Question about Andis 01690 Hair Trimmer
T trimmers 4710#
Clippers just stop working. when you turn them on you here nothing.
  • 62 Answers
Please return you clippers to the Andis Co at 1800 Renaissance Blvd Sturtevant WI 53177 and we will repair them. The standard repair cost is $11.50 plus parts if necessary. If the unit is less than a year old the repair will be covered under warranty. Without further information and inspection it would be impossible to tell you what the problem is. If you need any further information please call the customer service department at 1-800-558-9441.
Posted on Jun 16, 2008
My new andis t outliner making a loud noise
The Andis T-Outliner that you purchase from the USA is not for UK voltage 220 50 HZ, the Voltage is too high, the only way to control the voltage is transformer from 220V to 120 V. The Andis Trimmer that may work for you is the GTX trimmer this trimmer was manufactured for Canada and there voltage is 220V 50HZ.
Manny's Sharpening 323 237-2885 f175053b-23eb-4546-bbc5-bb86bc86dcf9.jpg Manny Mobile Sharpening and Clipper Parts Supplies
Mar 04, 2014 | Andis T-Outliner Hair Trimmer
My clippers just stopped working...just gives a light buzz
oil your blade after each use. on the side there is a blade adjustment setting. after you oil the blade turn your clipper on, turn the set screw out a few turns till the blade is free. Then turn back in till it makes a loud clacking noise. Then u will back out the set screw till the baldes stop clacking and keep oiled well.
Mar 20, 2013 | Wahl Super Taper Hair Clipper 2000 Hair...
Hedge trimmer clippers, elctric
Can't be too much to these things,so best bet is just take it apart.(My philosyphy is"It aint workin anyway,so just take a shot!"
May 11, 2012 | Garden
What's the role of the "power screw" ????
To adjust clipper/trimmers to run to their voltage needs. If clipper/trimmer rattles or over vibrates it may need adjustment to the line voltage in your area. Before adjusting, make sure the clipper/trimmer is clean and blade is oiled. Then turn the SMALL power screw clockwise on the side of the clipper until the noise disappears.
Mar 14, 2011 | Andis 01690 Hair Trimmer
Runs if tipped to the right. Not if tipped to the left
check the electrical cord at the clipper connection by bending the electrical cord at clipper end with the clipper on if the clipper stops the electrical cord is broken in side.if this will dose not locate the problem, the next possible problem will be the coil inside the clipper the coil has a broken field winding wire. Have a Wahl clipper repair shop repair the problem.
Mar 30, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
Wahl magic clip clippers are very noisy , tried to adjust ?
1 or 2 basic things happened. 1st there is an armature adjustment on the right hand side when viewing the clipper from the top (it looks like a screw). Place a screw driver in this and turn it counter clockwise, if this screw is up against the stop than you can place a small screwdriver behind it and pop it out (this is actually a cap) now you can access the actual adjuster. back this out about an 1/8 of a turn at a time until the noise stops, turn them side to side to insure that the armature is far enough off of the motor coil. Then replace the cap.
Jun 28, 2009 | Wahl Magic Clip Clippers Hair Trimmer
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Andis 01690 Hair Trimmer Logo
100 people viewed this question
Top Andis Health & Beauty Experts
Anglia Clipper...
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
