Cannot connect from windows 7 to host computer running vista. Showing internet gateway device on both computers. Have run network discovery, no results
    Master:
  • 645 Answers
Turn off the windows firewall and all the security softwares.
Try to ping the other computers IP.
If that shows up, u are good to go.
Posted on Nov 04, 2010
I'm running Windows Vista Business with a Belkin PlugNPlay router as host. My wife's networked computer is running Windows 7. In my network/sharing center I'm unable to change the network from public to...
Running the risk of a thick ear from the wife, I would dismantle and uninstall the network. Reboot your computer and set it up again then add your wifes computer without letting 7 change the settings.
Dec 31, 2010 | Microsoft Windows Vista Business DVD...
Tip
How To Enable File And Printer Sharing In XP, Vista, and 7
Verify File and Printer Sharing for Microsoft Networks is Installed by following these instructions for your particular OS:
Windows XP
1. Log in as the administrator or as an account that has administrator capabilities.
2. Open the Control Panel and click Network And Internet Connections.
3. Below "Pick A Control Panel" Icon, click "Network Setup Wizard."
4. On the Welcome screen that displays, click Next and then click Next again. The wizard displays the Select A Connection Method dialog box.
5. If your host computer connects to the Internet through a residential gateway like a router, access point, or base station, select the second option and click Next.
6. The following prompt is for your computer’s description and name. Accept the default answers and click Next. Do the same for the Workgroup Name prompt.
7. On the File And Printer Sharing screen, select the Turn On File And Printer Sharing radio button and click Next.
8. When the process is complete, the You’re Almost Done dialog box displays.
9. Select Just Finish The Wizard; I Don’t Need To Run The Wizard On Other Computers and click Next.
Windows Vista
1. Click Start, right-click Network, and then click Properties.
2. In the Network and Sharing Center window, under Sharing and Discovery, click the down arrow next to File sharing.
3. Within the File sharing settings, click Turn on file sharing, and then click Apply.
4. Next, click the down arrow next to Printer sharing.
5. Within the Printer sharing settings, click Turn on printer sharing, and then click Apply.
Windows 7
1. Click Start, open up Control Panel, then click on Network and Internet, then click on Network and Sharing Center.
2. In the Network and Sharing Center window, click on Change advanced sharing settings.
3. In the Advanced Sharing Settings window, you will need to change the settings for the Home or Work, and Public profiles.
4. Turn on File and Printer Sharing for both Home or Work, and Public profiles.
5. Click Save Changes and close this window.
on Jul 14, 2010 | Computers & Internet
Tip
How to determine what your computers IP address is
How to determine what your computers local IP address is
Applies to Windows XP, Windows Vista and Windows 7
1. Click Start - Run
2. Next enter "CMD" and click OK
3. Next at the command prompt type "ipconfig" and press enter
At this point all your active connections will list on the screen. Note you may need to scroll back up the window to get to the connection info you need. Also keep in mine if you are connected to your wired or wireless connection because both might have an IP address assigned but you can only be actively connected to one at a time not both.
4. Look under the Local Area Connection if connected to your network via a wired connection or Wireless Network Connection if connecting via a wreless connection.
Once under the right connection you will want to look for the line that shows "IP Address" this will have what the computers current IP Address is. Note if you have Windows Vista or Windows 7 it will be listed as "IPv4 Address". Also while you are here take note to what the "Default Gateway" is because if you are trying to network computers together you want to make sure they are connecting to the right network.
Here is an example of what IPCONFIG looks like on a computer running Windows 7
Other Helpful Links
How to allow ping request through Norton Internet Security 2010 Smart Firewall
How to check and change you computer IP address in Windows 7
How to enable and disable printer and file sharing in Windows 7
How to take file ownership in Windows 7 and Windows Vista
How to change your drive letter in Windows Vista and Windows 7
How to determine your computer's MAC address
on May 24, 2010 | Computers & Internet
Can vista home premium connect to a LAN
You should check the possibility to connect to homegroup network. I have Vista home OS and I can use router to connect to internet but I can not connect to other PC runned windows 7, I can see them but without connection. I had found on a forum that Vista home version can not interconnect in homegropu network.
Good luck with your search
Mar 19, 2010 | Computers & Internet
How do i enable UPnP on my router
For the UPnP architecture to work in Windows XP, the Internet gateway device must appear in Network Connections. To make sure that the device appears in Network Connections, click Start, click Run, type ncpa.cpl, and then click OK. Look for the Internet Gateway device:
Also, the router must appear in My Network Places. To make sure the router appears, click My Network Places in the Network Connections navigation pane, and then look for the router:
Collapse this imageExpand this image941206b.jpg Note The name that appears is the model name of the router. For information about how to enable UPnP on a router, view the router product documentation. If these devices do not appear, make sure that the correct components and services are installed in Windows XP. To make sure that the correct components and services are there so that you can enable UPnP, follow these steps:
  1. Click Start, click Run, type appwiz.cpl, and then click OK.
  2. Click Add/Remove Windows Components.
  3. In the Components window, click Networking Services, and then click Details.
  4. Click to select the Internet Gateway Device and UPnP User Interface check boxes in the Subcomponents of Networking Services window, if they are not selected.
  5. Follow the instructions that appear on the screen to complete the installation. Or, if you did not make any changes, close the Add or Remove Programs windows and Control Panel.
  6. Start the Services MMC snap-in. To do this, click Start, click Run, type services.msc, and then click OK.
  7. Locate SSDP Discovery Service in the list of services.
  8. If the status is not Started, double-click SSDP Discovery Service to open the SSDP Discovery Service Properties dialog box.
  9. In the Startup type box, click Automatic, and then click Start under Service status. Then, close the SSDP Discovery Services Properties dialog box.
Jan 16, 2010 | Computers & Internet
Tip
Network Windows 7 with Xp and Vista
Windows 7 includes a new way to share data between all computers in the house with the Residential Group. But only when computers running Windows 7 may join the Group residential and enjoy the new features of sharing, playing multimedia files remotely, etc.. If you have computers running Windows XP or Windows Vista networking with Windows 7, you can still share your files and printers in Windows 7 "old" by following the instructions in this case practice. Below are the steps to do the same.
Check the workgroup:
To be a network, your computers with XP, Vista and Windows 7 should be part of the same workgroup.
Click the Start button. Right-click Computer (My Computer in XP) and click Properties.
In the Settings area of the computer name, verify the name of the working group. The default name is WORKGROUP but you can customize it by clicking the Change Settings button.
Make sure it is the same on other machines on the network. Under XP, the information is in the Computer Name tab.
Enable Sharing:
To enable sharing in Windows 7, you must change the settings of the Network and Sharing Center.
Click Start, then Control Panel.
Click Network and Internet and then click Network and Sharing Center.
In the left column, click Change sharing settings advanced.
Verify that the options Enable network discovery, Enable file sharing and printer sharing and Enable so that anyone with network access can read and write are checked.
Click Save Changes.
on May 19, 2010 | Computers & Internet
Can't ping Default Gateway (XP) From Windows 7
Make sure you are receiving a proper IP address from the DHCP server....If you run a cmd prompt (windows icon, type cmd and hit eneter, then ipconfig) you should see a 192.168.0.x address. If not, go to the control panel, network connections, manage network connections, and be sure that TCP/IP (V4) is set as auto-configure....
If you are sharing the connection through an XP computer, you will need to run the Internet and connection sharing Wizard on the XP computer, and transfger the settings on a disk to the Windows 7 PC. A simpler solution (assuming you are on a cable/dsl connection would to be to go to your local big box store and buy an Internet/Firewall router. It would also increase your security.
Dec 28, 2009 | Microsoft Windows Vista Ultimate Edition
Internet Applications wont connect - Vista
I am running Windows 7 (the new vista) so I hope I can help. Go to the "Start" button and select "Control Panel". Click on "Network and Internet" and then "Network and Sharing Center". You shouls see something like: Computer =====Network ====== Internet. If there is an "X" on one of the connections, that may help you decide which option further down to try. You can keep me posted if this helps to this point.
May 28, 2009 | Computers & Internet
How to share internet connection on Windows Vista OS. I want to share internet connection between two Laptops using Windows Vista Operating system and the other using Windows XP. The Host computer is...
All right let's call your Vista computer A and your Xp computer B. First you have to bring the two computers into LAN. If you already did this, please skip the next eight steps.
Step 1: In Vista, before doing this you should enable Sharing and Discovery. You can do that by going to Control Panel -> Network and Sharing Center. Under the section ‘Sharing and Discovery, enable Network discovery, File Sharing, Public folder sharing and others if you want to. (See picture below)
Step 2: If your LAN card that is connecting to another computer is installed, it will be shown under Control Panel -> Network Connections.
Step 3: Right click that local area connection and click properties.
Step 4: Under the tab ‘Networking’, click the properties Internet Protocol Version 4 (TCP/IPv4).
Step 5: Click the radio button to ‘Use the following IP’ and give an IP address (For example, IP address: 192.168.0.1 and Subnet Mask: 255.255.255.0)
Step 6: Don’t give any other information, Click Ok and close everything.
Step 7: In computer B, which is the XP, make sure you enable the LAN card which is used to connect to computer ‘A’. Here you need not give any IP information as Computer ‘A’ will assign an IP address dynamically. If it’s not working make sure there are no IP assigned and change the properties to ‘Obtain an IP address automatically’.
Step 8: Test the connection by pinging. (You can do this by typing ping 192.168.0.1 or whichever is Compter ‘A’s IP in the comand prompt)
NOW your computers are connected. Now to share the internet:
Right click LAN card which is connected to Internet under Control Panel -> Network Connections and click ‘Sharing’ tab and enable both the options to share Internet. (Note: Unless there is another enabled LAN setting you will not be able to see the shared tab under properties)
Click Ok and close. This option is given by the Windows OS known as ICS (Internet Connection Sharing).
Now you can use Internet from both Computer A and Computer B from a single connection.
So this is the setup you need on the Host computer as you requested, if you turn out to need help witht he XP one too, let me know:)
Feb 14, 2009 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
26 people viewed this question
Alun Cox
David Payne
David Payne
