Question about Danby DKC645BLS Compact Beverage Cooler
I have a danby dkc645bls kegarator when you plug it in it will cool to 34 deg then once it hits theat temp it starts climbing and won't cool back down unless you unplug it then plug it back in. Has anyboby had this problem and where can i order the parts
  • jfs49858 Nov 10, 2010
    yes very
  • 2,382 Answers
You have 2 possibilites as far as what is causing your problem.
1. PTC start relay / Klixon (2 parts as an assy)
2. Run capacitor
These are not expensive parts even if you ordered all of them.
The sad thing about it is the parts are not available at your "local" appliance parts store.
So your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Posted on Nov 03, 2010
Temperature controller malfunction
the adjustment dial , they are usually dirty from accumulated dust . at any auto parts store you can purchase a can of electrasol , unplug unit , spray into the middle of the switch, as you turn the switch, rapidly all the way around in both directions , repete this .. 2--3 times . look if possible, at the connections on the back of switch are clean ,and have good contact ... let device dry completely before plugging it back in and turning unit on.. let me know , good luck StevenT...
Jan 04, 2014 | Danby DKC645BLS Compact Beverage Cooler
Danby dkc645bls cools once, then wont kick back on when it starts getting warm.
Your compressor is not starting and in your case you have a thermal induced problem.
I looked for about an hour for parts below on-line with little success. (Danby sourced)
You have 3 possibilites as far as what is causing your problem.
2. Run capacitor
The sad thing about it is the parts are probably available at your "local" appliance parts store.
If you can look at your compressors' label and copy down the
Manufacturer (i.e Embraco, Mitsubishi Elec, Panasonic etc) and ALL numbers (including LRA)
you can take that info to the local appliance parts supply and walk out with the parts in hand.
Otherwise your looking at calling Danby (number below) and telling them you need a PTC Start relay / Overload and run capacitor.
1-800-263-2629 (US)
Thanks for using FixYa
Oct 16, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby Kegerator is beeping and flashing EE and won't cool
I am having the same problem seeing if you found a fix??
Aug 26, 2009 | Danby DKC645BLS Compact Beverage Cooler
Danby kegerator not cooling
I just had the same problem. Mine was outside on the patio and the key pad on the front was the problem. cost me $2.27 plus shipping and it took me 5 minutes to fix call Danby back and wait on the phone for their parts and tell them you need the keypad sticker. Good Luck
Jul 28, 2009 | Danby DKC645BLS Compact Beverage Cooler
Habco EMS-28 Thermostat not finctioning correctly
i have HABCO ESM28......Where I can find the thermostat controller.....
Apr 25, 2009 | Danby DKC645BLS Compact Beverage Cooler
Temperature - Is fan supposed to constantly run or is it controlled by thermostat
You said ,Top half of Danby DKC645BLS refrigerator 10 degrees warmer than bottom half. Bottom half cooling to approx. 34 degrees.
Is it running all the time without cycling off and on as it should be doing?
Sorry to have to tell you this news.
But this would mean a bad thermostat or insufficient freon in the cooling system.
The same issue with the fact that one compartment is warm and the other is cool!
Let me know that service tells you!
Thank You
Huuum
Please remember toleave a rating
Oct 19, 2008 | Danby DKC645BLS Compact Beverage Cooler
Buzzing noise from DKC645BLS
It's the fan that moves the air around inside to aid in circulation. Call danby and ask to buy it. It shpuldn't be very expensive at all.
1-800-263-2629
Jul 11, 2008 | Danby DKC645BLS Compact Beverage Cooler
Temperature light control (kegerator DKC645BLS)
Not sure u have a problem.. all appliances dont HOLD a certain.. Temp.. They cycle.. come on for awhile reach a temp the shut down.. goes so low the comes back on... the middle of the cycle is the avarage temp... yours being 36 from what you posted
Sep 04, 2007 | Danby DKC645BLS Compact Beverage Cooler
Thermostat
It's the Danby "auto-defrost" feature. It cycles off every 24 hrs to defrost, at which time the temp rises (as the unit isn't running!). Not much you can do. By the way, the blue LED temp display isn't accurate. It NEVER gets 36 (liquid temp) inside the Danby unless you do the following: Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Sep 03, 2007 | Danby DKC645BLS Compact Beverage Cooler
Danby DKC645BLS Compact Beverage Cooler Logo
1,318 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Marvin
Marvin
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
