Question about HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
Check right cartridge - HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Sergeant:
  • 185 Answers
Try this: assuming the cartridge is in good condiditon, remove and clean contacts (not the head) with alcohol along with cartridge holder pins.
good luck
Posted on Nov 03, 2010
How to remove and insert catridge on right
Switch on printer, wait up to initialize, lift cartridge access door located at right side of the printer(check snap shot)wait till cartridges stayed at right side,gently push cartridge down wards to un lock, take out cartridge, replace desired cartridge..close the door & check display for ready mode...Note: Used cartridges & refilled cartridges may give error message to replace it.. If you are replacing with new one, printer will print align page to align cartridge.. For aligning the cartridge put printed paper in face down condition in scanner & scan it.. 5_25_2012_7_00_52_pm.jpg
May 25, 2012 | HP Officejet 4355 All-In-One InkJet...
My printer says,move and check right ink cartridge
Unplug the printer. Plug it again and install the cartridge. If the message is stil present, try to install a new original. cartridge.
Oct 26, 2009 | HP Officejet 5610 All-In-One InkJet...
WRONG CARTRIDGE and Printhead does not move MP780
your printer ink cartridge can not access (move to middle) when you open up the cover, you may try
1) try to open right side cover you move the cartridge by hand (power off) to middle position, then take out the cartridge and reinstall it then power on, the cartridge moving right, you may open up the cover again if the cartridge go back the middle position which means your printer works normal. still stop moving go next
2) check the cartridge initcial sensor at righe side, the cartridge moving to the end of right should be touch this sensor, find out it and check there is good touch (click) by the cartridge body. adjust the sensor position maybe needed.
3) cartridge is stucked sometime also check the cartridge moving rail hard moving, need to drop oil to lubricate.
Feb 07, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I have put new cartridges into the printer cartridges won't move
you may check
1) the cartridge locker is set back to original position
2) check the bell that drive the cartridge is on the right position(not loosen) you can see the bell moving when you move the cartridge by hand.still not fixed
3) check the cartridge driver gear works in the right side cover, the motor not driving the bell if you can not see the gear running when power on.(very rare)
Jan 13, 2009 | Lexmark X75 All-In-One InkJet Printer
My hp photosmart 2575 says 'ink cartridge problem, remove and check cartridge on right. Refer to printer documentation
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Aug 14, 2008 | HP Office Equipment & Supplies
Remove and ck right cartridge
Once remove both the cartridges from the all-in-one and then clean the copper contacts of the cartridges and then put only black cartridge and check for the message displayed on the all-in-one if it even reads check right cartridge then the issue is with the all-in-one hardware. If it reads insert right or color cartridge then the issue seems to be with the cartridge.
Remove the cartridges from the all-in-one and power cycle the all-in-one and then reset.
Now insert the cartridge and check for the result. If the issue still persists then check the expiry date on the cartridge and once replace the cartridge and check for the result.
May 27, 2008 | HP Officejet 7210 All-In-One InkJet...
HP PhotoSmart C4180 All-in-One Color InkJet Photo Printer Logo
70 people viewed this question
Clive
Clive
