Question about Sony KP-57WS500 57" Rear Projection Television
Regarding bad vertical ICS
Is this something I can repair? If so where is it located in the TV and is is a plug in?
thanks in advance for your help
  • patallen1 Jun 13, 2008
    Thanks, I guess I'll spend the $400 bucks
    patallen1
    Guru:
  • 1,894 Answers
Sir it is present in the control board of your TV sir.
both convergence IC and vertical ICs needs to be removed and soldered.
but since u wil be working at a very high voltage there is always a risk of electrical shock.
because the flyback voltage is enormously high.
Posted on Jun 13, 2008
Its a zenith 27in the sound is good but the picture only shows a line across the screen
Make a fist with ur hand and bang on the tv bazel frame.The tv picture flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics have coldsoldering joints and requiring resoldering.If u bang on the tv bazel frame picture don't flickers back or bounces back to a normal picture.The tv have a vertical or a horizontal hold ics are dead require changes those ics chips.If u don't have all the tools.Can't do a basic soldering work or able to changes those ics chips.Shop around for tv shops for estamate and repairing prices for repairing.
May 04, 2011 | Zenith C27A24T 27" TV
No picture or sound
Often these errors are related to a bad solder joint on the main-pcb or crt-board or what was once just a solder connection failure to the vertical circuit is now a full cascade failure of the vertical output circuit. You can check this by tapping on some parts on these pc's with an isolated screwdriver. Whenever you tap, and the picture goes dark, you're sure it's a bad solder joint and you'll need to re-solder it. Also bad solder connections around the flyback transformer as well as in the vertical sweep circuits. Please If you have no TV repair experience, call in a tech to assist you in this repair. Good Luck and let us know how you made out with this repair.
Best Regards,
Beach TV Repair
Treasure Coast, FL
Jul 04, 2010 | Sony KV-35V36 35" TV
My phillip tv has started showing a double picture
Hi
Thanks for using FixYa. The issue is with the convergence ICs going bad and needs to be replaced. It’s not a difficult job if you want to do this yourself, you should require some basic knowledge about soldering-resoldering components. To start with you’ll have to open the back of the unit and then replace the ICs(STK ICs) which are located behind the black heat sink and also check the resistors as if they are short the ICs might blow again after sometime. There are repair kits available which includes repair instructions with the parts, if you want to do it yourself you can buy and repair it yourself. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 11, 2010 | Philips 60PP9202 60" Rear Projection...
Mitsubishi WS-55857 with a flickering blue edge.
The vertical IC needs to be replaced. You can get new Vertical output ICs at www.tvrepairworld.com and they will also help explain where its located.
Nov 27, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Cannot adjust horizontal blue convergence on WS 55857
You still have bad grounds on the ICs. Or maybe the solder has fused another pin. If not bad grounds on the ICs you have missed them elsewhere...Really concentrate and look for these bad grounds and check your caps with a cap check. And power resistors too!!!!!
Sep 16, 2009 | Mitsubishi WS-55857 55" Rear Projection...
Toshiba 42" suddenly has blue arc projecting through lower half of screen. Confirmed it was the blue tube by removing the projector lens and looking at the direct image.  Is this a bad tube or something...
This is not a bad tube it is a convergence problem. Your convergence amplifiers are malfunctioning, and need to be replaced. If you have a background in electronics, you can remove the back of the TV locate the Convergence ICs (using the schematic or service manual) and the order the parts you will need which are the two convergence ICs and the biasing resistors (you will see these on the schematic). To remove them unsolder the pins, unscrew the screws holding them on the heat sink and remove them carefully, if they stick use a solvent to break down the adhesion of the heat sink paste. Once loose, take them out and then unsolder the biasing resistors and replace them with the ones you ordered along with the ICs.
To install the new ICs put heat sink paste on the back of the ICs and insert the pins into the proper holes in the circuit board. Screw the screws back in securely, and solder the connections back.
After doing this you will need to perform a convergence adjustment, using the cross hair adjustment screen (access this from your TV menu). and the you will need to do an advance adjustment using the crosshatch pattern (also accessed from your TV menu).
Once these are done use you service manual to follow the procedures on locking the adjustments into the TVs memory.
I hope this helps,
Thank you,
Shuttle83,
http://www.electron-age-technologies-llc.com
Mar 23, 2009 | Toshiba 42H83 42" Rear Projection...
STK392-110 ICs
Yes youre two stk392-110 Ics need to be replaced. You can get replacement ICs at the following link and they provide free instructions with pictures and also have free instant messageing with a tech online to help talk you through the repair. Its an easy inexspensive repair less tahn 40 dollars for both the new Ics and instructions and the tech support are free heres the link.
http://servicemanuals.vstore.ca/
May 28, 2008 | JVC AV-65WP74 Rear Projection Television
Schematic/manual needed for RCA 27V412T Color Television repair
Look for the vertical IC. It should be a small flat IC attached to a heatsink and marked something like LA7837. The IC will have a circuit designation like ICxxx. For example IC301. Check all of the caps in the same circuit (C3xx). One or more are bad &/or intermittant. Start there and keep us posted.
Dan
Apr 28, 2008 | Televison & Video
Blue line on TV screen
Hi
Your TV has a vertical fault. Based on your description, chances are that it is the vertical IC that went bad. It is relatively a simple repair job and any person with basic familiarity with electronic components and circuitry and soldering would be able to do the job. Should you venture to do a DIY please be reminded of the standard safe practices involve when working inside a TV unit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 24, 2008 | Fisher PC-19S90 TV
Sony KP-57WS500 57" Rear Projection Television Logo
27 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
