Question about M&S Systems MCD-6 6-Disc CD Changer
A cd is wedged in unit. can not remove cd changer
  • 10,594 Answers
First press and hold Track-Up and Mode buttons at same time on unit for three seconds to reset disc player, then check if cd get release.
In some cases, performing a reset on the MCD6 may resolve your problem. First try resetting the MCD6 player by pressing the TRACK UP and POWER buttons at the same time. If that does not work, remove the plastic front cover by pulling straight out and press the RESET button below the keypad. If your MCD6 player still does not operate, please take off cover from cd player and try to manually release wedged cd in unit.
If loading gears worn out then nothing will help to fix the unit, please contact local repair shop or M&S Systems at (214).358-3 196
Hope these info will help you.
Let me know if you have any question.
Thanks.
Posted on Nov 03, 2010
  • Raja
    Raja Nov 07, 2013
    In my case I have the CD Changer case not getting ejected. The changer case is empty. No CDs. I have disconnected and removed the CD Changer from the wall unit. I want to know what I should do manually to eject the case out. All I know is some lever is holding the case. What do I do to detach the lever?
Hi I have put a cd into the changer but now cannot eject the cd, the stereo reads error 99 please advise
The CD, when inserted, became either wedged or not seated properly and the sensors dont know how to respond. Here are the codes for Kenwood.
Changer Error Codes
• E-00: Poor Cable connection.
• E-01: Magazine not properly set in changer.
• E-02: No Disc in magazine.
• E-03: CD does not have selected track number.
• E-04: Disc is dirty, upside down or unreadable.
• E-10: No data is recorded on the MD. The player plays the next disc automatically.
• E-99: Changer malfunction, disc may be caught in machine or changer requires service.
If you have a steady hand... carfully unscrew and open up the unit just far enough so you can either pull, or nudge the CD tray enough for the CD to be seated in the tray properly...
Good luck...
Nov 20, 2012 | Televison & Video
Remove CD Magazine - No power to unit!
u need to re-connect it in order to remove the magazine
Jun 15, 2008 | Sony CDX-646 10-Disc CD Changer
WE HAVE A CD PLAYER IN THE CAR ALREADY WITH A REMOVABLE FRONT BUT ONLY PLAYS ONE CD CAN WE FIT A MULTI CD CHANGER TO THE EXISTING CD PLAYER OR DO WE HAVE TO GET A COMPLETE NEW CD SET UP
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
I removed my Mercedes 6 disc cd changer from my
Without power. you may just have to disassemble the unit.
Mar 08, 2010 | Panasonic CX-DP88 8-Disc CD Changer
In and out cd changer and error readind
Please explain what you are doing and what happens next. Since you've provided a generic problem the generic "reset everything solution" is unplug for 5 minutes plug back in and try it out. You might physically inspect the try and see if a foriegn object has been wedged some place it ought not.
Oct 23, 2009 | Aiwa Audio Players & Recorders
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds.
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 21, 2009 | iLO CA3000V CD Player
I removed my PU 2471A head unit and Blaupunkt IDC-A09 changer from my Peugeot car as both had minor faults caused by my son putting objects into cd slots.Prior to this both units worked perfectly in...
The head unit needs reprogramming with planet to accept the CD changer....... a main dealer or any good local garage should be able to help you with the software needed.
May 27, 2017 | Blaupunkt IDC-A09 5-Disc CD Changer
I need to uninstall my Sony 10 disk car CD changer
When removing display from dash make sure you remove ALL proprietary cabling, otherwise your unit is worthless...since the car is junk, do WHATEVER is necessary to remove the cabling....don't beat yourself up if you cant do it as Cd changers are pretty cheap nowadays.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 10, 2009 | Sony CDX-444RF 10-Disc CD Changer
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
I fixed my similar problem by applying 12v to the unit according to the pinout found here:
http://users.ntplx.net/~andrew/sony/unilink/
(note that -12v goes to the connector barrel)
Apr 26, 2008 | Sony CDX-656 10-Disc CD Changer
M&S Systems MCD-6 6-Disc CD Changer Logo
342 people viewed this question
Top M&S Systems Audio Players & Recorders Experts
Colin Stickland
Colin Stickland
Morne Olivier
Are you a M&S Systems Audio Player and Recorder Expert? Answer questions, earn points and help others
