Question about Magic Chef MCD1311ST Microwave Oven
Some of the fields on the touch pad are not resopnding to touch. what can I do
  • 3,037 Answers
You can replace the touchpad itself since it is bad or you can get a new microwave. The touchpad can be ordered directly from the manufacturer or you can get one from repairclinic.com by searching with your model number. If you need more help with this, please let me know.
Benjamin
Posted on Nov 04, 2010
Touch pad inoperaive
Unfortunately, if you are having problems with a touch pad you will probably have to replace either the touch pad itself, if you can get it or the whole control board and touch pad as a unit which normally ends up running as much as a new microwave. I would check your warranty and see if it still is covered and proceed that direction.
Aug 13, 2013 | LG LMV1630 Convection/Microwave Oven
How to set clock?
You can set the clock to a 12 or 24 hour system.
For 12 hour - Touch clock pad once Enter the time using the number digits (1:00-12:59) Touch clock pad again
For 24 hour - Touch clock pad twice Enter the time using the number digits (0:00-23:59) Touch clock pad again
Mar 05, 2011 | Emerson MW8107WA Microwave Oven
On the touch pad numbers 3, 6, 7 and 0 dont work
sounds like the touch pad control has failed ... there is a touch pad on this unit and also a control board located behind units touch pad... you can gain access to this by unplugging unit and removing console that houses touch pad /clock assembly ... once removed the only test there really is to do would be with power off remove ribbon cable to touch pad and make sure clear of any dust /debri and reconnect there are 2 small holes in ribbon cable that are used when reconnected fir into small slots and firmly connect... if that doesnt fix i would recommend a new touch pad... not sure what area your located... there is a distributor for sharp in dallas ,texas called
global micro parts... reputable company that if you give them your model number they can assist you with the part.... good luck to you
Jan 27, 2011 | Sharp R305KS Microwave Oven
None of the keys work
the touch pad has a ribbon cable that connects to the control board poosible that the touch pad has failed or the control board itself.... most of the time the touch pad fixxes the problem... if you have power and all still try ordering the touch pad for the unit...
good luck to you
Jan 09, 2011 | Microwave Ovens
Touch pad inoperaive on one side
about the only thing you could do is to replace the touch pad there are no repairs done to touch pads we basically just install a new one i suppose one could take one apart and try to fix it but there are no schematics that they give to the touch pad make sure before ordering a new touch pad that it is the touch pad and not the control board that has malfunctioned if you are unable to perform these tests please call a repair technician if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 13, 2010 | Microwave Ovens
How to set clock on asda microwave, p80d20al t5
1. Touch CLOCK pad.
2. Touch CANCEL pad.
3. Use number pads to enter the correct time. You need at least three numbers to set time. (Note that the clock is a 12hr format clock)
4. Touch CLOCK pad again.
Aug 31, 2010 | Microwave Ovens
F2 E0 "Stuck key" ????????????
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!^!^
Jan 03, 2010 | KitchenAid KCMS1555RSS Stainless Steel...
Microwave shows F2 on display with controls non functional
HI. this is a code that represents a failed key pad or touch pad membrane board. replacing this failed touch pad will fix this issue. This touch pad board is separate from the actual control board.
Aug 13, 2009 | KitchenAid KHMS155L Microwave Oven
Manual for breville microwave bre799gmsse
this feature allows you to program your oven to begin cooking automatically at a designated time of day. Simply touch Custom Help pad. Touch the number 3. Enter the start time. Touch Clock pad. Enter cooking program. Touch Start/Touch On pad.
Jul 26, 2009 | Microwave Ovens
Magic Chef MCD1311ST Microwave Oven Logo
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
gggg
Kevin
Kevin
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
