Question about Sony KP-57WS500 57" Rear Projection Television
I have a problem with my Sony 57"wide screen TV Model kp57ws510
The TV is like I am seeing double, there are lines on the left and right side that are blue gray and red. Is this something I can repair or must I take it into a shop. The local shop wants more than $400.00 for the repair, but they won't give me the name of the bad part.
My email is
thank you for your help
patrick allen
  • 1,894 Answers
Its due to bad vertical ICs
Posted on Jun 13, 2008
  • dewan nafees ahmed Jun 13, 2008
    also it can be due to convergence ICs going BAD.
    repair shops usually dont tell you what the parts are.
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
My 57" rear-projection Toshiba TV is showing about a 12" wide path of scrambled lines from the left to the right side of the screen at about 1/3 from the bottom of the screen itself. Sometimes the...
It looks like a dynamic focus problem. But I think you'd have to call a shop. It would require a part order, soldering, and likely more test and troubleshooting. It could be guessed that it's a dynamic focus transformer or similar, from looking in the schematic.
Apr 21, 2010 | Hitachi 57F500 57" Rear Projection...
54inch Hitachi TV has double figures and colors red, yellow-not normal. Set approximately seven -eight years old. Lost remote control and direction book in moving. Is the set worth getting fixed? Generally...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
Apr 11, 2010 | Hitachi 57F500 57" Rear Projection...
Everything on the screen is doubled focus and it seems like the screen is calapsd in the middle
What you describe is probably a color convergence collapse, usually caused by a power amplifier failure, refer to the following link: if this video is close to what you see on your TV you will need to replace both power convergence IC, the model KP57WS510(model given in your post) calls for STK392-510 both are available through UED, email, the above link gives an idea on what is needed for the IC replacement, that is if you're thinking of repairing the problem yourself.
Apr 07, 2010 | Sony KP-57WS510 57" Rear Projection HDTV
My Sony Big screen,57in.,Model #KP57WS510,the age-Feb.2004. I turned it on,it looks like i need a pair of 3-D glasses to watch it.Red and green outline the people or objects.Not so much in the...
The following convergence repair kit also applies to your model sony The kit contains the two convergence ICs all six pico fuses and four of the 4.7 ohm resistors. It also comes with free installation instructions and free tech support so you can do the repair yourself.
Jan 19, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Left side of screen going yellow and pink with leters in double
The convergence modules have gone bad Along with the new parts kit are fuses, diodes, and resistors that usually fry when these modules go bad. Depending on the model, there will be two and sometimes 3 of these modules that have to be replaced. Each module has 50 pins each that have to be soldered, so unless you have experience with complicated TV repairs, the cost to do that repair may be as much as a flat screen TV of the same screen size as yours.
May 12, 2017 | Mitsubishi WS-65711 65" Rear Projection...
there are a series of 4.7 ohm 1/2 watt resistors all in a row under the fins of the ICs. Check them they have to have one side unsolderd to check them. There are also 6 yellow pico fuses in that line of resistors that need to be checked as well.
Jul 05, 2008 | Sony KP-57WS510 57" Rear Projection HDTV
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
Sony KP-57WS500 57" Rear Projection Television Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
