Question about Keurig B60 Coffee Maker
My keurig only dispenses half of a cup of coffee. Half the water comes through the kcup and the other half is despensed back into the water reservoir
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Posted on Mar 01, 2011
If water is coming from back water reservoir take an air compressor and blow air through white piece on both sides then blow air through top needle through all four holes....then walla problem solved! It worked for me.
Posted on Apr 15, 2011
My keurig is not dispensing water properly
1.Power off machine.
2.Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep.Insert it into slot on right side and again from back of needle.
3.Remove KCup cradle.Separate bottom from top.In the top section, insert the paperclip up into bottom needle from the bottom upwards.It will not go all the way thru and this is normal.
4.Reassemble KCup cradle and reinsert it back into coffee maker.
5.Power on machine.
6.Brew a cup of water only.There may be coffee grounds in the water and these should eventually clear during the remaining steps.NOTE: A large cup brew cycle should output a full 8 ounces (235cc).Less means there is still a blockage
7.Empty reservoir and fill with undiluted distilled white vinegar.Repeatedly run brewing cycle until Add Water light comes on.
8.Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9.Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10.Set Auto-OFF, if preferred.
Mar 28, 2011 | Keurig Coffee Makers & Espresso Machines
I Just love this machine however the past two days it is only giving me half a cup of coffee and then at the same time as it is filling my cup it is also putting the hot water back into the resevoir tank....
5.Power on machine.
Mar 27, 2011 | Keurig B60 Coffee Maker
Only brews half a cup on the largest cup setting?
5.Power on machine.
Mar 26, 2011 | Keurig Special Edition B60 Coffee Maker
Platinum B70 keurig coffee maker water heats up but won't allow the water to dispense into cup for coffee?tea
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
5. Power on machine.
6. Brew a cup of water only. There may be coffee grounds in the water and these should eventually clear during the remaining steps. NOTE: A large cup brew cycle should output a full 8 ounces (235cc). Less means there is still a blockage
Sep 15, 2010 | Keurig B100 Coffee Maker
The Keurig is heating up the water, yet is does
May 13, 2010 | Keurig B60 Coffee Maker
Keurig coffee
7. Empty reservoir and fill with undiluted distilled white vinegar. Repeatedly run brewing cycle until Add Water light comes on.
8. Make sure Auto-OFF is NOT set and let last cycle of vinegar remain inside machine for 4 hours.
9. Refill reservoir with fresh water and repeatedly run brewing cycle until the water is clear and odorless.
10. Set Auto-OFF, if preferred.
Apr 28, 2010 | Keurig Elite B40 Coffee Maker
We have a keurig coffeemaker, and it's not making a full cup..maybe half the water comes out....have restarted, gone thru menu, don't know what the problem is...
Check the needle inside the k-cup reservoir/holder to ensure it is clean and free from obstructions. The needle can get clogged easily, preventing it from brewing properly. You can remove it by pushing up from the bottom where it dispenses into your coffee cup. Wash it out completely, then brew a "blank" cup of just water on the largest size setting with no k-cup in it. If that isn't the problem, check your water reservoir tank to make sure it is seated properly. Jiggle it a bit or remove it and replace it pressing it down to make sure it is secured in the base well. Hope that helps! Best of luck...
Nov 03, 2009 | Keurig B60 Coffee Maker
My 9 month old machine only spits out water for a second
I called Keurig and they felt that it was likely a blockage at the needles, but despite cleaning them repeatedly, there was no improvement. They are sending me a replacement.
Sep 16, 2009 | Keurig Platinum B70 Coffee Maker
Keurig B60 Coffee Maker Logo
3,291 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Steve Allison
Steve Allison
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
