Battery on my laptop appears charged but when I remove the ac cord it turns off. Why
    Master:
  • 645 Answers
Its because the battery is not properly detected by the laptop.
Try updating the BIOS for the computer.
If that doesn't help, try getting a new battery.
Posted on Nov 04, 2010
HPG62 A45SA keeps cutting out while plugged into the mains (the battery has been removed). With the battery this problem doesn't happen. Instead, the plugged in not charging sign...
Sounds like your cable/charger/ computer AC plug in had been pulled, damaged, or the transformer is going out. If you can lat you hands on a similar known good AC cord it would help you trouble shoot the problem, you could eliminate the cord and focus on the computer plug-in. The AC/Charger cord transforms AC to DC to charge you battery and and run you computer. Another cable has to have similar specs (output voltage) as to not damage the components. As to the " plugged in not charging sign appears...", Is the battery old, replacement, does it deplete after using?
Nov 02, 2012 | Computers & Internet
Laptop Power Up Problem
Try booting under AC power with the battery removed.
Jun 05, 2008 | Gateway 400SD4 Notebook
My LG laptop is not powering on. what will i do? I didn't used it for three days then when I started to turn it on. there is no power. When I put the power cord, there is no light on the battery. What...
You may have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 06, 2011 | LG Computers & Internet
When you turn the laptop on it turns off with 30 - 60 secs.
Feb 06, 2011 | Acer Aspire 5735 Notebook
Its that the battery is not charging, and on the power meter icon its blinking four times orange and one time green. If I remove the battery, the laptop works with ac adapter. but if I reinstall the...
Check for a DC connector problem:
Feb 06, 2011 | Dell Latitude D610 Notebook
Yesterday my battery was indicating it was at 17%, so I plugged it in. Awhile later the "battery low" indicator came on screen so I realized it hadn't been charging. It still didn't charge if I...
You have a DC connector problem:
Jan 27, 2011 | Panasonic Toughbook CF-51 Notebook
I have dell c840. Suddenly only the left most light of the three lights gets orange when power is switched on and then there is no activity and screen remains blank. Bty light when plugged in also remain...
hello
shut down computer - unplug power cord from laptop - remove the battery from laptop - plug Ac adapter into computer and Ac outlet (wall)
turn on computer
if computer does not turn on, replace the AC adapter and cord - then place battery back into computer
plug in new Ac adapter and cord - recharge battery - if orange light stays on after 4-6 hours of charging battery, you need new battery as well - replace battery, charge it up and it should be fine
if you have attempted these steps before and no change occurs, then you may have issue with power connection in computer - locate a service centre to replace power connection on computer
Nov 07, 2010 | Dell Computers & Internet
Unable to recharge a laptop. is it the battery or the AC cord?
if you connect the AC cord to the laptop... it says it is charging ,, means the AC cord is ok... if you remove and your laptop turns off the battery is the problem.
Nov 04, 2010 | Toshiba Computers & Internet
Cant on my pc and no display appear at all
Unplug AC adapter from power cord, remove the battery wait 30 min, put back battery and plug the AC adapter.If not charging the battery, the problem is in AC adapter.If laptop not turn on need service.If it's in warranty contact service in your are.
Nov 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Computers & Internet Logo
18 people viewed this question
Alun Cox
David Payne
David Payne
