DVD stuck in drive. How do you manually eject the DVD?
  • 22 Answers
Question, does the dvd stuck inside still play, can you hear it spinning?
Posted on Nov 03, 2010
Disc will not eject from dvd player
Have you tried both the eject button on the DVD drive and the remote? Is there a disk jammed in the drive? Here is the manual:
http://www.curtisint.com/html/custservice/manuals/PRO_PLEDV1945A_EN.PDF
most of the time there is a small hole near the eject button that you can unbend a paper clip and insert it into that will release the door.
here's a video.. it's a computer, but same principle:
Open Stuck Drive on Your PC
Aug 14, 2015 | Curtis ProScan PLEDV1945A 19"" TV/DVD...
Why is my Sony bdvn790 stuck on bd/DVD and the front light flashes
I am having the same issue. From what I can tell (at least in my case), there was a disc stuck in the DVD drive. I had to dismantle the chassis, remove the drive and manually "eject" the disc. There is a manual screw port under the BD/DVD drive that you turn and it will manually eject the disc. However, removing the disc from the drive did not solve my problem. I am still getting the BD/DVD displayed when powering the system back on and the light is flashing as you described.
Oct 12, 2014 | Sony Bdv-n790w 5.1-channel 1000w Blu-ray...
Dvd drive door stuck
In case you're not able to eject the disc using the eject button, you can try right clicking on the CD/DVD drive under 'My Computer' and clicking on eject. If that fails as well, you can try to eject the disc manually by pushing a straightened paper clip or a pin into the tiny hole on front of the CD/DVD drive. You should be able to eject it using the last method.
GuruAid.com
May 31, 2014 | Gateway 830GM PC Desktop
How to get a dvd tray unstuck
There are two ways to open the CD/DVD drive door if the button just below the drive tray does not work.
Go to My Computer and right click on the drive and click on Eject.
If this does not work then you can manually open the CD/DVD drive tray by -
Straighten a paper clip and gently insert it into a tiny hole below the drive tray next to the Eject button. Push the paper clip gently until the drive tray pops out, then pull the tray until it is fully out, then you can remove the CD/DVD disc.
If you still having problem opening with the Eject button, then the CD/DVD drive is faulty and needs replacing.
May 19, 2013 | Televison & Video
Acer aspire dvd wont open with eject button
Whether you use your DVD drive to install software, make backups of your personal files or watch movies, having that drive onboard makes your computer more useful and more versatile.
While DVD drives function normally most of the time, sometimes a DVD will become stuck in the drive, and the tray will refuse to open.
Knowing what steps to take to resolve the situation allows you to start enjoying the advantages of the DVD drive again.
Log on to your computer and click the "Start" button. Choose "Shut down" from the menu and then choose "Restart." Wait for the computer to restart, then press the eject button repeatedly.
Remove the DVD if the drive pops out.
Since there is no hole skip this and go to cleaning the lens.
Shine a flashlight on the DVD tray and locate the small hole near the eject button.
This is the bypass hole and it allows you to eject a DVD when it becomes stuck.
Insert an unbent paper clip into the hole and push it in until you hear the DVD begin to spin. Push the paper clip in until the drive pops out.
Remove the DVD and insert another one.
Use the bypass hole again if the new DVD becomes stuck.
If the new DVD sticks as well, you need to clean the laser lens on the DVD drive.
Insert a laser lens cleaning DVD and close the tray.
Run the laser lens cleaning program at least three or four times to make sure the lens receives a thorough cleaning.
Restart your computer and insert a DVD to test the unit.
Oct 19, 2012 | Lifetime Acer Aspire 4810TZ-4011...
A dvd is stuck in the drive. It resists all attempts at removal including the ''eject cd'' command in Open Firmware. Can I manually remove it?
The iMac (Slot loading) computer's disc eject mechanism is electrical instead of mechanical. To eject a CD-ROM disc at startup that contains system software, press the mouse button until the computer ejects the disc. If the disc does not contain system software, wait for the iMac to start up and drag the disc icon to the Trash.
If either of these steps fails to eject the disc, push the drive's manual eject button with a small, blunt object like a paper clip. This button is located to the right of the CD/DVD slot as shown in Figure 1. The computer must be turned on to eject a disc in this manner.
ht3007_1.gifFigure 1 Manual eject button
Once the disc is ejected, it extends just beyond its center hole so you can remove it from the drive. If the disc fails to eject, while holding in the paper clip, use another CD to gently push against the inserted CD. This gentle pressure may help to release the inserted CD.
Important: After ejecting the disc with the manual eject button, you must restart the iMac in order for the CD-ROM or DVD-ROM drive to work.
DONT FORGET TO VOTE
Oct 10, 2009 | Apple iMac G4 Desktop
CD Mechanically stuck in Drive Dell Studio 17
turn on the PC and insert a pin in the small hole on CD drive.it will be ejected.
Jul 10, 2009 | Dell Dimension 5100 (D51L1) PC Desktop
Averetec 3200 dvd replace
If you are asking, how to manually eject a disc from a drive, I can help.
If you have a Disc stuck in the drive, you can always use a paper clip to preform a manual eject. Just unbend a paper clip, and stick it in the pin size hole on the front of the drive. Keep pushing until the drive door opens.
Feb 15, 2008 | Averatec SDW-042 DVD RW Burner
The CD wil not eject
There is a small hole in the drive, insert a paperclip and push in to eject the drawer manually.. the disk might be stuck and jammed the drive
Dec 29, 2007 | Dell (0F027) CD-RW/DVD-ROM (Combo) Burner
DVD stuck in drive
try ejecting through my computer then right clicking on the drive and select eject or there should be a little pin hole at the front of the drive to push and force a manual ejection
May 30, 2007 | LaCie (300987U) DVD RW Dual Layer Burner
Televison & Video Logo
276 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
