Question about Philips 55P8341 55" Rear Projection Television
Help I have a phillips 55 inch rear projection tv. And the color is all wacked, I am adding a picture.. I need to know if I can fix it, what might have caused it to do it and if I am going to just have to buy a new one.
  • 1 more comment
  • Emily Jun 13, 2008
    sorry the picture didnt work above.. here it is
    How do I do that?
  • outlws822 Jul 03, 2008
    Picture is blurred and color is bad with hallos
  • Philips Master
  • 8,617 Answers
Change the CRT coolant in the green and blue tubes thats a comon problem with that model. You will be amazed at the results that changing the coolant will have on color, it will make it look like new again.
Posted on Jun 13, 2008
  • Sonny Berry
    Sonny Berry Jun 13, 2008
    its a rather involved proceedure, basically thr CRTs have to be removed. dissassembled and cleaned then reassembled and filled with new coolant.
I have a Mitsu ~ HDTV 1080 #65511 all the colors are out of wack. I can not find a place to align them and no longer have the manual ..
Tv have colors lines R,G,B mis alignments,have colors shadows picture or 3D pictures look alike?Tv have problems known as a convergence pictures problems.The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too,this parts on the convergence board must have be replaced.To fixed the convergence board to solved tv convergence pictures problems.The shops will cost u like $300-350 for parts and labors.
Jul 26, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from www.tvrepairworld.com which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
www.servicemanuals.vstore.ca
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Blue color bleeding
the color issue is most likely the crt coolant needs to be replaced you can get the phillips CRT coolant replacement kit at the following link which contains the coolant and the instructions on how to do the replacement.
http://servicemanuals.vstore.ca/
The crack you hear could just be the speakers or a intermitant ground problem in the audio circuit more likely the spealers if its only on strong Bass
Apr 03, 2009 | Philips 55PW9363 55" Rear Projection...
My colors all of a sudden went out of wack
Is there an advanced convergence setup anywhere in the menu where the screen displays a grid? If so, you might want to get into that and move along the grid to each section that looks off. Adjust until the color falls behind the gridline, and move on to the next. It can be a time-consuming process, but should take care of your convergence issues.
Jan 20, 2009 | Toshiba 55H70 55" Rear Projection...
Philips 50P8341 50 in. Rear... Problem:
You CRT coolant needs to be replaced, its a very common problem with the phillips and magnavox projection TVs. If you need more info on the Coolant Change let me know.
Jul 14, 2008 | Philips 55P8341 55" Rear Projection...
55 inch phillps projection tv model #55p8341
you have to have your ant/cable connected to but tunners on the back you should see a ant1 and a ant2 then select pip from your remote
Jan 20, 2008 | Philips 50P8341 50" Rear Projection...
C Color is way outta wack on my 56 inch pilips rear proj tv. HELP
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Oct 28, 2007 | Philips 60PP9352 60" Rear Projection...
Philips 55P8341 55" Rear Projection Television Logo
119 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
