Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
Hi f1 label is lit up in red on both washers and is making a alarm sound wont turn off
    Problem Solver:
  • 8 Answers
F1 = The flood switch has been activated for more than six seconds.
The flood switch is in the bottom of the whole unit, so it will have water in the tray of the carcass.
It will dry out eventually (or you can pull out the unit and tip the unit to empty the water), then the unit will stop beeping. However, it will just do it again unless you address the cause, which is any of the following:
Inlet hose to inlet valve connection loose
Inlet valve body leak
Damage to the fill or drain hoses
Heater plate damage (chipped enamel)
Seals/O Rings (pinched, contaminated or poor join)
Dispenser (seal, diverter valve or weld leak)
Lid area (lid motors not functioning correctly, lid off yoke or foreign object interfering with lid seal).
It's most often the last one.
A 603 drawer can leak - and cause an F1 - just during normal use.
Because the lid comes down after shutting the draw, if the user has stacked a pan or utensil in the draw that almost touches the top, it can prevent the lid from coming down and making the seal. So it will leak just for that wash.
This scenario never happened with the 601 models because they didn't have a lid that came down to make a seal. (They solved one problem but caused another!)
Alternatively...
On a 603 model, the lids get wound down when you close the draw. It's possibly a dead lid-seal motor. There are 2 worm-drive motors on either side, connecting to the lid via a yoke. F&P cocked up with the earlier 603 and used poor quality motor drives. These earlier inferior ones are beige in colour, whereas F&P recommend replacing with a superior black coloured drive. If yours are beige, it's quite likely that you might need to replace both or just one.
Posted on Nov 05, 2010
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
Red key lit up on a 2009 heritage softail and it wont start
Hi Anonymous, you need to do an alarm reset, for more information about your question please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 08, 2012 | Harley Davidson FLSTC - FLSTCI Heritage...
Hi, I have a Maytag stove and unfortunately have lost my manual. In the last couple of days there has been an alarm going off with F1 appearing on the display panel. Once at 5:30 am and at 1:00 am. Could...
With Maytag Ovens the F1 error means Defective touch pad or clock (ERC). This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present. (If you don't feel comfortable doing this yourself you need to arrange a repair technician to look at it for you)
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Regards, Kat (please leave feedback, thanks)
Aug 19, 2011 | Maytag Microwave Ovens
Hi, have twin drawer dishwasher which out of the blue suddenly started making a terrible noise and showed F1 on the window. Wasn't in use at the time
You have a leak in the dishwasher. The F1 alarm along with beeping sound is showing flood switch has tripped.
The inlet water hose is most likely developed a leak.
Turn the power off and disconnect water connection from under the sink.
You will have to dry the flood switch located at the base of the dishwasher housing under the bottom drawer.
Jun 26, 2011 | Fisher and Paykel Dishwashers
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
My washer was supposed to go in to spin cycle and alarmed with I believe F1. Is there anything I can do to fix this problem
There is a recall for the Cabrio for having the "F1" error(I had mine fixed by whirpool for free). Sounds like you are getting the F1 error code. If you have not had the washer repaired under the warranty program then you should give Whirlpool a call and get it repaired under warranty. When you call them say that you are getting the "F1" error code and have read on the internet that there is a recall. Have your model number,serial number and date of purchase available. They will send someone out to inspect the washer and repair if they have the control board in stock(they had to order mine and it took 2 days for it to arrive). I also located the phone number you will need to call for service...1-800-253-1301
Jan 22, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Ready light doesn't stay lit, alarm light is red
Because I was getting gray shading on my pages and data was still being printing, I decided to change the toner cartridge. Now the pages are clean and white and all the lights function properly. Most cartridges that are running on empty don't print any data at all or at least print the data at the top of the page and gradually gets fainter sp? on the page. Who would have thought just by changing the cartridge would solve the problem? So glad that's all it was........wasn't excited about having to buy a new printer.
Jul 22, 2009 | Brother HL 1440 Laser Printer
When you try to start car the alarm goes off and car wont start and horn goes on and off the locks click back and forth
'99 camry: with alarm sounding. turn key to "ON" position and press in and hold alarm button (red two position (in /out) on dash board. Button should go from flashing red to solid red. Release button when it stays lit (solid bright red) . Alarm is now in disabled mode and engine should crank when key is turned to "start" position. "Thank you" for over the phone tech support at Richardson Toyota in Texas.
Aug 03, 2008 | 1999 Toyota Camry
AcerPower F1 PC Desktop Problem
It could be a bad power supply. As far as I remember, this unit has a standard ATX 230 watt power supply. It should not be too hard to replace it. Its fairly straight-forward. Its a matter of removing the panel to access the connectors inside (make note of which comes from where) and unscrewing the power supply on the back of the unit. Reverse all actions to install new power supply. If you need more detailed help, reply to this post.
Apr 25, 2008 | AcerPower F1 PC Desktop
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
TomDicker
Level 1 Expert
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
