Question about Dryers
My ge dryer 2 years old model DCVH515EFOWW keep shuting off after 2 min I tried all cycles its doing the same thing control panel shows 0.00 and shuts off when i turn it on again it comes back on for 2min and shuts off again i starts again it comes on for 2 min again i did smell some plastic burning smell
  • Dryers Master
  • 8,220 Answers
This dryer is a little fancier looking but is really no different from GE dryers of the past. Reach inside and try to turn the drum by hand. If it seems hard to turn then the motor is gonna bogg down. You must get inside the dryer and inspect the drum glides. Most of these newer models have to have the top removed first and then the controls. Then you can get the front panel off to inspect the dryer glides.
Numbers 315 and 316
Older models with bad glides look like thismy ge dryer 2 years - themobilian_36.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 03, 2010
I have a Frigidaire Affinity electric dryer Model # FAQE7001LWO. . The cycle will start for about 5-7 mins once started and then it shuts off and all lights on the unit start blinking. Please Help!
Google your model number and how to retrieve the error codes. It sounds like either the heating coil or control board is bad. I have a different model that does the very same thing...they run until the cycle tried to turn the heat on then it causes an error. In my case it is the control panel and I decided since mine is old and we are a family 6 (lots of use in it) not to repair it.
Aug 04, 2016 | Frigidaire Dryers
GE dryer runs but only heats on timed cycle not the other 2 cycles.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Feb 17, 2015 | GE Dryers
Ge dryer dcvh515efoww runs on air dry, but when set on any heating cycle, it runs for a few minutes and then it turns off on 00
it is over heating you might have unplugged a wire to the thermostat when you had it apart or the thermostat has went out.
Mar 21, 2014 | GE Dryers
What do the "T" error codes mean in regards to GE electric dryer model # DCVH515EFOWW
YOU must see you instruction manual section troubleshooting and Fix it.
if you do not have download the instruction manual from www. fitness.manualsonline.com or www. retrevo.com
God bless you
Jun 19, 2012 | GE Dryers
GE Washer Model WCVH6260HWW, Fabric Softener Won't Dispense/Drain
I took the tray out and placed it to the side. Then I ran a common pipe cleaner through the nozzle that supplies a water spray to the tray. So far, so good.
Jan 28, 2010 | GE Energy Star WCVH6260F Front Load Washer
Dle2532 lg dryer, cooling light is always on
I'll take a stab that you use dryer softener sheets. These will deposit a coating on the two metal sensor bars (about 4 inches long, very near the lint filter inside the drum) which prevents the sensor from "seeing" that the clothes are still wet, so the dryer jumps to the cool down portion of the cycle. Clean the metal bars off and it should work again. (note: the bars are not in the cycle if you choose time dry instead of using the automatic cycles)
Apr 11, 2009 | LG DLE2532W Electric Dryer
Electric dryer intermittently doesn't heat
If your dryer has a timer with quick connects which easily plug into it then you can possibly fix this problem. Yank both connects off the timer and remove the timer. Take the 2 motor screws off and remove the plate carefully. Clean the contacts on each leaf switch with a file. Put it back and retry. Sounds difficult but it isn't. Remember only the timer with the 2 quick connects.
Dec 21, 2008 | Dryers
DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
Jun 18, 2008 | GE DBXR463EBWW Electric Dryer
Dryer runs but will not dry
It may be a thermostat that has gone, thus preventing the heater from going on. Check your power source as well, maybe you have lost a line.
SGt 48
Jun 17, 2008 | GE DCVH515EFWW Electric Dryer
Dryers Logo
77 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
