Question about Haier 32 in. LCD TV
I don't have the programming code for my remote ONE FOR ALL , COARC05C, R31971, 3005CX. would you happen to have the codes.
Remote codes
You have this backwards. The codes are in the remote. If you are using a Cyberhome remote with your Cyberhome DVD recorder, it should work.
Oct 27, 2013 | Cyberhome DVR 1600 DVD Recorder
My dish remote does not work on my new RCA tv. How do I fix that?
Hey Vernon Long,
We would have to program your remote to your RCA TV. I have provided the steps to program the remote below along with a few codes to try. You can view the link provided for more codes if the ones I list don't work!
Link: http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx
Codes: 502, 646, 633
Addressing Remote to TV:
1.) Press and hold the clear TV button until all mode lights light up.
2.) Release and TV light will be blinking.
3.) Enter code and press #. The TV button should flash 3 times.
4.) Try functions (Volume, Power, etc..) and see if working.
5.) If no function, repeat steps 1-4 with another code.
Our remotes aren't guaranteed to work all types of equipment, but if the codes don't work let me know here and I will try some more steps with you!
Tommy Faust
DISH Network
Nov 05, 2011 | DISH Network IR Remote Control
Remote stopped working. How does one reset the remote?
Programming a code into a remote mode:
  1. Turn on the component to be programmed, then press the corresponding MODE button on the remote control. (TV, VCR, AUX, CABLE, ETC)
  2. Press the MENU and MUTE buttons simultaneously for 2 seconds, the button selected component lights on the remote control. If you don't press any button for 20 seconds, the button selected component will turn off on the remote control.
  3. Enter a code number using the number buttons on the remote. When pressing the button, the light is blinked at a time. Programming codes for the corresponding component can be found on the following website. Again, if the code is correct, the device will turn off.
  4. Press the MENU button to store the code. After blinking twice, this code is stored.
Jul 18, 2011 | LG 42LC2D 42 in. LCD HDTV
I bought a new TV and need to program my Dish network remote control
Hey scrappy32847,
Congrats on the new TV! I can definitely assist you with this and get it taken care of. As I don't know what TV you have I don't have any codes off hand available.
You can check out this link: http://www.dishnetwork.com/SupportSection/remote-setup to get the codes to program your remote. I have also listed the steps below to program that remote to your new TV.
If you need any additional assistance you can reach me here or at thomas.faust@dishnetwork.com
Tommy Faust
DISH Network
Jun 24, 2011 | DISH Network IR Remote Control
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
I have a quantum fx REM-100 remote control and i need the codes for a quasar tv
I bought a Quantum Fx (REM-102) TV remote control for VIZIO TV but the remote control don't response
I did intent some codes to control programming but don
Apr 24, 2009 | GE JASRM24912 Remote Control
Need codes
If you don´t get any help, ask here. They are specialists in finding remote codes. Send them the model # of remote and TV or DVD Player you want to control.
Jan 19, 2009 | RCA Universal Remote Control
Jizzz i´m desperate!!!!
jenson 300 series Sony tv codes 497,491,475,459,406 or the code you have
hold the program or setup button untill it blinks. select the tv function and enter the code you have or one i listed above then enter
Or if your remote is this 300c series your code would be 0000
you would press down and release the device"mode key"tv,vcr,ect
the red light will blink once.press and hold down the setup key untill red light blinks twice then release.enter the code the led light will blink once on each digit execpt the last one will blink twice to confirm valid code ****mode 1 is for the tv on this remote.
hope this helps
Mar 18, 2008 | Jensen JER-323 Remote Control
I lost the instruccions, I know my Tv code for it, but I don´t know the steps..
these claim to be the instructions - sorry no luck with a manual 1. Turn on the component 2. Press and hold the component key (TV, DVD, VCR-AUX, SAT-CBL) The illuminated on-off key turns on and stays on 3. While holding the component key down, press and hold the ON-OFF key. The illuminated ON-OFF key turns off. 4. After holding down both keys for three seconds, the illuminated ON-OFF key turns back on. 5. Release both keys. The illuminated ON-OFF key remains on 6. Press and release the ON-OFF key repeatedly until your component turns off. Wait four seconds between each keypress. Each time you press the ON-OFF key, the illuminated ON-OFF key blinks, and the next code in the list is sent. This process continues until all of the codes in the code lists have been searched. If your component turns off, you have found the correct code. (If it cycles through and the illuminated ON-OFF key blinks four times and turns off, all codes have been search. The manual code search method is exited.) 7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON-OFF key turns off. You must press the STOP key to save the code or the correct code will not be saved. 8. To confirm that the component is programmed with the correct code for max functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your component do not work try programming the remote with a different programming method. Be sure to retrieve the code your remote programmed. here's the link there might be other useful info http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?7713 Hope this helps :)
Jan 12, 2007 | Jensen JER-422 Universal Remote Control
Haier  32 in. LCD TV Logo
229 people viewed this question
Top Haier Televison & Video Experts
Jaime Hernandez
CoppellTVRepair.com
Are you a Haier Televison and Video Expert? Answer questions, earn points and help others
