Question about Apex Digital AD-1110W DVD Player
Found burned capacitor, can't find a way to get part number, number on capacitor is (8.0/4.0). Is there a common fix?
I found two bulging capacitors on the PS board: 1000uF and 470uF. Also found chemical residue on the inside of the case just above the two capacitors. I replaced both and now it works.
Posted on Dec 30, 2010
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Cook temp not working
follow this steps and test with VOM. God bless you
Diode
The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven. A regular meter with a diode checker will not work to check these diodes. You have to use a meter with a 9 volt battery or put a 9 volt battery in series with the diode to check it.
Enter your model number to see parts for your microwave.
Help me find my model number
Door Switch
If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron
If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor
If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer
If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food. When a high voltage transformer fails it will usually arch and have a burning smell.
Thermal Fuse
If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector
If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magn
Apr 02, 2013 | Maytag MMV4184A 1000 Watts Microwave Oven
Morphy richards oven is not heating and not cooking anything
please proceed according and fix it. God bless you
Diode
Door Switch
Magnetron
Thermal Fuse
Thermoprotector
Main Control Board
If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually a faulty door switch or within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Mar 01, 2013 | Morphy Richards Microwave Ovens
I have a hayward super ii pump model sp1615z1 that wont start I replace the capacitor because it wasn't working when the timer turn it on.After replacing the capacitor the pump worked fine for a...
There is no cheap fix for a burned up motor...you'll need to replace it. You can replace just the motor for about half the cost of a whole new unit. When you replace the motor you should replace the pump seal as well. Your motor number should be UST1152 for the 1.5 HP and the seal number a 201.
John
Jun 27, 2011 | Hayward SP3015EEAZ Super II Pump 15Horse...
SONY KDF70XBR950 DLP TV 6 Blinks. Is it on the G1 Board? and does anyone know the fix? Thank You.
First double-check all your connections and wiring. Make sure there is nothing looose or broken. The capacitors also could be swoolen and burned out. You can test with capacitor tester. Thermal fuse or flyback is also possible and common causes. Lamp burn out? Do you have power to the bulb socket? Power to ballast that bulb attaches to? Last solution wold be to replace the board
Oct 27, 2009 | Sony Televison & Video
Whirlpool Ultimate Care II washer went dead during fill cycle
Start with the capacitor. It has a funny smell when they go bad. The motor will smell bad as well when it burns up.
May 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Samsung HL-S6187W 61 in. HDTV black screen on the right side
If you found a bloated capacitor on the circuit board, that one needs to be replaced not the board. You can see the part number on the capacitor itself. Also please look for any burned IC and neighboring components. If you found additional burned components, it also need to be replace. Contact a pro tv technician to replace it.
Order parts here:
http://www.partstore.com/Sitemap/Generic/Television+parts/Television/Television+parts/television+parts.aspx
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
RCA D52W19BYX1
If yu can email me a location number for the capacitor and I will look up the part number for you.
tvtek (@) msn.com
Jun 24, 2008 | RCA D52W19 52" Rear Projection Television
MV-1610 Runs but doesn't heat
That wouldn't be a resistor on the capacitor, it would be the high voltage rectifier diode.
It should read open on a continuity check. A shorted high voltage diode is a fairly common cause of a no-heat condition.
For testing, see: http://www.gallawa.com/microtech/diode.html
To order the part, and for other Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit http://www.lgservice.com.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 22, 2008 | Goldstar MV-1615 Microwave Oven
Sylvania 6842pf m after i power on inmedialty power off (stamby)
These sets are manufactured by Funai, in my opinion total junk, yet they command a $1,500 price tag. I cannot find parts available for this hunk of **** anywhere so if this tip helps you fix this set and get it out of your hair, God Bless You! Model number is followed by an M to read: 6842PF M Found no VSUS on connector CN2502 of the SMPS. VSUS was shorted to adjacent GND pin by 120 Ohms. Small high voltage blue capacitor C2250 (Between Two very big electrolytics and right next VSUS diode D2250 (TO-220 package) on aluminum heatsink) shorted, burned. I have two of these sets in the shop at the same time, both of them have the very same problem, appears to be common and parts seem to be NLA for this unit. Replace C2250, 1,500 pF @ 1Kv. Usually marked as 152K on small high voltage capacitors in junk units. This is not a common value part so if you have to, make one by parallelling a .001 uF cap (102) with a 470 pF cap (471) to get a suitable 1,470 pF capacitor at 1 Kv. Adjust VSUS with VR2250 on SMPS board to read 175 VDC to GND and you are done. You're welcome. ~Ohmster
Apr 28, 2008 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Apex Digital AD-1110W DVD Player Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
robert landry
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
