Question about HP 1040 Plain Paper Inkjet Fax
HOW DO I ADJUST THE MODEM SPEED, I HAVE SKYBEAM PHONE SERVICE AND THEY SAID I NEED TO ADJUST THE MODEM SPEED TO THE LOWEST SETTING FOR THE FAX TO WORK
It is total depend on your phone line. modam has suficent speed. change your phone line u will got solution
Posted on Nov 03, 2010
2 Suggested Answers
  • 79 Answers
SOURCE: Ihave an HP1040 Fax, I
The setting is located in "menu," under fax settings, and you are looking to lower all transmission and receptions speeds/rates. This is due to the fact that voip services do not support faxing, though with this modification you should be able to receive and transmit faxes fine, though this is not a guaranteed fix.
-David.
Posted on Nov 04, 2010
The fax on my brother MFC-8460N does not work. it does not pick up a dialing tone when sending and on receiving it rings once says receiving bit nothing comes through. Please help
Your modem setting probably is not compabile with the data rate your phone will support.
From the user manual --
If you are having difficulty sending or
receiving a fax due to possible interference
on the phone line, we recommend that you
adjust the compatibility setting to reduce the
modem speed for fax operation
Press a or b to choose Basic or
Normal (or High).
Basic cuts the modem speed to
9600 bps. Unless interference is a
recurring problem on your phone
line, you may prefer to use it only
when needed.
Normal sets the modem speed at
14400 bps.
High sets the modem speed at
33600 bps.
Press OK.
Press Stop/Exit.
The other thing to consider is do you have tone or pulse dial service from your telephone company?
Mar 23, 2011 | Brother MFC-8460N All-In-One Printer
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
Ihave an HP1040 Fax, I recently changed phone service to Skybeam, they said I needed to chsange my modem speed to the lowest setting, how do I reset the modem speed.
-David.
Nov 03, 2010 | Office Equipment & Supplies
Ng poor line condition/ out of memory
Generally this is an indication that the telephone line you are trying to fax over has either alot of noise on it or possibly on the receivers end.If you are on a telephone line which has DSL service on it make sure you have a line filtre connected on the fax to eliminate line noise for your DSL modem, as well if you are using a digital phone service such as Vonage or your Cable providers phone service this is a digital service, contact brother technical support to have your modem speed lowered to 9600bps through the firmware switches on your machine.
Mar 26, 2010 | Brother IntelliFAX 4100 Laser Fax
I need to change a baud rate to9600 for telephone line. can you direct me please.
How to change the baud rate....
Press Menu/Set, 2, 0, 1.
Press ▲ or ▼ to select Basic or
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
* High is available for FAX-2910, FAX-2920
and MFC-7225 only.
Note
Basic reduces the modem speed to 9600
bps. Unless interference is a recurring
problem on your phone line, you may
prefer to use it only when needed.
14400 bps.
33600 bps..
Jul 29, 2009 | Brother Office Equipment & Supplies
Fax to location does not pickup and goes into
Adjust you transmission speed to the lowest setting then try.
Keep boosting speed up until you can no longer connect then back down one speed.
This brand is known for communication problems with other brand of fax machines.This is the only workaround that has supplied results for me.
Jul 22, 2009 | Brother MFC 420CN All-In-One InkJet...
I have my fax machine hooked up through a magic jack. how do i change fax speed?
I contacted the folks at MagicJack today and for faxes they confirm your findings. They suggest the following: We do not officially support using faxing with MagicJack. Please try the following steps to use MagicJack with your fax (contact your fax vendor for details):
- turn off error correction on your fax machine or program
- set the fax machine or program to use the slowest speed available
- increase the speed, checking at each speed that faxes work
The change must come through your fax machine, not the MJ.
HERE is a link to the manual for your fax machine.
If you are having problems sending or
adjust the Equalization for compatibility to
reduce the modem speed for fax operations.
a Press Menu, 2, 0, 2.
b Press a or b to choose Normal (or
Basic).
�� Basic reduces the modem speed to
when needed.
�� Normal sets the modem speed at
14400 bps. (Default)
Press OK.
c Press Stop/Exit.
Note
When you change the compatibility to
Basic, the ECM feature is only available
for color fax sending.
There are only 2 speed settings. Since the MJ does not support faxing, if the slower 9600 bps does not work, you will be unable to fax with the MJ.
Thanks for using FixYa - A FixYa rating is appreciated!!
Jan 26, 2009 | Brother Multi-Function Center MFC-240C...
Baud rate
1. Why 9600?
Because you are using a VOIP service it can from time to time lose connection briefly. The slower the speed the less data can be loss do to network congestion. It also gives the error correcting function of the receiving fax a better chance of filling in any lost data.
9600 is a good choice becasue the industry minimum is 9600. This means you will be able to communicate pretty much any fax thats is still tickin today. Raising the speed will get you a faster transfer but will also increase the chance that you are sending data at a faster rate than the recieving fax can send.
2. How to change the baud rate....
Normal (or High*).
Press Menu/Set.
Press Stop/Exit.
and MFC-7225 only.
Note
14400 bps.
33600 bps.
May 28, 2008 | Brother IntelliFax-2820 Laser Fax
Lower Modem Speed on a Brother Intellifax 4100
You need to find a service manual. Or have you tried brotherusa.com. The settings are made through the firmware switches.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
May 15, 2008 | Brother IntelliFAX 4100 Laser Fax
HP 1040 Plain Paper Inkjet Fax Logo
208 people viewed this question
Clive
Clive
