Question about Whirlpool Washing Machines
The suspension spring from the back end of my Whirlpool washing machine came off and the tub shakes violently when in spin. I am not quite sure how to replace the rear spring since it is different from the two side ones.
    President:
  • 1,294 Answers
You just have to look for the hole from where it came off; but make sure to put in a similar washer (like the other springs have). And make sure your machine does not shake while you try to move it with both hands; while switch is off. The Lord reigns...................
Posted on Jun 13, 2008
Thin twin tub loose
you will need to remove the front panel of the washer,there are 3 spring suspension rods below the tub and either one or more of these springs are disconnected from the tub or broken
Dec 07, 2012 | Whirlpool LTE6234D Top Load Stacked...
Washer shakes as if unbalanced during spin cycle I think that part of the suspension has failed, the result is the washer shakes violently during the spin cycle but otherwise seems to perform reasonably...
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Whirlpool / Kenmore top load, direct drive washers use a number of springs between the main suspension plate and base assembly as well as friction pads that are designed to minimize shaking.
See the Whirlpool / Kenmore service manual for top load washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It's likely that one of the springs or pads has broken or come off.
See the following for how to remove the cabinet to get at these.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Oct 24, 2009 | Washing Machines
The tub is offline and shake the washer violently
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 12, 2009 | Kenmore Washing Machines
Kenmore he2 washer shakes violently
Sep 07, 2009 | Kenmore HE2 Plus Front Load Washer
Shakes violently in the spin cycle
hi...
the reason it shakes violently is because
1)Most noisesfrom a washing machine occur during the spin cycle. If you hear loudthumping during the spin, the load of clothes may have becomeunbalanced. Stop the washer and redistribute the clothes, then re-startit. Repeat these steps if necessary.
or else the other reason may be
2) If your washer doesn't spin or agitate on either the delicate or regular cycle, check these:
Selector switch
Clutch assembly
Drive motor
Selector switch Ifyour washer has a selector switch on the control panel, make sure thebutton for your selection is pressed all the way in, or set properly.
Clutch assembly ManyGE®/Hotpoint® washers use a clutch and an automatic shift lever. Thisassembly is quite complicated. If there's a problem with it, youprobably should contact a qualified appliance repair technician.
Drive motor manywashing machines have multiple-speed drive motors. Though it'suncommon, the drive motor may work fine on one speed but not onanother. If the drive motor has failed on one speed, you need toreplace the entire motor.
On something like this you will need to
remove the washer wrap toinspect the suspension springs & base assembly. Be sure the shippingpins have been removed. The tub should float freely.
I think my solution would have helped you...rate for me if it is been useful.....thank you for using fixya....
Jul 20, 2009 | Admiral Washing Machines
My front load washing machine shakes violently in the final spin cycle. It is brand new and sits level.
Also - be sure the drum locking (transit) pins were removed by the installer.
Jul 03, 2009 | Kenmore Washing Machines
Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Apr 03, 2009 | Washing Machines
Spin cycle speeds up to the point of violent shaking
IF THIS IS A BRAND NEW INSTALLATION - be sure you have removed the basket shipping pins (4) that secure the tub during shipping.
Mar 24, 2009 | Kenmore Washing Machines
Drum off balance
It's either a bad suspension spring or you have a crack in the tub support.
Jul 15, 2008 | Whirlpool LTE5243D Top Load Stacked...
Suspension pads? where are they do you have a good diagram?
most suspensions on machines use 2 springs on top of the drum and 2 suspension legs on the bottom. ( similar to a car shock absorber) just make sure the bottom concrete counter weight is not loose , this will cause violent a shake
Feb 08, 2008 | Washing Machines
Open Questions:
Washing Machines Logo
74 people viewed this question
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
prem mathew
