Televison & Video Logo
Posted on Nov 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I'm not sure how to connect my Toshiba SE-R0346 to my Sanyo TV. I plugged the cable line into the "Antenna in" port & then another cable line from "Antenna Out" to my TV. If I unplug any of these, I lose the cable to my TV, so I know they are hooked up. I turn the power on on the VCR & press play, but nothing happens. Yes, there IS a tape in there!
Anonymous
Level 3:
Brigadier General:
  • Master 8,909 Answers
  • Posted on Nov 03, 2010
Anonymous
Master
Level 3:
Brigadier General:
Answers
8909
Questions
Helped
1540036
Points
28391
Exactly as you have done is fine all you need to do now is play the tape, (so you know what to look for when it is displayed on the screen), decide which channel you want to view the vVCR through, say 9, select the channel and set the TV to search tune on that channel. Store it when your taped programme appears.
Alternatively, have the set up as you have described and press auto install. That will retune the whole of the TV and include the VCR.
Hope this helps.
Connecting samsung sound bar to sanyo fvm3982 tv
Here are steps to connect a Samsung soundbar to a Sanyo FVM3982 TV using an optical cable:
  1. Locate the Optical Out port on the back of the Sanyo TV. This port will be labeled "Optical Out" and is usually covered by a small protective cap.
  2. Remove the protective cap from the Optical Out port and plug in one end of the optical cable.
  3. Connect the other end of the optical cable to the Optical In port on the Samsung soundbar. This port may be labeled "Optical In" or "Toslink".
  4. Turn on both the TV and the soundbar.
  5. On the Sanyo TV, use the remote to navigate to the audio settings. Look for an option to set the audio output to "External Speakers", "External Audio", or "Optical Out". Select this option.
  6. Adjust the volume on the Samsung soundbar using its remote control.
Once these steps are completed, the sound from the TV should be played through the Samsung soundbar. If you encounter any issues or don't hear any sound, check to make sure that the soundbar is set to the correct input and that the volume is turned up. Additionally, make sure that both the TV and soundbar are properly connected and powered on.
How can I connect and use a samsung se-506 to your samsung smart tv Samsung UN65H7150 65-Inch 1080p 240Hz 3D Smart LED TV
doot, your samsung se-506 can only connect via a usb cable
you would have to make sure you get the right cable
look at the se-506 and note if a male plug end if required or a female plug end
look at the usb input port on the tv and note if a male plug end if required or a female plug end .
I am guessing that both ends will need to be fatter plugs but you can confirm this by photographing the ports and showing the pictures to the electronics retailer who sells usb cables when your go out to buy a cable.
Hope this makes sense.
Trying to connect a digital antenna to my Sanyo tv. I plugged the cord from the antenna to the tv using the only input location labeled Ant. No signal, tried changing input but no luck.
an antenna has coaxial connection to go to your tv from the antenna... it looks like a barrel. If it is a powered antenna it will also have a cord to be connected to power in some way (usb, ac wall plug etc) that needs to be plugged in often as most those antennas do not pick up anything until you plug them in but that depends on location and a bunch of other stuff. good luck
https://www.6ya.com/mr.mike
On my toshiba 52hm84 how do I hook up a digital converter box
how to hook up on toshiba 52hm84 digital converter box
Connect antenna to antenna input on converter box.
Connect RCA audio/video cable from output on converter box to audio/video input on TV.
Plug the converter box's AC power cord into an electrical outlet.
Turn on TV and select "line" or "A/V" input.
Follow setup instructions in converter box owner's manual.
3helpful
"no signal" with N64 and sanyo tv. I have a sanyo
Well I think that you need a blue plug for it to work instead of
the tradditional N64 av cables.
Model ds31520. I've had it for years working like this: no antenna, no cable, just DVD (connected to non-S input ports) watching movies. Somehow I hit a button sequence on the remote and now only this: ...
Sorters -
Re-connect to me on the chat and we'll get this sorted. I'm really sorry - I got disconnected and the system would not allow me to reconnect to you. I have some ideas but chat would be easiest. If you don't want to chat, post a message here and I'll message back with some things to try.
BElectric.
I have a Sanyo DP32648 that keeps losing only one channel in the program. When the TV is turned off, that channel disappears from the program. I have to manually reboot the entire list. How can I solve...
It sounds like there is some electrical noise interference that would not be "fixable". If though, we reconfigure the way that they are connected together, we may be able to avoid the noise.
Instead of allowing the antenna signal to "pass through" the 625 we will skip it.
After following the directions, switching between satellite and antenna will be done by selecting on the SANYO "Input 1" for satellite, and selecting "Ant" for antenna. K?
Try this:
From the 625 Tuner 1- using RCA cables (a.k.a. composite cables, or red, white, yellow cable), connect to "Input 1" on the Sanyo TV. To see composite cables go to http://www.wowvision.tv/settingsandconnections.htm
Next, remove the coaxial cable between the Sat box and TV. (Sanyo "Ant. In" port and 625 "Out to TV" port) Set that cable aside.
Now, remove the incoming antenna cable from the 625 "Ant. In" port, and connect it to the Sanyo's "Antenna In" port.
Finally, scan for channels and check for the presence of CBS.
Once verified, test the TV by turning off and on.
Turn on the satellite receiver and switch Sanyo to "Input 1" to verify sat picture.
I believe this solution will satisfy your needs. Please let me know if it doesn't work, and I will need to talk to you about signal strengths, again.
God bless,
Highdefjeff
1helpful
3answers
I have 42 inch toshiba, my husband cancelled our cable, is there a way to get the tv to work for just local channels??
The instructions are in your TV manual, but because of the complexity of the TV and it's features, it may be difficult to find. I believe it is on P. 31 (at least of the manual I got online). You'll need to connect a TV antenna appropriate for your area. If broadcast sites are close (line of site) a simple bookshelf antenna will work. With the antenna connected, and the antenna input selected in setup, you allow the TV to scan for local channels in your area. I hope this helps you.
Connecting to Direct TV satellite box
If the cable is connected to Antenna/cable port on your TV, then set the TV to antenna mode and search for programs after which you should have some stations showing.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
