Question about Adaptec AVC-3610 (2144600) Video Capture
Adaptec AVC-3610 tuner problem
Plugged the cable in. MCE shows only channel 5 (Guide). Other channels are not visible, or work for a few seconds.
The feed from the cable is OK - when plugged to another computer with a different tuner I can watch all channels.
Any ideas ?
  • mccgemini Oct 17, 2008
    Adaptec AVC-3610 tuner problem problem.
    MCE 2005 cannot synchronize with adaptec 3610.
    It show only channel 5 in black and white.
3 Suggested Answers
alfi819
  • 65 Answers
SOURCE: Adaptec AVC-3610 dual tuner only showing as single tuner in vista
To diagnose, try to make it work with a different computer. If it does not work, the problem is with your AVC-3610, else try uninstalling and reinstalling all the drivers and software that came with it.
Posted on Mar 27, 2009
SOURCE: need power cord for adaptec avc-3610
looking at the one that came with my HP Pavilion zd8000... It takes an adapter that puts out:
5 volts DC
2.5 amperes
Inside pin is positive on connector
any wall wart that has that power output and has the right fit should work. Radio Shack or the Source Perhaps?
Posted on Jun 03, 2010
PICTURE FREEZES EVEY FEW SECONDS
Not enough info in your Q to help you.
1) What's the source?; TV tuner (digital terrestrial, cable, satellite. Internal or external tuner/receiver box)
2) One channel - some channels - or all channels affected?
3) Just this TV, or are other TVs affected in the house too
4) Are your neighbours having the same issues?
5) What have you done so far to troubleshoot the problem yourself? (retuned, checked cables, checked signal level, realigned aerial/antenna etc)
Oct 17, 2014 | Televison & Video
Sound robotic on samsung ln22a450c1d
change the sound volume in channels settings /avc and try
Jan 01, 2014 | Samsung LN32A330 32 in. LCD TV
Need power cord for adaptec avc-3610 dual tv tuner and dvr
5 volts DC
2.5 amperes
Jan 09, 2010 | Adaptec AVC-3610 (2144600) Video Capture
I have a Philips TV, model HD2717 C101. All channels do not display--Why? It skips quite a few channels on scan, the only to get them is to actually select the channel individually.
Hi are you running it off of an antenna or cable?
Assuming you have a digital tuner and are selecting the proper type of channel search Ie: cable or air it could be that the tv needs a firmware update to the tuner.
I have experienced similar issues with several TV's I had an Olevia 37" HDTV that required a firmware update to get the tuner to properly decode channels.
I also have seen lots of cases were people have cable hooked up without a cable box and receive "mixed" channels.
I currently have Comcast and have 6 TV's hooked up 3 with cable boxes and 3 directly off the line. According to Comcast I should not be getting anything besides "basic" channels without a box but using the digital tuner in the TV's does pickup most of the channels and even some HD channels that are not there using their boxes.
Interestingly enough none of the TV's tuners decode the channels into the same "channel." As an example HGTV on 1 TV shows up as 84.4 but then 86.1 on the second and something like 84.11 on the third.
My recommendation run the auto program again then go through channel by channel and see if anything needs to be manually entered or deleted. I know this is a pain in the **** and takes about 20 minutes per TV but hopefully that will tell you if your TV tuner is relocating the channels to another channel.
Lastly if your tuner is not digital or if the tuner can't be updated you may have to use a secondary tuner such as one in a VCR to get the channels you desire.
This whole Digital Conversion that we have undergone has brought to light for me at least that our government and corporations don't care about the real world impact on the ordinary person.
Sure they made money on reallocating bandwidth and sure tons of new HDTV's and digital products (including digital cable) have been sold but I haven't come across anyone who feels they have benefited from the conversion forced upon us.
Hope this helps sorry about my rant.
Dec 28, 2009 | Philips Televison & Video
Tuner will not pick up cable box on channel 3, front and rear AV
In order for the TV to work with the cable box by using a piece of coax and tuning the TV to channel 3, you must make sure the TV is in "Cable" mode on the tuner and not "AIR or Antenna" the frequency maps are different between these types of service and channel 3 cable will not be the same as channel 3 on Air or UHF/VHF.
Often there is an auto program feature on TV's that will "scan" for all available channels, and this should select the proper input type.
Hope this helps!
Mar 29, 2009 | Philips Magnavox MS3652S 36" TV
Mar 27, 2009 | Adaptec AVC-3610 (2144600) Video Capture
Digital tuner
Try this!
The manual states the TV is designed to search for channels.
turn the power on
then hit menu
(if it doesn't start searching for channels)
then hit channel up -let it run a complete channel search
hit menu again
hit channel up- let it run a second channel search
hit menu again after it finishes it's 2nd search cycle
if it doesn't go to a channel, hit the input button.
it worked for me!
hope it helps
Dec 08, 2007 | Sanyo Vizon LCD-15A2 Television
Adaptec AVC-3610 (2144600) Video Capture Logo
50 people viewed this question
Top Adaptec Televison & Video Experts
Are you an Adaptec Televison and Video Expert? Answer questions, earn points and help others
