Question about Brother IntelliFAX 4100e All-In-One Laser Printer
How do I receive the total page count on the Brother IntelliFax 4100?
JayBlair
  • 328 Answers
SOURCE: can not receive faxes or blank pages com thru!
Can you make a copy and get a good print? Does the blank pages come from different people? If you still get a blank from making a copy, then try a different toner and or drum unit. Hopefully it is still under warranty.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Posted on Aug 01, 2007
Guru Guy
  • 95 Answers
SOURCE: Laser Fax Brother IntelliFax 4100
Purchase a flash card for the fax machine. Contact your dealer to assist you with this. It installs in the back of the machine under a little panel marked as such.
Posted on Nov 17, 2007
marsrover
  • 682 Answers
SOURCE: Brother Intellifax 4100
1-pull the paper cassette out-fan the paper and adjust the cassette to the proper size of the paper.2-after you remove the cassette from the machine have a look in cassette bay with help of any light source and cofirm there is no foreign object stuck inside(pieces of paper-pins etc-after that if the problem exist apply a spray from contact cleanr with it is tube inside the bay of cassette in direction of machine rear frame.and insert the cassetee firmly many times to activate cassette switches.
Posted on Mar 03, 2008
SOURCE: brother intellifax 4100 clicks during receive
Our tech told us that any cartridge from Office Depot will make it click and have problems. We changed back to a Brother cartridge and it works fine!!
Posted on May 29, 2008
  • 159 Answers
SOURCE: Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
Posted on Jun 11, 2009
I have a brother intelliFax 4100. I cannot receive fax.
While it is ringing press the START button. You are set to MANUAL RECEIVE
Feb 08, 2010 | Office Equipment & Supplies
When sending a fax on our Brother Fax-4100 the person on receiving end of the fax says it comes across totally black What is the problem??
If you make a copie. on your fax.
That is the same quality that you are sending over the phone line.
If the copie is total black
lift the document feeder see if there is anything on your optical glass.
But my experience tells me that the lamp has gone out also know en as the scanner asm.
let us know what hapens
Apr 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Total pages printed?
yes only if you go to test mode or maintenace mode.
Menu,*,2,8,6,4 within 2 seconds. and then choose 70 or 77 it will give you a print out with all info.
99 to get out of maintenance.
good luck
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother intellifax 4100
Have you tried a new toner cartridge?
Oct 27, 2008 | Brother IntelliFAX 4100 Laser Fax
Fax machine not receiving
David Powell Loves Katie Stone!
Oct 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Change my Carrtidge
I THINK IT SAID YOU HAVE A BROTHER 4100 IF SO YOU NEED TO RESET THE DRUM COUNT BY LEAVING THE THE FRONT DOOR OPEN AND HITTING THE CLEAR KEY AND THEN THE # 1 KEY
Oct 18, 2007 | Brother IntelliFAX 4100 Laser Fax
Brother IntelliFAX 4100e All-In-One Laser Printer Logo
900 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
