Question about HP Wireless Optical Mouse
The maning when the red light blink on the wall plug in for mices
    Problem Solver:
  • 14 Answers
I assume you meant, "The meaning".
When this light is blinking, this means the mouse is charging.
Posted on Nov 03, 2010
Brand new, never used. Plug into wall to charge and just get flashing red light. After 16 hrs on charge, still flashing red and when turn on, screen blinks then shuts down.
check that you have the battery in the correct way
if it has batteries like AA , AAA or what ever the negative terminal of the battery goes against the coil spring so if you have them all facing the same way, that may be why they are not charging
the screen shutting down at this stage would be cause the batteries are flat
of course you could always bet new fully charged rechargeable batteries and put them in correctly to see if the rest works
Apr 30, 2017 | Sylvania SDVD7015 7 in Portable DVD Player
The power light stays red and if pushed to go on, only blinks red. There is a high pitched sound when it is plugged into the wall. I've tried unhooking the box from the antennae, the tv, and the wall...
Sounds like you have a high voltage issue with the power supply. The blinking light is actually a trouble code and some of these can be found in your manual, others can be looked up on the web if you type the make and model of the set and the number of blinks you should be able to track down the issue. If your not comfortable about working on the set then you will ned a repair person to check out the power supply and other boards on the set.
Jun 25, 2011 | Televison & Video
Ps3 red light keeps blinking
Step 1: Check Your Console
One of the biggest causes of the blinking red light problem is placing the console with the fan vents sitting against the floor or up against a wall where air cannot flow freely in and out of the console.
So, start by checking your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. Once you fix the blinking red light of your ps3 and your console is working again, you will want to keep the vents clean and unobstructed.
Step 2: Test the Hard Drive
Now, find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit. It could possibly be a problem with overheating which causes problems with the motherboard, especially if you had your console on the floor or up against a wall.
Step 3: Unplug
The last in-home remedy to fix PS3 red light blinking is to unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating. If it doesn't work, then you have more substantial damage to your console motherboard.
Yet, that doesn't mean the console is useless! Continue on to find a permanent solution to the problem.
If all this doesn't work go through this mannual to have step by step instructions for solving this problem http://www.gamingupholds.com/ps3-repair-guide.aspx
Feb 14, 2011 | Sony Playstation 3 (PS3) Console
Red light blinks and wont start up or eject
So, start by checking your console and making sure those fans are not blocked off. If you notice a lot of dust on the console, clean it off right away. find the hard drive on the side of your console and remove it. Wait a few seconds and replace it. In some cases this may fix PS3 red light. If you still see the blinking red light, there is a chance you have more substantial damage inside your unit. unplug the console from the wall for about half an hour and then plug it back in. This doesn't always work, but some people have had success with problems other than overheating.
or click here to download repair guide
Dec 26, 2010 | Sony Playstation 3 (PS3) Console
I have a micro innovation mouse it has 2 parts the mouse has a red light how can i hook it up please
plug the transmitter into a usb port. make sure batteries are in the mouse and the switch is on. press the button on the transmitter and the red light will blink slowly. next, press the reset button on the bottom of the mouse. when the red light on the transmitter blinks fast, it has connected.
Sep 05, 2010 | Micro Innovations PD7250LSR Wireless RF...
Tv won't turn on 4 blinking led
Red led blinks 4 times is an error code that shows that fan is not running in tv, check fans connections and make sure all are plugged properly.
Thanks.
Jul 18, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Battery light blinking red during charging
Dell or Panasonic? Your post has both listed.
If the blinking light on a Dell is yellow or amber or orange (somewhere in that color range) and continues to blink the entire time it is plugged into AC power (wall outlet) and when you unplug it from the wall the laptop immediately dies .... then you battery is dead and needs replaced.
If the blinking light stops after a while (perhaps a minute?) and then turns green while plugged into AC power, then it is successfully charging - or so it thinks.
When you unplug it from the wall, does it stay up and running?
If it runs, it's OK - just ignore the light and plan on getting a new battery one day, start browsing now. :)
If it dies immediately upon unplugging, then your battery is dead and needs replaced.
Jun 13, 2009 | Panasonic Toughbook 28 Notebook
Red blinking light when on my compaq deskpro en pc
Probably your power supply. They are pretty cheap to replace. If it's plugged into a power bar then try plugging it directly into a wall socket just to make sure it isn't your power supply.
Apr 01, 2009 | Compaq Deskpro EN 6350 Model 4300...
HP Wireless Optical Mouse Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
