Question about GE Refrigerators
My ice maker in my GE refridgrator over fills with water run in to ice bucket
  • GE Master
  • 2,699 Answers
Look at the ice maker,there's a screw on it that allows how much water fills into it,also you could have a bad water valve located on the back of the fridge,try the ajustment,if that doesn't help change out the water valve,also next time send the full model number so we can look up your machine.let me know how you make out
Posted on Nov 03, 2010
Not getting water to GE Model PSS26SHRBSS ice maker
fill the ice maker with water,wait 2 to 3 hours,see if ice is in bucket,if there is most likely you have a bad water valve or the line is frozen not letting water go to ice maker,but you should hear the valve buzzing if the line is frozen.go here,put your model number in and you can look up your parts.hope this helps and good luck with your repair.
https://www.searspartsdirect.com/model-number/PSS26SGRBSS/0432/0165000.html
Jan 19, 2018 | GE Refrigerators
Fridge's water dispenser continues to run
Hello John;
My name is Peter. I am a retired field service refrigeration technician.
Neither your ice maker or water dispenser work off your main control board.
There is only one reason that the ice maker will not fill and you water dispenser does not shut off immediately after the contact switch disengages.
Your problem is low water pressure. You have a bad water valve.
After time the water valve seals fail, metal form the water line or corrosion plugs the water supply valve. You need at least 60 PSI water pressure to shut off the water dispenser solenoid valve and at least 60 PSI to open the ice maker water valve and fight the long fill tubing resistance.
Check - Pull your unit out where you can get behind it. Turn power off to your unit. Turn the water valve off. With towels under the unit water connection and a large bucket ready, disconnect the water supply line. With the water valve shut off you will probably get a steady stream of low water flow. The valve is bad. If not, open the water valve with the water line in the bucket. Is the water flow 60 PSI? Probably not.
Use a hair dryer to completely dry the solenoid valve and electrical area before you plug your unit back in
You need to replace the valve.
Before you do the above. Just in case you move your unit check for a bend or closure in the water line.
Dec 24, 2014 | GE Refrigerators
Refrigerator: GE model GT22KCPCRCC New ice maker: GE model WR30X10093 Problem: with old ice maker installed, ice tray was over filling with water causing ice blocks in ice bucket, freezer and into the...
What your describing sounds to me like a classic case of the water valve sticking open, as you have stated and replacing it will resolve your problem.
Gene
Jul 31, 2011 | GE Refrigerators
Hi there, We are having problems with our ice maker on our GE Profile Model # SRD2054W, purchased October 1995. I know it's old, but it has been a good appliance until now. The ice maker fills but the...
What you think is probably correct. Water valves can seep water and freeze the fill tube. Remove the ice maker and the fill tube remove ice from the fill tube and replace the water valve.
Apr 16, 2010 | GE Profile 23.1 Cu. Ft. Side-by-Side...
My ice maker is frozen..the ice comes out not in cubes but as a huge chunk of massive ice in the white bucket part
If this is a crescent cube maker, then either the mold heater is cracked, the fill switch is broken, the water fill hose and water guide are broken or mislocated, the refrigerator not sitting level, or an incorrectly adjusted fill level.
Dec 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Nov 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE ice maker, solid ice in ice maker
Many ice makers have an adjustment screw behind the front cover that shows plus or minus. Try the minus turn of the screw that should shorten the amount of time the ice maker fills. If electronic please call the company you purchased it from and explain the problem. Sea Breeze
Jul 23, 2009 | GE Refrigerators
Ice maker stoped working
Jun 25, 2009 | GE Profile PSW26P Stainless Steel Side by...
My GE side by side fridge/freezer is working, water dispensing ok, but not making ice. I switch off the fridge, than ice maker but still not making ice. I try all the hints from Manual but no luck. Water...
fill the ice maker with water manually, if you have ice in the bucket you know that the ice maker is working , after check the water valve if is opening , if it is replace main board
Jun 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
