Question about EliteGroup ECS AMD690GM-M2 Socket AM2 Motherboard
Powers up, fan spins etc but no graphics. Using onboard vga. What can I do?
    Problem Solver:
  • 4 Answers
Get a debug card, put in the pci slot, put the processor, memory, hdd keyb, mouse on the place, double check it..turn on the power , read the last post code that display...watch for the blink of the 3 keyb lamp during power on...if there is no blink..then your o/b vga not initialized by the bios and (maybe) reading the other exp slot.
if there is a blink then check your monitor and cabling..record the last post code that display on the debug card (POST code display card), shutdown then remove all your device except for processor,ram,debug card , vga(if any external)...turn on the power again..did the post code is different or its the same with the last time?
shutdown,remove the ram, and vga (if any ext vga)..power up again (with only debug card and proc) did the code display the same or no ?
remove the proc and still with the debug card inserted in the slot..power up...what in the display?same?
you should be able to diagnose that..may be the proc (code 00 C0 C1 C2 ), may be the ram...maybe your o/b vga was dead..maybe your bios rom was still have bug (ECS ??=>does have a 2-3 years waranty..am i right?)
UDIN (indonesia)
Posted on Jun 13, 2008
Need a driver for vga from motherboard ecs elitegroup p4m900t-m2
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=822&CategoryID=1&DetailName=Feature&MenuID=16&LanID=9
Click Download and there are your drivers!!
Aug 14, 2011 | EliteGroup ECS P4M800-M7 (v3.1) + embedded...
Which vga card compatible wit P4M800PRO-M2, Pci or AGP?
Hi. Thanks for your question.
Video card compatible with your motherboard is an AGP 8x.
Hope this helped. For more info about your motherboard please see this link------>http://www.dealtime.com/Elitegroup-ECS-P4M800PRO-M2-2-0-Via-Socket-775-MicroATX-Motherboard-Audio-VGA-AGP-8x-10-100-Ethernet/prices
Thank you for using FixYa.
Dec 17, 2010 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
VGA card which compatible wit ECS P4M800PRO-M2
You can use VIA CN896, VIA Dual GFX Express, VIA PT880 Pro, S3 Graphics Cards, Gforce Graphics cards with VIA chips.
Good Luck.
Download all driver intel 945gct-m\
You just copy and paste this address.Yo can download the driver
http://drivers.softpedia.com/get/GRAPHICS-BOARD/OTHERS/ECS-945GCT-M2-V10-Intel945-VGA-Driver-6-14-10-4785.shtml
Jul 03, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Drivers dont work
try here >>> http://www.nodevice.com/driver/category/Motherboard.html
Jul 30, 2009 | EliteGroup ECS AMD690GM-M2 Socket AM2...
Reloaded Windows XP PRO SP3 and I do not have all drivers needed.
VIA/S3G P4M890 VGA Driver V16.94.45.10 you can d-load all the drivers you need from the ecs website
Dec 22, 2008 | EliteGroup P4M890TM2 (V1.0B) Motherboard
No picture at all
Hi geminip3, you need to make a couple bios changes when using a PCI-E graphics card. Still have your manual? Go to page 36. Advanced Chipset Features. Onboard GPU (Enable If No Ext GPU). By adding a PCI-E card this should be set to Disable. Than go to page 44. Init Display First (PCI Slot), set this to [PCI-E]. Read each page.
Than save your bios & exit. The system will auto restart. If you do not see display, wait about a minute & remove the monitor cable to the second out put slot. Some PCI-E cards need more power than the PCI-E motherboard slot can provide. You may find a power port on the PCI-E card. Some look just like the power cord for a floppy, others look like the power cord for an IDE hard disk drive. The latest ones are black in color & one end connects to an opened 4-pin molex (IDE power cord). Let’s address the onboard video card. (No PCI-E card attached). Back to page 36. Onboard GPU should be set to [Enable]. Page 44. Set Init Display First to [VGA/PCI]. Page 45. PCI/VGA Palette Snoop, set to [Disable]. I was unable to find where in the bios one can set the amount of system memory to run the onboard VGA. ECS manual is not the easiest to work with. Note: Ihave worked on other ECS MB's & though the above information has worked out ok for some, its not worked out for others. If the above suggestions do not work out, suggest you call ECS tech. I have emailed ECS stating their manual is confusing & asked for them to explain bios settings for VGA & PCI-E. Correct bios settings for your MB & user jrl1261's MB GeForce6199PM-M2. If the above settings do not work out. Don't fret. ECS wil get back to me & I'll post their email here.
Mike
Aug 10, 2008 | EliteGroup ECS GeForce6100SM-M (1.0)...
Black screen and beeping.
try to use pci card to getto screen agp ect ok maby bios thinks its that output reset it pull out battery then back in
Feb 03, 2008 | EliteGroup ECS AMD690GM-M2 Socket AM2...
EliteGroup ECS AMD690GM-M2 Socket AM2 Motherboard Logo
476 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
