Question about Vizio VF551XVT 55 in. HDTV
75201 for local tv repair of vizio vf550 - Vizio VF551XVT 55 in. HDTV
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Nov 03, 2010
Vizio tv has sound no picture
Hi Brenton,
You have sound and no picture. It appears to be a case of backlight failure which is common in LED TVs. The problem is technical and involves opening the tv, diagnosing and replacing or repairing the defective board. Please consult some good local TV tech. Good Luck.
Apr 28, 2015 | Vizio Razor E461-A1 46" LED TV 1920x1080,...
Does my Vizio VF550 LCD HDTV 120z need to be plugged into a surge protector to be protected against storms or is there already one built in ?
Yes it must be plugged in to a surge protector, but don't get the cheap ones, buy a good one or you will be sending this to the repair shop when the current spikes. These sets are very sensitive to spikes. There is no protector built in on this set.
Jun 12, 2011 | Televison & Video
Picture problem
it all depends on whats wrong. if you are thinking you can fix burn in , TV you can't. but if the TV just needs a lamp. I recommend finding one on the web and having a local shop install it. the labor should be no more than $75
May 04, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have a Vizio hdtv 32'' lcd the power button is yellow, when I turn the tv on the button turns green but thats all that happens no pic or sound the model is Vizio L32HDTV 10A
I would guess the power supply went bad. The Vizio parts store sells the replacement for $82. Cheap fix for a decent TV.
Replacing it only requires a moderate mechanical skill. Removing the screws from the case is the hardest part. Remember to unplug the TV before you attempt this repair, or contact a local repair shop. They may only charge a small fee to install it for you.
Sep 13, 2009 | Vizio L32 32 in. LCD HDTV
No Picture on Vizio 42 in. Plasma
There is no backlight on plasma TVs. If you have a black screen than most likely one of your sustain boards are gone. Board can be purchased on line at about $100. If your TV has no signs of life it's most likely the power board. Any way it would not be that expensive to fix if you are able to take the TV apart and swap the boards. But I need to say that I recommend to do it ONLY if you are qualified enough. Otherwise ask your local TV repair company to service your TV.
Sep 06, 2009 | Vizio P42HD Television
My remote conrol quit working on my new Vizio HD TV. The set can only be operated by pushing buttons on the side manually.
Take your remote to a local dealer that sells Vizio and see if it works there. If it does then I would see if you can return the set or find a warranty center for Vizio. I just repaired one that had a bad IR receiver.
Jul 15, 2009 | Vizio Televison & Video
Vizio shuts itself off
There may be some components failing in the power supply or one of the circuit boards that are causing too high a current pull.
I realize that this answer is very vague. Without doing proper diagnostics, it is impossible to guess at something like this.
Out of warranty repairs on these sets can be very expensive. I would suggest that if the set is going to be expensive to service, it would be best to replace it with a known brand name that offers an extended warranty with local service. You will pay more, but you will have dependability and better quality.
Jerry G.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VF551XVT 55 in. HDTV Logo
106 people viewed this question
Top Vizio Televison & Video Experts
Steve Allison
Steve Allison
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
