov 11, 2010
    when washers go into the final rinse cycle the machine just calls for cold water so the clothes don't wrinkle as much,check to see if you have cold water coming into the washer,also there's a motor coupling that breaks on whirlpool washers if the motor is running but the washer isn't spinning check the coupling on the back of the motor,let me know what you find or how you made out with the machine,also the timer could be bad,if you advance it by hand past that point does it run?
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
I have a Maytag Centennial washer, model number MVWC6ESWW, when I start the machine, it immediately starts agitating and adding water simeltaneously. At the end of the cycle, the clothes are soaking wet,...
I had the same issue. When I started the machine it began agitating and then began to fill as if it is beginning the second rinse cycle - well I think it was.... SO, I threw in some towels and began the cycle at the second rinse part of the cycle. Low and behold, the next load started and finished just fine.
I hope this helps. This is just one of many issues with this machine, but luckily I haven't had to call the repairman yet! They all seem to revolve around the thing being out of sync.
May 01, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Lg front load washing machine does not seem to get the clothes clean. I think it is because it uses so little water??? How can it get clothes clean with just a few cupfulls of water? All controls and...
I have run into this problem several times with LG washers. On one job LG had us replace every electronic componet that had anything to do with the water fill and the problem still was not resolved. The electronic control determines how much water to fill depending on the load size, so smaller loads give you less water, with the same amount of soap. Leaving clothes in the washer overnight, and leaving the door closed does contribute to mold and fungi growth in the washer. The customer tried different brands of soaps and different amounts of soap. He left the door open after usage to allow the unit to dry out, and tried different cleaners, to clean out the sludge build up. We determined that there just is not enough water to thoroughly clean the clothes. The sales store had to replace the washer with another brand. There is an ongoing class action lawsuit against Lg for this problem. Do an online Search for lg washer lawsuit. By the way, we don't have a problem with clothes not getting clean with the Whirlpool Super Capacity Duet Front-Loading Washers. Good Luck, Appliance Specialists
Jan 04, 2010 | LG WM1812C Front Load Washer
Load size, spin cycle, and other cycles do not work properly
error code f 06 keeps coming up and we cannnot afford to have it serviced at this time we were told it had something to do with the control panel
Mar 22, 2009 | GE Profile WPSR3100W
Smell in washer
Vinegar will fix this! Try pouring a quart of white vinegar into the washer, then run a cycle with no clothing in the washer. When the rinse cycle begins, stop the washer. Let it sit for about 30 minutes, then complete the cycle. That should do it! Afterwards, be sure to leave the door open to air dry it.
Oct 27, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Washer Not Completely Rinsing
If your washer has an extra rinse button try pushing it. My Maytag refuses to wash unless that button is pushed, so in your case it may not be completing the rinse cycle correctly.
Just a suggestion.
Jan 03, 2008 | Hotpoint Aquarius WF000 Front Load Washer
AMANA DISTINCTIONS FABRIC CONDITIONER RELEASE
Hello Daddy 2,
Welcome to fixya
I'm Huuum and happy to assist you,
What is the model number and the year of the washer?
Front load or top?
A waiting your response!
Huuum
Dec 10, 2007 | Amana 3.2 cu. ft. Top-Load Washer
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
165 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
