Question about Beam Industries 2775 Serenity Plus Central System Vacuum
The system was turned on manually to vaccum out the car and now the only way to turn it off is to unplug it (i.e. pressing the switch on the vaccum canister to auto from manual does not turn it off). Bad switch?
    Novelist:
  • 147 Answers
It is possible that it is a bad switch/circuit board on the unit. If your unit is less than 7 years old that should also be covered by warranty (manufacturer) however an in home service, should you require someone to come to the house will not be covered.
Posted on Nov 03, 2010
  • Beamvacman Apr 15, 2011
    disconnect the wires going into the house ,this will isolate the problem ,its possible a person flipped the vacpan on with their foot while you were vacuuming manually ,I have seen it.
Power head motor dose not operate when switch on handle of vaccum
Its possible if the head is belt driven that it has clogged with fibres or could even have snapped. Unplug the vac, turn it over and have a look, you may need to remove a cover plate first.
Oct 20, 2014 | Vacuums
Power switch won't turn off
try taking it apart and spraying it with WD40
Here is how the switch assembly should go together:
Feb 13, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Wont turn on
It sounds like the switch had disconnected its a easy fix just remove the screws in the handle around the switch and simply reconnect the wires to the switch. Be sure you unplug you vacuum before you work on it
Jan 17, 2014 | Oreck UPR014T XL Pro 14 Upright Vaccum...
When the switch is turned on the vaccum cleaner starts running instead of,when the hose is connected. removed the earth lines from the unit and truned on the vaccum cleaner. It did the same. What might...
Dirty switch at vac where hose connects go to radio shack get some tuner cleaner spray. spray this switch and plug hose in and out a few times spray again see if this works
Feb 26, 2011 | Broan-NuTone CV554 Cyclonic Bagless...
When you plug in the vaccum it sparks from the outlet
If it trips the breaker, you have a short somewhere from the cord to the motor. If not, be sure to wait until it's plugged in before you turn the switch on. Turn it off before you unplug it.
Dec 30, 2010 | Electrolux Vacuums
My vaccum cleaner will not turn on...i checked the outlet and it works but no power to my vaccum
Some vacuums have a resettable circuit breaker in case of overload or switch in case of blockage. Both are usually a pushbutton type thing (like on a powerstrip). Find it, reset by pushing, and run the motor. Check for obstructions and for anything that could be preventing the brush-roller from turning. If the breaker or switch trips again there is a problem that needs to be resolved.
The manual might be helpful.
Oct 08, 2010 | Vacuums
Was vaccuming and vaccum quit. Tried unplugging and turning back on. Getting absolutely no power. unscrewed screw under handle and tried to make sure connection was being made. Don't really know what to...
ok..If you have a multimeter you can check plug fuse then switch and motor, if you put leads across the plug you will get some reading if its working.could be thermal cut out on the motor.
Apr 18, 2010 | Kenmore Magic Blue 24195 Bagged Canister...
Bissell vaccum cleaner just turned off why
Ive had this problem before. I have never figured out what caused it. I let it be for a few minutes and it started working again.. weird.. I'd just let it sit for a few then try it again.
Mar 02, 2010 | Bissell 6594 PowerForce Bagless Upright...
The motor will not turn on. One minute it was
Called the phone number posted on the vaccum cleaner itself and my husband received technical support directly from Dyson. Problem solved at no cost to us. Vaccum is working fine.
Jun 03, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Hi, vacuum clogged and motor shut down, how do I restart. thx
I'm assumeing you have remove the clog so unplug the machine an let it set of about an hour then plug it in and before you turn it on get it ready to vaccum then turn it on the overload switch should reset and it should run
Jan 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beam Industries 2775 Serenity Plus Central System Vacuum Logo
133 people viewed this question
Top Beam Industries Vacuums Experts
Beamvacman
Level 1 Expert
Thatvacguy.com
Are you a Beam Industries Vacuum Expert? Answer questions, earn points and help others
