Question about Mitsubishi WS-55805 55" Rear Projection Television
Mitsubishi 55 inch Rear Projection w/ Green tint
Hello there, I purchased a used Mitusubishi WS-55411 TV yesterday. When I picked it up the picture was incredibly sharp and clear. I trasported it home in a Trailer which I thought I still believe I had it well protected however when I got it home and hooked it up it has a terrible green tint and green shadows, I have tried adjusting all the Covergence manual as per the manual instructed. I might be a tad better however still terrible.. Any suggestions?
  • Shocku Jun 13, 2008
    Thanks for your input however, I don't follow what you are trying to tell me.
    Problem Solver:
  • 11 Answers
C.V.G ADJ AND SERVICE MODE ? GREEN C.V.G BAR ADJ POPARLY?
YES , SO POPARLY NOT SAVE 50HZ & 60HZ
NO, SO CVG I.C DEF, ITHER PRT LANCE LOOSE
Posted on Jun 13, 2008
About 4 inches on both sides of screen looks fine,the rest has a redish tint and on top there is 3 lines red,green and blue which only show up at certain times,when turning on,off,when changing chanels and...
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 13, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Hi I need a replacement bulb for my WS-55411 Mitsubishi. Can you help me find the right bulb and it's part number? The screen blacked out and sound still works so I assume I need a new bulb. When I shop...
Your model doesnt have a bulb since its a rear projection TV . It has three picture tubes, However loss of video with audio still working is usually caused by a vertical output failure.
Jul 28, 2010 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi WS-55411 55 in. Rear Projection Television
2 possibilities. Either your convergence IC's are going bad, or you need to remove the front panel of TV where the speaker grill is and you will find a small box with 6 control knobs on it. Mark each knob so you can set it back to its original position if you forget, the set might turn off if you adjust too high on either color, if so, set knob back in original position and turn tv back on and try again.The if it works reallign your convergence and that should do it.
Jan 28, 2009 | Mitsubishi WS-55411 55" Rear Projection...
Do have power and sound, do not have picture
this unit has a self test check you can do
when the set shuts down or when the set is turend off.
press and hold , onthe front of the set the input or device button, and hold the menue button for bbout 5 seconds.
the set will flash a 2 digit blink code at you.
12 blik = no problem
21 blink = xray protect
22 blink = short protect
23 blink = loss of deflection.
regards,
daniel.
Jan 15, 2009 | Mitsubishi WS-55411 55" Rear Projection...
TV not turning on after left on
ok 6 hours is not long but i would deffintly say u have a power issue now with the box inside over heated and burnt out will have to be prfessionaly replaced
Jul 18, 2008 | Mitsubishi WS-55411 55" Rear Projection...
4 pin or 6 pin
It has neither. It is not firewire capable.
Jul 17, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Mitsubishi turns on for 3 seconds then shuts off..after power surge
try holding in the menu and input buttons together on the front panel for about 8 seconds to see if the self diagnosis feature will blink a two digt code then let me know what happens
Jun 05, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Blue Screen/Waviness
sounds like convergance ic's mits is also know for bad caps
1000uf @ 16v check for bulges on top of the cap
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Jan 05, 2008 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55805 55" Rear Projection Television Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
