Question about Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
Power adapter for WD500E035-00 - Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive
I replaced the ac adapter on the motherboard of the Gateway NV5207u and now when I try to power it on, won't power on. battery light red
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Mar 30, 2013 | Gateway NV5207u Notebook
Tip
How to troubleshoot your laptop at start
When you plug in the power adapter and press on the power button, there is no signs of life at all. The laptop will not make usual noises, LEDs will not light up, the fan will not spin, the screen is blank and black, etc… In short, the laptop is dead. What you can do in this case?
1. Make sure the wall outlet is working and the laptop DC adapter is getting power from the outlet. Try another wall outlet.
2. Test the laptop DC power adapter, make sure the voltage output is correct. You can test the DC power adapter with a voltmeter.
3. Let’s say the DC adapter is fine and the adapter outputs correct voltage. In this case unplug the power adapter from the laptop, remove the battery, wait for 1-2 minutes, plug in the adapter and try turning on the laptop again.
OK, you tested the adapter and it’s bad. If you decide to replace the original DC adapter with a generic one, you’ll have to follow this rule:
The voltage output on your new adapter has to be exactly the same as on the original adapter. The amperage on the new adapter could be the same or higher.
If nothing helps and the laptop is still dead, apparently the motherboard is fried or there is a problem with the DC power jack. It’s possible the DC power jack is broken and the motherboard is not getting any power from the adapter. In this case you’ll have to disassemble the laptop and replace the power jack.
on Mar 27, 2010 | Computers & Internet
WILL NOT CHARGE OR POWER ON
Normal 0 When you connect the power adapter into the laptop, does the power LED light up? If not then -
Oct 22, 2010 | Acer Aspire 5100 Notebook
The power of my Linksys Wireless-G Game Adapter [ WGA54G ], isn;t coming on! I was wondering if there is a switch to turn it on!
With Linksys game adapter there's no power switch on it when you plug it to a power outlet if adapter is working the light should come on.
You can follow these troubleshooting to determine if adapter is really bad or something else.
Make sure that the power adapter that you are using came with the wireless gaming adapter.
Power adapter is connected properly to the back of the adapter and the electrical outlet.
Electrical outlet is preferably a surge protector.
Try another electrical outlet.
Unplug and replug the power adapter.
Hold the reset button for a minute, while the adapter is connected to the electrical outlet.
If there is still no power light then it is possible that the adapter is defective, and have it replace if still under warranty.
Oct 07, 2010 | Linksys Wireless-G Game Adapter [ WGA54G ]...
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
Apr 22, 2009 | Dell Inspiron 1501 Notebook
No power at forward poser adapters
did you check the fuse (under the hood) to see if it needs replacing? I had a dime roll into my power adapter which in turn blew the fuse. It is a separate fuse than for the rear power socket(s). Check the owners manual for the proper location for the power adapter (front). Remember to check the power adapter for any metal objects before changing the fuse.
Jan 05, 2009 | 2006 Buick Rendezvous
Power adapter
As long as you dont EXCEED the power rating listed on the answering machine itself, you can use/purchase a new power adapter for it.
You should be able to find a power adapter that matches the answering machines power need exactly.
I hope this has helped to solve your problem, good luck!
May 16, 2008 | Conair TAD 2014 Answering Machine
POWER ADAPTER
LOST POWER ADAPTER NEED TO PURCHASE NEW ONE
Apr 30, 2008 | TruTech PVS12701 Portable DVD Player
Western Digital Elements powered by WD 320 GB External USB (WDE1U3200N) Hard Drive Logo
442 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
