Question about Samsung Refrigerators
One of the fans in the frig is making a noise- it stops when you open the door. the icon to the left of the temperature - looks like a filter ? with a drop of water coming down is lit and purple.
  • nedselfe Nov 04, 2010
    thanks for the suggestions - guess it's time to crack the thing open and see what's going on.....
  • 4,070 Answers
The fan in the freezer could be hitting built up ice if the defrost system isn't working properly. Either fan will make noise if it's going bad. The fan cuts off because the door is open. You can hold the door switch down to keep it running so you can tell why it's making the noise. Remove the cover on the back of the side that's making the noise. It should spin freely when you spin it.
The purple lit filter is telling you it's probably time to change the filter. If you need more help with that you can look in the manual or post your model number and I'll try to find diagrams for you.
Posted on Nov 03, 2010
Suddenly making noise from above the refrigerator behind the vent
Almost certainly there is an ice build up which has eventually migrated to the fan blade. Do a 12 hour defrost to ensure a proper "defrost", then try again. Very possible the door was left open slightly by accident.
Jun 08, 2010 | Sub-Zero 695/O Side by Side Refrigerator
Frig is driving me crazy---weird noise and no ice!!
That might be the fan. Making that noise, because fan stops when you open the freezer. The ice maker might be a totally diffrent problem. The solenoid may not be opening to let the water in, which is usually cause by a bad solenoid.
Nov 28, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Refrigerator side makes noise, not getting cold
I have same fridge freezer & luckily a extended warranty, engineer has been out on numerous occasions & the motor is getting freezed up, which is why the noise stops when the door is opened. Get rid of it! No solution to the problem...its a faulty appliance & a well known fault with this model or so I have been told. Good luck.
Aug 26, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Frig has stopped making ice.
Open the left door open the ice maker door, up in the left hand corner you should see a green light, check to make sure that you have a selection chosen(either small of large cubes.
Jul 15, 2009 | LG LFX25960ST Stainless Steel French Door...
Freezer frost buildup; fan constantly running; water filter
Just had mine repaired. Tech told me that the tempearature settings on the display panel are not EXACT science. The fridge is cooled by blowing air from the freezer to the fridge and when the sensor in fridge reached approx desired temperature, the damper is closed.
The noise you hear periodically (water dripping) is the heating rod melting the defroster (hence frost freeze), which unfortunately sometimes spills into the blower motor to fridge, causing frozen motor, causing the infamous ER FF error code and fridge failure.
I reluctantly had LG to do the energy saver fix (recall) and it replace everything that the internet users are complaining about.
Jun 27, 2009 | LG LRFD22850ST French Door 22.4 Cu. Ft....
GE Profile making knocking noises at different times
I have the GE profile Refrigerator with ice maker in the refrigerator compartment. Mine was knocking loudly for long periods of time, so I finally removed the icemaker by removing the side panel in the icemaker compartment held with 1 phillips head screw, disconnecting the electrical plug (unclip), pulling the tab of the icemaker down (on top) and sliding it toward the door, thus removing it. There was ice frozen in the motor compartment that was the problem. I let it thaw out and re-installed. All was OK after that..
Jun 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Aug 29, 2008 | Zanussi ZI921 / 8FF Bottom Freezer...
LG LRFC25750 Refrigerator French Door
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
340 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
