Question about Cuisinart ICE-50BC 1.5 Quart Ice Cream Maker
I accidentally washed the cuisinart ice cream bowl in hot water. is it beyond fixing?
Hi, I always wash the bowl in hot water, would not have it any other way for hygiene reasons & have never had a problem. After all it is only made of aluminium ! What has happened to yours to make you think you have a problem ?
Peter.
Posted on Jun 29, 2011
Cuisinart Ice Cream Freezer Bowls Not Freezing Anymore
I would take the freezer bowls out of the freezer, run them both under the sink to thaw both bowls out, dry both bowls thoroughly, and then set them both on the counter so that the liquid settles toward the bottom of the freezer bowls. After 1 hour, place the bowls FLAT back into the freezer - don't forget to wrap them in a plastic grocery bag or some other sort of plastic bag. Try to make ice cream again after 24 hours or more of freezing. Let me know if this works, so I can pass the good news along to others.
Aug 03, 2009 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Ice cream not firm
The freezer bowl is sensitive. Go ahead and thaw it out until you can hear the liquid swishing around inside - usually letting warm water run through it is sufficient for thawing. Then refreeze the bowl, making sure the bowl is sitting flat/level in the freezer. When making ice cream with this unit, letting the freezer bowl sit out for even 20 minutes can unfreeze it enough so that you only get sludge. Do not remove the freezer bowl until you are immediately ready to pour the ingedients into the bowl. You can even pre-chill your ingredients by letting the ingredients sit in the freezer for about 15 minutes - although I have found that this usually has the opposite effect of what you have just experienced --> the ingredients usually freeze up so fast that the mixing paddle is no longer able to turn.
-Tha Mp3 Doctor
Mar 16, 2009 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
Ice cream is soupy & when I freeze it it becomes icy
Freeze the bowl for at least 24 hrs, rather than the 12 hrs the manual suggests - it will make all the difference in the world. For really thick ice cream, freeze the bowl for a day, and then put the ingredients in the freezer until the outer rim becomes frozen. Very delicious!
-Tha Mp3 Doctor
Dec 10, 2008 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
I have the automatic frozen yogurt-ice cream & sorbet maker ICE-20 series made bby CUISINART. The first few times the icecream came out perfect & great. I made ice cream yesterday and it was soupy. I put...
I would actually let the freezer bowl thaw out on a level surface. Then place perfectly level back in the freezer for 24 hours. Should work again. Enjoy!
-Tha Mp3 Doctor
Put the ice cream bowl in the dishwasher
The only way to tell is by putting it in the freezer for 24 hours, and then trying to make a batch of ice cream. If it doesn't freeze or make the ice cream properly, then you will need to get a replacement bowl from Cuisinart - they are available.
-Tha Mp3 Doctor
Aug 11, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Cuisinart ice cream-frozen yougurt maker& sorbet maker CIM 60 series
I have the same problem, but it seems that it has gotten worse with time. When I first bought this product 6 years ago it worked fine, now the bowl won't freeze entirely and it has been in the freezer for two days (at the lowest freezer setting). I am wondering if the freezer bowl has a life span.
Aug 03, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Over freezing ice cream....
Any water is going to solidify the mixture. Make sure you use heavy whipping cream, and not half-and-half or some other substitute.
As far as the mixture freezing onto freezer bowl - use the supplied spatula to try to scrape it off, but I generally have to count that portion out as lost. Running warm water over it will quickly wash it off.
Happy mixing!
-Tha Mp3 Doctor
Jul 17, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
Mixing Arm Doesn't Turn
As long as it makes the ice cream, it doesn't matter which one turns. If it's not making the ice cream, call Cuisinart, as both the lid and the mixing arm can be replaced.
-Tha Mp3 Doctor
Jun 04, 2008 | Cuisinart ICE-20 Automatic Frozen Yogurt...
To much of yogurt or ice cream stuck to sides of bowl. What is the solution? 1.5 Cusinart ice cream maker
Use a silicon jiffer (rubber spatula to get stuff from walls of jars) to get it off walls and into bowl. You can also warm the bowl with warm/hot water on the outside and slide it out.
Do not use metal or it will scratch. Abrasive cleansers and scrubbing cloths will do this too ... so no steel wool please.
Apr 01, 2008 | Cuisinart ICE-50BC 1.5 Quart Ice Cream...
Cuisinart ICE-50BC 1.5 Quart Ice Cream Maker Logo
196 people viewed this question
Top Cuisinart Ice Cream Makers Experts
ellenskitche
Jay Finke
Jay Finke
Lawrence Oravetz
Are you a Cuisinart Ice Cream Maker Expert? Answer questions, earn points and help others
