Question about Ovens
Looking for the manual for metal dynamics gourmet wood oven
My defy double door gourmet thermo oven overbakes cakes on the outside what should i do to ensure even baking
Reduce the temperature slightly or get an oven thermometer and follow the recipes.
Aug 01, 2017 | Ovens
I have a defy Gemini gourmet double oven. The top oven works but no light. The bottom oven there is nothing not even the clock is working. What could be wrong and how do I fix it?
First check and make sure you are not in Sabbath mode in the manual. if you are not in that mode then most likely your oven went over temp and the thermal fuse shorted out. You would need the fuse and most likely a temp sensor because it went over temp. I am not there to do tests but that is what is most likely.
Jan 18, 2016 | Ovens
Need a manual for Gourmet classic double oven Leisure
http://leisurecooker.co.uk/manuals/brochuresmanuals
The above link allows you to search by model and download for free
Nov 20, 2015 | Ovens
We have a Westinghouse Polaris free standing oven and the door does not seal properly, huge waste of money heating the oven to have theheat escape! grrrrr ! can the door be adjusted to close properly?
this is usally one of two things the metal is stressed at the point where the hindges go into the stove remove door and flatten with a piece of wood and a hammer only if you can see the metal is bowed out,also the actual hindges may be worn and have exccessive play in them
Jul 16, 2012 | Westinghouse Ovens
I have an SL100 - 10W La Germania table top oven (gas) I did not receive a operations manual with purchase of the oven and I do not understand its operation. Questions 1. How does it maintain the set...
I GOT THE SAME QUESTION .. IT IS A GAS OVEN . WHEN THERMOSTAT IS SET TO GAS MARK 4 WHICH IS EQUIVALENT TO 350 DEGREES , AFTER 10 MINUTES, IT REACHES ITS DESIRED TEMP. BUT IF I DON'T ADJUST THE FLAME, THE TEMP WILL RISE HIGHER AND HOTTER THAT I NEED TO OPEN THE OVEN DOOR TO DECREASE THE TEMPERATURE INSIDE. ANYONE KNOWS IF THAT IS NORMAL? THANKS12_1_2012_3_54_19_am.jpg
Oct 26, 2010 | Ovens
Can i install a biult in oven staight into the housing or does it need some sort of heat resistant layer around the oven
Is the housing metal or wood? Metal would be better, but either is ok. The oven most likely has double insulated walls. Connect the power source and see if the outside gets hot. If it does, you can purchase a thin layer of heat and fire proof insulation.
Nov 03, 2009 | GE Profile JTP56 Electric Double Oven
Aslight metal rubbing noise in the top lincoln impringer 1450 natural gas coming from themotor or fan side.openad with screwdriver the 13 screws etc to removed gaurd copver so that maybe i could see...
most likly the fault is the fan blades touching the side of the circular hole,to test.1.switch of all power.2.when power is switched of try switching your oven to on position.if oven will not work then proceed3.if you can turn the fan blades by useing a thin piece of wood or simler.4 if when you turn the blades you hear a rubbing noise you might take a closer look if you have torch point it in if you see the blades touching or one of the blades touching it might be possable to to push the offending blade back very slightley useing the same piece of wood you yoused at 3.if this fails to solve your problem the fan moter might be ready to give up. I hope this can solve your problem.yours adrian.
Sep 14, 2009 | Ovens
Ovens Logo
26 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
