Everything is fine until it gets to the spin cycle, then it wont drain
The pump is probably bad it should be pumping the Water out of the tub and into the drain line if this is not happening then the pump is bad the pump is usually on the bottom of the washer just follow the drain line I believe three screws and a belt adjustment and with basic mechaical skills u can replace it your self
Posted on Nov 03, 2010
My Kenmore washer drains after the rinse cycle but won't spin at the end of it's cycle. If I manually set it to the spin cycle, it spins just fine. Desperate!!! The lid switch was just replaced about
Possible there is problem with the timer controller unit. It seems that the stepper motor is not moving to the next cycle until you manually move it to the spin. You can use some contact cleaners on the switch and also carefully try to see if the timer moves within , replacement is a costly issue and must be debated
Nov 20, 2013 | Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Washer wont spin or drain
did you check to see if there was anything stuck in the pump? sometimes socks and other small articles get dow there and wont allow the washer to spin or drain
Feb 07, 2009 | Frigidaire Washing Machines
When I try to use my cold cycle on the washer it wont work.
Dear Customer
Please perform the following checks
check the lid switch if the switch is broken the washer will agitate but wont drain or spin
Plaese rate this,Thank u
Dec 17, 2008 | Roper RAS8445KQ Top Load Washer
Washer will not pass wash cycle...Will not Drain
Nightshade, in most cases, no spin, no drain is a lid switch problem. If you advance the timer to the spin position does it spin? If the machine is agitating you can rule out the coupler. If you are sure that it is not a lid switch problem, then you are probably looking at a bad timer....Catriver..post back.
Nov 08, 2006 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
