Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Yes was washing clothes and it all of a sudden stopped.. Nothing on it works, none of the options. Reset the breaker, nothing... Brother suggested unplugging then try plugging in again which is what I am currently in the process of doing
  • 5,911 Answers
The most common cause of the symptoms you just described is a lid switch malfunction or lid strike (actuator) problem. Symptoms may include:
- Filling, then stopping on the intial fill cycle (no agitation).
- Stopping right after the wash cycle and not advancing to rinse cycle (no spin).
- The washer may not drain.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike" or "Actuator") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because it does NOT have a lid strike (actuator) and the small hole on the right hand side of the wash tub will not be present. This type of switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator rod by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
Replacement parts (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
NOTE: Banging or slamming the lid can actually cause more harm than good. These switches are fragile and can break easily in this manner.
The average price of a replacement lid switch is about $20 - $30 if you perform the repair yourself. The lid strike (if equipped) usually costs less than $5. Prices will vary between sites so shop and compare. If you have questions, or need additional assistance, please post back and let me know. This is a very simple repair that you can easily perform without the assistance of a repairman.
If the model number is correct, the part number for a replacement lid swtich is 3949247. The lid strike is 358684.
If you have any questions, please post back with your complete MODEL NUMBER (located on a nameplate along the wash tub rim under the lid) and let me know. I hope this helps you.
NOTE: If this advice does not help you enough, repairclinic.com has a Repair Manual you can order to assist you with all your repairs. The part number is 1170635 and is priced at about $20.
Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful to you.
Posted on Nov 03, 2010
Hello, I am Renee. My washer has stop draining and spinning after a comforter was washed. Would you please give me some advice/suggestions. Thank you.
Hi Renee,
Sounds like a blocked or faulty drain pump. Can you hear it trying to work during drain cycle?
A relatively cheap fix for most machines.
Thanks
Damien
Nov 08, 2015 | Washing Machines
My Kenmore 20722(990) washing machine stopped mid cycle. It is full of water and clothes. I checked my circuit breaker, nothing tripped. I checked my ground fault switch, that wasn't it either. It is...
Go to the link below and enter your model number in the search window there. Sears has thousands of parts lists and line drawing illustrations that can aid in finding the reset button if present or any other part you may want to locate or replace.
Sears PartsDirect
BTW, it does not have to be a Kenmore or Sears-branded appliance. They have many others as well.
Mar 22, 2011 | Kenmore 20722
I have a Kenmore 400 series top loading electric dryer that just stopped working right in the middle of a load of clothes. It was working just fine and then it just stopped. Now it will not turn on at...
Hi there....this sounds to be like you blew the breaker. Go to your breaker panel in your house and search out the fuse for the dryer. This will be a double 110 volt breaker. You need to reset both sides to be sure. It is easily locatable as they almost always have the items listed on the inside of the door of the panel. If this works for you great. Please try to remember to click on the yes box on your way out ...thank you and good luck.
Oct 10, 2010 | Kenmore 73952 Gas Dryer
Fill with water - Stopped in the wash cycle - Blew Breaker
please put unit in a out by its self...recontact if still problem
Dec 15, 2008 | Kenmore 15864/15862 Top Load Washer
MIcrowave stopped working
there is a 15 or 20 amp fuse behind the control panel. turn power off at breaker, remove control pand the fuse will either be round and the size of a quarter, screwed in or will be about an inch long and cliped into place
Nov 19, 2007 | GE JTP85 Electric Double Oven
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
